    657
    2,692
    898,705
Overscan Jitter
One of the limitations of Stella is it doesn't emulate the jitter that occurs if overscan runs longer/shorter than normal. This is a quick attempt to address this.
TIA.hxx
Change currentFrameBuffer
    uInt8* currentFrameBuffer() const
        return myCurrentFrameBuffer + myFramePointerOffset + myVariableScanlineJitter*160;
Add myVariableScanlineJitter
    // contains the difference between the scanline counts of the
    // last two frames. If non-zero the image should jitter.
    Int32 myVariableScanlineJitter;
TIA.hxx
Locate this bit of code in endFrame()
  // Recalculate framerate. attempting to auto-correct for scanline 'jumps'
  if(myAutoFrameEnabled)
and add this directly above it
  // save difference in scanline counts for jitter emulation
  myVariableScanlineJitter = myScanlineCountForLastFrame - previousCount;
  if (myVariableScanlineJitter < 0)
      myVariableScanlineJitter = --myVariableScanlineJitter / 2;
  else if (myVariableScanlineJitter > 0)
      myVariableScanlineJitter = ++myVariableScanlineJitter / 2;
Test build of Stella for Mac OS X:
Stella OS Jitter Test.app.zip
