Pack Rat Penance
Posted by EricBall, 16 July 2012 · 158 views
Like a lot of geeks, I have a collection of old and obsolete PCs in the basement.  A few were my primary PCs, but many I rescued.  And like any pack rat, I had plans for them - like being used in a MAME cabinet.  Some of the plans have even panned out - like a MythTV backend or a TiVo guide server.
But the basement cleanup & purge brought to light the number of PCs which were lurking in the corner.  The two 486s were declared surplus after removing the hard drives (for a final backup & secure wipe).  And I swapped the drives & ATSC cards from a noisy Athlon XP into a quieter 1GHz Celeron.  (A MythTV backend doesn't need a fast CPU if you avoid transcoding.)
Then I took a serious look at the various Slot-1 PCs I had.  One was a bare P2-400 motherboard in my Tempest cabinet.  I decided to upgrade it to the P3-550.  So I started swapping stuff around and somehow ended up with at least two dead PCs.  But then I realized there wasn't any point in using them as I had an Athlon 900 which I could use instead.  That one booted, but failed to enter setup.
And then it hit me.  Why was I bothering with these broken and obsolete PCs?  For the Tempest cabinet I could use the Athlon XP - it was the fastest one and known working.  And if I ever did build my MAME cabinet I would be better off getting something new anyway.  (Yes, Tempest is running MAME, but I only needs to run Tempest and can use an older version.)
Thus in one fell swoop I have relegated four PCs to the dustbin.  After I have pulled the hard drives, of course.
May 2013
S M T W T F S
   1234
567891011
12131415161718
192021222324 25
262728293031
Recent Entries
Search My Blog
