The UAV Blog
    15
    8,219
Install - UAV & AC in the 400
Bryan
revised Jan 2, 2018
Recommended board: Plug-In
The 400 has socketed chips including the 4050. The easiest installation is to put the UAV in the 4050 socket, but if you want to keep the RF output, you'll need to solder the socket on top of the 4050 and then mount the UAV on top of it. These instructions should work for NTSC and PAL systems.
Position the main PCB with the CPU board slot toward the back.
1. Connect a wire to the left side of C187. This is Color-In.
2. recommended: Solder the 16-pin socket on top of the 4050 (best done with the 4050 removed).
2. Make sure the UAV jumpers are set for the 400 and install it in the socket. The green terminal should be facing away from you.
3. Put the Color-In wire in the right-most terminal (terminal 1 when facing the terminal openings).
4. Attach your video cables to the UAV. The remaining terminals (R to L) are Ground, Chroma, Luma, Composite, and a 2nd Ground.
Installing an Audio Companion board:
1. Locate C182. The AC board will go on the back side of the leads.
2. Line up the corresponding pads on the AC board and solder it to C182's leads so that it stands upright (the power pads are available on both sides of the board and are marked + and G).
3. Attach a wire for Pokey audio to the front end of R160.
4. Attach the other end to the first input pad ('iA' directly above the + power pad).
5. Attach a wire for SIO audio to the right side of R170.
6. Attach the other end to the last input pad ('iD', the 4th pad from the left).
7. Attach your audio out wire to the output pad (directly above the G power pad).
8. Attach audio ground to the ground pad on the back side of the UAV.
Carefully check your work against the pictures before powering the system. Route cables carefully out of the shielding during reassembly.
4 Comments
Sure. An RCA connection is very common for audio. Or, are you asking if the AC board is necessary? It isn't, technically, but it greatly simplifies creating an output that mixes Pokey and SIO audio together (like tape loaders with music).
Hi Bryan, thanks for providing this. Back in Jan I discussed making a video of installing this, to host at my channel (http://youtube.com/perifractic). I'm finally shooting it! I hope you can assist with some constructive questions/feedback about the above instructions?
You say:
"3. Put the Color-In wire in the right-most terminal (terminal 1 when facing the terminal openings)."
This is a bit confusing. In the photo, it is indeed in the "right-most" terminal, but it depends which way the user's board is facing. "Terminal 1" isn't labelled so we're reliant on a user knowing that 1 is leftmost... but we're talking about rightmost... Can I suggest something like: "Put the Color-in wire in Terminal 1, which is the terminal nearest the edge of the board." (That way we don't get into left or right which is all subjective.)
You say:
"4 ... The remaining terminals (R to L) are..."
Can I suggest: "Terminals 2 to 6 are..."
You say:
"1. Locate C182. The AC board will go on the back side of the leads."
Back side is subjective. Also what is the back side of the leads? Isn't it more that the leads will go on the opposite side to the AC's chip or logo?
You say:
"2. Line up the corresponding pads on the AC board and solder it to C182's leads..."
"Corresponding" is tricky for some as there is no obvious labelling on C182 to see what corresponds with what. Can I suggest something like: "Orient the AC board with the chip and logo facing away from resistor C182, then solder the side facing towards C182 to its leads."
Same sort of suggestions with...
"Front end of R160" - which is the front?
"right side of R170"
"ground pad on the backside of UAV" - actually isn't it the top side when the UAV is in place? It's facing upwards.
I really hope these help you and future users! I'll post back when the video goes live :)
Your friend in retro,
Perifractic
