    657
    2,698
    899,174
SpiceC dasm usage figured out
In the prior SpiceC blog post I showed what a config file would look like:
MENU_KERNEL = "Menu/48pixel.asm"GAME_KERNEL = "Game/maze.asm"SCORE_KERNEL = "Score/radar.asm"AUDIO = SAMPLES    MAC DIGITAL_AUDIO        lda #AMPLITUDE        sta AUDV0    ENDM
A key part of that is the constants which specify which kernels were selected for the project. Using those, my plan was to do this in the 6507 source code:
GameKernel:    INCLUDE GAME_KERNEL    INCLUDE SCORE_KERNEL OverScan:   ...
Turns out dasm does not support constants for include files!?!?!? So I updated dasm ;)
After getting that issue resolved, I created a few dummy kernels that displayed different colors to confirm that the kernel selections were working correctly. A key part of how that works is all Score Kernels include a constant defining how many scanlines they'll use:
SCORE_SCANLINES = 30
and all the Game Kernels will self-adjust to use whatever is left:
       ldx #192 - SCORE_SCANLINESKernelLoop:           stx WSYNC       ;        DIGITAL_AUDIO   ; 5  5        txa             ; 2  7        and #15         ; 2  9        ora #$C0        ; 2 11 green        sta COLUBK      ; 3 14        dex             ; 2 16        bne KernelLoop  ; 2 18
I do plan to allow some control for the score kernel heights - you'll be able to adjust the font size so the config file will contain something like:
SCORE_FONT_HEIGHT = 8
while the score kernels would use:
SCORE_SCANLINES = 22 + SCORE_FONT_HEIGHT
I also modified the short descriptions in the kernels to show the colors to make it easier to test:
For the first test I selected the green game kernel and the 30 scanline red score kernel:
Next up, the blue game kernel without a score kernel:
Last test, the same blue game kernel with the 50 scanline white score kernel:
So now that I've figured out how the dasm side of the projects will work, I need to figure out the C side. I suspect this next part will take a month or two.
1 Comment
I've changed the name from Spice C to SpiceC so searching for info about it will be easier in the future. An AtariAge search of Spice C returned 833 hits for me, which is the exact same results as a search for just Spice so the lone C is being ignored.
