The Poor Man's 1400XL Part 4
Centronics connector arrived from RS first thing on Monday morning, but we need to finish the VBXE installation first before figuring out a bracked for the PBI socket. Following Bob Wooley's article, we use a piggy-backed 74LS08 (although Bob recommends an HC) to create the EXTSEL line which is absent on the 1200XL. This is required not only for the PBI but for VBXE itself.
I haven't lost my "spaghetti" leanings, but at least some shink-fit insulation is in evidence.
The XL VBXE adapater (originally intended for the 800XL) needs to be raised up on an extra two stacked precision DIP sockets in order to clear GTIA and the piggy-backed LS08. Fortunately there's plenty of headroom in the 1200XL.
Here's the VBXE finally fitted. Thanks to Candle for patiently explaining the 3.5MHz hook-up points.
After experiencing sync issues and consulting with Candle again, I eventually discovered that pin 15 of CD4050 isn't even connected to anything on the 1200XL. Pin 12 provided the necessary sync signal.
The NTSC display is noticeably taller than the PAL screen, but I'll get used to it. Until Ultimate 1MB arrives, I'm running the VBXE core with emulates a 256KB RAM upgrade. Here's the machine running a prototype SIDE cart:
So we have extended RAM, RGB output, RTC, SpartaDOS X and IDE storage. Next time we'll tackle internal BASIC and the PBI.
3 Comments
