Atari XM301
8 replies to this topic
#1 walter_J64bit OFFLINE
walter_J64bit
  • 5,222 posts
Posted Mon Apr 30, 2007 5:34 AM
Ok I've just got my hands on one that didn't come with the manual or the software can any one help out?
Edited by walter_J64bit, Mon Apr 30, 2007 5:35 AM.
#2 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Mon Apr 30, 2007 6:49 AM
That was my first modem too. I remember it coming with XE-TERM I think..and it's odd, that program is not in any of the big archives I have, I'd like to get my hands on that program as well..
#3 puppetmark OFFLINE
puppetmark
    Dragonstomper
  • 711 posts
Posted Mon Apr 30, 2007 7:00 AM
Try this threadd. You will find the SW. You need to have the Xm301 attached or the software will error.
http://www.atariage....p;mode=threaded
#4 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Mon Apr 30, 2007 10:52 AM
I remember a hack I used to use to get my XM301 working while my disk drive was in the shop...
The Atari 1030 modem is just like an XM301, except that it can be booted from like an 850. It loads a terminal program if you boot with the 1030 but no disk drives...
I had a broken 1030 (lightning damage; would boot, but wouldn't actually take the phone off the hook), so I used to boot up with the 1030 attached, wait for its built-in terminal program to load, then unplug it and plug in the XM301.
It worked surprisingly well...
#5 Curt Vendel OFFLINE
Curt Vendel
  • 4,912 posts
Posted Mon Apr 30, 2007 4:09 PM
The XM301 is a repackaged 1030 Modem, in fact the original specifications listed it as the 1030P (portable perhaps, I'm not sure) but any s/w for the 1030 will work on the XM301.
You can use it on any 8Bit system except the 1200XL (unless you restore the 12vdc line back onto the SIO connector)
Curt
#6 walter_J64bit OFFLINE
walter_J64bit
  • 5,222 posts
Posted Mon Apr 30, 2007 6:24 PM
Cool Thank's I'll put that on disk ASAP are there any BBS's in NC I can lon into?
#7 walter_J64bit OFFLINE
walter_J64bit
  • 5,222 posts
Posted Mon Apr 30, 2007 6:26 PM
Curt
I think I did some time back to my 1200XL the XC12 tape drive works with my 1200XL.
#8 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Mon Apr 30, 2007 11:44 PM
Too bad the XM301 didn't have the 1030's built-in bootable terminal program... guess by then, there weren't too many non-disk-drive-owning Atari users?
#9 walter_J64bit OFFLINE
walter_J64bit
  • 5,222 posts
Posted Tue May 1, 2007 11:49 AM
WOW it works! :lust: now I need to get a hold of a BBS! :lust:
