    657
    2,692
    898,715
Sprite Engine rebooted
Both players are being used to draw all the sprites, the 3 dotted lines are drawn using the missiles and ball.
blogentry-3056-0-13458500-1495152439.png blogentry-3056-0-35459600-1495238564.png
You can move the blue sprite around with the joystick, as it crosses paths with the other sprites the players will flicker. Hold fire to move slower. The white dot in the radar will show the location of the blue sprite within the world.
blogentry-3056-0-51390800-1495152585.png blogentry-3056-0-33568800-1495238541.png blogentry-3056-0-40695700-1495238559.png blogentry-3056-0-65116700-1495238637.png
Right Difficulty = A to show the use of HMxx to shift the missiles and ball back & forth on every scanline.
blogentry-3056-0-82148400-1495152435.png blogentry-3056-0-78947100-1495238553.png
The missile/ball routines will probably take a bit to migrate over as I'll have to rewrite them to take advantage of the new support for HMxx.
For Harmony on a 2600*
draconian20170518.bin
* we discovered an issue with Fast Jump that required an update to the Harmony/Melody driver as well as Stella's implementation of it. As such, you'll need Stella 5.0.0-pre8 or newer, which isn't available yet.
Addendum: Per request, added screenshots using the Fixed Debug Colors. Do note that the colors have changed to make it easier to know which color's which (ROYGBIV), plus the debug colors are now displayed on the TIA Tab!
4 Comments
Nice work - is this the 4th or 5th rewrite :) Hopefully you'll be able to reuse the code in another game as it is quite generic?
Chris
Thanks! I've lost count :lol:
The kernel and C code are pretty generic. I plan to use them to write up a tutorial on CDF development after I finish Draconian.
