TF3 Hacking
For lack of anywhere else to write a retro tech blog, I figured I'd give this place a shot. FWIW, all my posts are likely to be long.
Thunder Force III was bar-none my favorite Genesis game. It sold me on the system and I've honestly never stopped playing it. And one of the things that sold me the most on it was the music.
Unfortunately, this awesome soundtrack used all the FM audio channels on the machine. And weapons also used a channel or two. So when you fired, channels were subtracted from the music.
Thunder Force III is a 2d scrolling shooter. There are very few places where it's wise to take your finger off the fire button to listen to the music. (I had a few memorized though). I always wished for a way to play through without sacrificing the music.
So a few years ago, after locating some docs on TF3's internals over here (http://www.romhacking.net/documents/465/), I decided to take a stab at muting the weapons. All the other sounds are part of the game, and I left intact (and I rarely noticed them stealing channels anyway).
I had a couple of missteps on that project. The first was I tested all my changes in emulation, and then I burned it to an EPROM. I was very proud of my plan -- I mounted the EPROM on the /bottom/ of the PCB, leaving the original ROM in place, and mounted a switch to select. You couldn't change it at runtime (switch debounce will cause a bad read and a crash), but you could select weapon sounds or not before starting up at least, and all in one TF3 cart.
Unfortunately, I powered it up with my ROM, and got a dead screen. This was pretty disappointing, and then I remembered there was a checksum on Genesis carts. I went through the emulator for an explanation -- and sure enough "auto-fix checksum" existed. I learned something there, but I also had a problem -- what was my new checksum, and how the heck was I going to fix the EPROM without desoldering the whole darn thing?
The checksum I got easily enough - by setting a breakpoint when the checksum word was read from the cartridge header, I found the checksum function and read what the Genesis had calculated for my ROM. Now I knew the right value, but how was I going to fix it?
EPROMs (and flash, for that memory) are interesting devices. They are "erased" by charging every cell, so that the cell's value is '1', and "programmed" by draining that charge away to make '0'. In other words, you can always change a '1' into a '0'. I first checked whether I could fix the checksum word by only changing bits to 0, and that was not possible. So I had to make the cartridge match the original checksum. Scanning through the ROM with a hex editor, it was clear there were large unused areas, conveniently set to $FF (ie: ALL bits set). I calculated a difference, and changed two bytes in the middle of one of these areas. A quick test in the emulator verified my new checksum matched. Now, since I fortunately hadn't trimmed the EPROM pins yet, I was able to plug it into the programmer again, and re-program it. Words that were the same wouldn't change, just those two bytes I modified. And this worked. The result is here:
Backstory complete, we come to last night and the long part.
I picked up some 4MB EPROMs and got it into my head that I wanted a Thunder Force multicart, with menu and the works. Although 4MB is lots of memory (2 and 3 are 512k, and 4 is 1MB), the easiest way to do the bank switching is to divide it into 4 banks of 1MB. That left me unsure what to do with my hack, though, since one bank is easiest devoted to the menu. So I decided there was no reason why I couldn't make the weapon sound an in-game toggle.
I decided to put it as a keypress during pause. When paused, TF3 lets you adjust your speed and selected weapon, only the fire button does nothing. So that seemed ideal.
I started out to trace how the existing keypresses work by pausing the game, then setting a breakpoint on reading the joystick. I was able to determine that the joystick read function was identical to what the FAQs I had collected listed - clearly a standard library. Both joysticks are read and saved, despite TF3 only using one.
In tracing this code, I found a rather clever sequence I've never seen before that provides leading edge detection in just two instructions - I'd always manually checked this myself. It's common to save the "last" read in order to detect held keys and the like. TF3 goes a little further - using "EOR new,old" then "AND new,old", it ends up with a word that contains only newly set bits (assuing '1' bits mean pressed). This is great for menus and options and saved me having to deal with that, since a held key on a toggle would otherwise be trouble.
It took only a little longer to find the code jumping into a small function that checked specifically the weapon select and speed change buttons, then returned. Setting a breakpoint there proved that this was only called during pause mode - it seemed like I found my hook. Now I could start to write code.
I replaced a subroutine call to branch to one of those large blocks of $FF bytes I mentioned before, and now I just had to write some code. The one catch was to keep the branches short, I selected a block in the first 64k of the cart. I used a standard 68k assembler and used the listing file to get the output bytes - this saved me from needing to hand assemble or calculate offsets.
Although large regions of memory looked untouched, it always makes me nervous to assume that, so rather than play through many times and try to hit every possible case, I did an old trick and pushed the stack down. The 68k stack normally starts at the very top of RAM (in fact it's set to $00000000 in all the ROMs I've seen). I nudged it down 4 bytes in the header (to make later fixes easier - I only need a bit).
So my next task was to initialize, modify, and protect that new word. First I created the new pause button-check code. I copied the tests for the other two buttons, making life easier:
org $7180 0838 0004 f1f3 btst #$4, $f1f3.w ; check new buttons for fire 6700 0008 beq done ; not set 0878 0000 fffe bchg #$0, $fffe.w ; invert the bitdone: 6000 ca34 bra $3bc6 ; continue with original call
I was using the top word, but I moved the stack 4 bytes after I'd written all that code, as the memory zeroing code used 32-bit writes - I found that later. $f1f2 contains the filtered new buttons of both joysticks, so $f1f3 was joystick 0. bit 4 is normally 'B', which is fire, but if TF3 remaps the keys it ensures the functions still map to the correct bits.
So, all this does is check, if Fire is newly pressed, invert the flag bit. the code then jumps to the original subroutine whose call it replaced. Since it uses BRA instead of BSR, the subroutines RTS will return to the original caller.
I was able to test with that much and a debugger, of course, and see the bit was toggling, but it initialized to 0. It probably would have been easier to leave that as 'on' and use 1 as 'off', but I get stubborn sometimes...
So now I needed new initialization code that would set the bit to '1'. I decided the simplest way was to change the entry point, so I let the assembler tell me the next open address, and wrote this simple code:
entry: 08f8 0000 fffe bset #$0, $fffe.w ; set the bit for weapon sounds 6000 9064 bra $0200 ; jump to real entry point
I then changed the entry vector to point here instead of $0200 as originally set. All it does it ensure that my bit is set, and jump to the original code.
Unfortunately, it didn't work! Stepping through the code I could see my bit set, then cleared. Eventually, I identified two loops that were zeroing RAM.
The first one counted up and was easy enough to just reduce the count by one dword, but the second one was tricky, and it took me a couple of passes to figure it out. The first problem was the start address was set by move d0 (previously cleared to 0) to A6, and then zeroing using predecrement mode on A6. I finally realized that moving A7 (stack pointer) to A6 was the same size instruction and would provide the start point I wanted, so I did that. But my bit was still being zeroed and I was not sure why!
Finally, though, I clued in. The Genesis RAM is mirrored in the upper address space - 64k repeating through $e00000 to $ffffff. I hadn't changed the COUNT of words to zero, and it was simply "wrapping around" when it reached the bottom and zeroing my top word. The count was part of an initialization table, and easily modified. Finally my bit seemed to be preserved, and nothing else appeared to mess with the stack pointer.
Now I went back to my original hack. I had replaced all the weapons sound effects BSRs with NOP NOPs. This time I needed to analyze them - and there were only three entry points: $532c, $1970, and $197E. The TF3 hacking document identified those as a sound effect playback engine, and two Styx (player ship) fire sound requests. Sure enough, the latter two functions did some tests then conditionally branched to $532c.
I didn't need to understand those two functions, but I had to decide what to replace. Of 13 patches, though, all but 5 went through those two functions. I briefly considered replacing $532c, but that is used for ALL sound effects, so I'd need to filter which sound was being requested, and that felt like too much trouble. Instead I opted to replace the two Styx fire sound request functions, and directly patch the branches to $532c. For this, I wrote three new subroutines. The first two completely replaced the Styx Fire Sound Request functions - first testing my new bit, then doing the same as they used to do. (They were so short, I didn't bother jumping back to them). The third was a wrapper for $532c that tested my bit before jumping.
styxfire1: ; $1970719E 0838 0000 fffe btst #$0, $fffe.w ; is it set? 670c beq.s dorts ; no 0278 0001 f312 andi.w #$1, $f312.w ; original function at $1970 6604 bne.s dorts ; not quite sure 6000 e17c bra $532c ; play the sounddorts: 4e75 rtsstyxfire2: ; $197e71B4 0838 0000 fffe btst #$0, $fffe.w ; is it set? 67f6 beq.s dorts ; no 0c78 0002 f312 cmpi.w #$2, $f312.w ; original code 6504 bcs.s skip1 4278 f312 clr.w $f312.wskip1: 4a78 f312 tst.w $f312.w 66e4 bne.s dorts 6000 e15c bra $532c ; play the sound directsnd:71d2 0838 0000 fffe btst #$0, $fffe.w ; is it set? 67d8 beq.s dorts ; no 6000 e150 bra $532c ; play the sound
Then, at $1970 and $197E, I overwrite the beginning of each function with a BRA to the replacement function. (Again, using ORG directives, I could just write them in the assembler and let it calculate the offsets).
org $1970 bra.s styxfire1 org $197e bra.s styxfire2
and so on.
For the five cases of BSR $532c, they became BSR directsnd, again letting the assembler calculate the offsets.
And that's all! Technically that's more than was needed, I could have done away with all the hacking of init functions by simply inverting the meaning of the bit, or by accepting that sound effects for weapons would be OFF by default, but sometimes when you do a hack incrementally you learn as you go, and it's easier to deal with the new knowledge than undo what you did.
The last thing I needed to do was calculate the new checksum, which again I let the Genesis do, breakpointed, and then stored the correct value in the header - no need to patch FF bytes this time.
It works well, though I still need to play through start to end and verify it is really okay. The game starts up normally... by pausing and pressing fire once, weapons sounds are turned off, and you can repeat to turn them back on. Much nicer than the hardware switch
For those who just want to try it, here are the patches. If the original bytes don't match (especially the checksum), you probably have a different version ROM than I did. I don't know if they are out there.
$00000000 - change "00000000" to "fffffffc" - moves stack pointer down 4 bytes to use as data space for hack$00000006 - change "0200" to "7194" - change start address to my new entry point$0000018E - change "0678" to "c084" - update checksum$00000230 - change "2c40" to "2c4f" - patch memory clear routine and user stack pointer$000002a2 - change "3fff" to "3ffe" - patch memory clear routine counter (initialization table)$00000328 - change "03ff" to "03fe" - patch second memory clear routine (counter)$00001388 - change "283e" to "5df8" - changes relative BSR from $3bc6 to $7180$00001970 - replace "02780001" with "6000582c" - replace styxfire1$0000197e - replace "0c780002" with "60005834" - replace styxfire2$000019ea - replace "3942" with "57e8" - replace sfx call$00001a70 - replace "38bc" with "5762" - replace sfx call$00001aa0 - replace "388c" with "5732" - replace sfx call$00001c1a - replace "3712" with "55b8" - replace sfx call$00001c50 - replace "36dc" with "5582" - replace sfx call$00007180 - replace "FF" bytes with following - inserts above code 0838 0004 f1f3 6700 0008 0878 0000 fffe 6000 ca34 08f8 0000 fffe 6000 9064 0838 0000 fffe 670c 0278 0001 f312 6604 6000 e17c 4e75 0838 0000 fffe 67f6 0c78 0002 f312 6504 4278 f312 4a78 f312 66e4 6000 e15c 0838 0000 fffe 67d8 6000 e150
Double check your work before you save it - a single mistyped character will cause a crash or unexplained behavior.
- 1
