Expanding the 400
26 replies to this topic
#1 TimsterAA OFFLINE
TimsterAA
    Moonsweeper
  • 357 posts
Posted Sun Mar 23, 2008 9:28 AM
I had posted this in another topic, but I feel it may not get seen there, so I thought I'd start a new one.
I cracked open my 800 because the video had gone fuzzy on me, and I wanted to swap out the RF cable, which I did successfully. While I was in there messing around, I found under the top cover (the part behind the cart slots) the place where the RAM expansion 'carts' are. I found my 800 has three 16K carts and one 10K ROM cart. I assume this is the limit the original 800 can be expanded.
Regardless, I got thinking that even though I fixed the video quality problem, I know for a fact that my 400 has even crisper video out. I thought maybe I could put the extra RAM from the 800 into the 400, and use that. But when I opened up the 400, it's 'ram-expansion' innards were not there (or at least not like the 800).
My questions are: 1) is the 400 expandable like the 800, and 2) if so, where/how do you expand the memory?
Thanks for all the help everyone! This Commodore-raised boy truly appreciates it!
--Timster--
#2 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,013 posts
Posted Sun Mar 23, 2008 9:44 AM
There was a kit for expanding the memory of the 400 to 48K, but it required soldering. Beyond that I don't know how much more the 400 could be expanded.
Tempest
#3 ClausB ONLINE
ClausB
  • 1,496 posts
Posted Sun Mar 23, 2008 10:53 AM
In 1982, the MACE Newsletter published my article, a DIY upgrade to 48K for the 400. It was later plagiarized by "The Windhover Project." You might find it on-line somewhere if you look.
If you're handy with solder, give it a try. If you can't find it, I can scan the article and post it.
Edited by ClausB, Sun Mar 23, 2008 10:54 AM.
#4 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Sun Mar 23, 2008 11:05 AM
Here ya go..
http://www.digitpres...hdocs/index.htm
http://www.a8maestro...ry/wpmem400.txt
#5 ClausB ONLINE
ClausB
  • 1,496 posts
Posted Sun Mar 23, 2008 11:30 AM
Here ya go..
Good search! The first link is a copy of the original with added comments. The second link is the rip-off.
I scanned the article anyway:
#6 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
  • It's easy living in a bubble
Posted Sun Mar 23, 2008 4:23 PM
would 41464 chips be usable?
#7 ClausB ONLINE
ClausB
  • 1,496 posts
Posted Sun Mar 23, 2008 4:37 PM
IIRC, those chips require an 8 bit refresh address, which the earlier ANTICs did not supply. You could add more circuitry to do the CAS before RAS refresh. Also, they are not pin-compatible with the RAM board sockets, so it would need much more work to use them.
#8 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
Posted Sun Mar 23, 2008 4:49 PM
thanks, I will have a look for some 4164s and make life easier :D
#9 ClausB ONLINE
ClausB
  • 1,496 posts
Posted Wed Mar 26, 2008 10:18 AM
I've read that Atari used to sell professionally-installed 48K upgrades for the 400. Does anyone have pictures or docs or schematics of this upgrade?
#10 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,013 posts
Posted Wed Mar 26, 2008 10:25 AM
Yes they did. I have one NIB but I never opened it. I can take pictures when I get a chance.
Tempest
#11 David_P OFFLINE
David_P
    Dragonstomper
  • 887 posts
Posted Wed Mar 26, 2008 7:31 PM
Brad Koda at Best may still have some in stock (http://www.best-electronics-ca.com/); alternatively, B&C Computervisions (http://www.myatari.com/) may also be able to set you up with a 48K board for the 400.
#12 UNIXcoffee928 OFFLINE
UNIXcoffee928
  • 1,177 posts
Posted Sun Jul 6, 2008 2:02 AM
Did anyone ever try these in an 800?
#13 Osgeld OFFLINE
Osgeld
  • 5,373 posts
Posted Sun Jun 11, 2017 2:26 PM
So I just did this and all appears to be well, question though the -5 volt supply looks to be a rather low powered rail, does anything else use -5 besides ram? cause otherwise I have been running this off of a DC power supply since the upgrade
Thanks!
#14 Paul Westphal OFFLINE
Paul Westphal
  • 1,268 posts
Posted Sun Jun 11, 2017 7:10 PM
Here is the wiring for the
Atari made 64k ram card ( yes, it says it on the card ). The 400 only sees 48k.image.jpeg
#15 Paul Westphal OFFLINE
Paul Westphal
  • 1,268 posts
Posted Sun Jun 11, 2017 7:11 PM
I have done about 8 of these.
#16 BillC OFFLINE
BillC
  • 1,791 posts
Posted Sun Jun 11, 2017 7:25 PM
Thanks!
The Sobola schematics show the power LED connected to the -5V circuit, it wouldn't be hard to change that.
#17 Osgeld OFFLINE
Osgeld
  • 5,373 posts
Posted Sun Jun 11, 2017 7:47 PM
Yea, that is the only other thing I saw in the schematics, just wanted to make sure I was not missing something, thanks
Atari made 64k ram card ( yes, it says it on the card ). The 400 only sees 48k.attachicon.gifimage.jpeg
good reference, I did the above method of converting a 16k card into a "48" k card cause I did not want to hunt down the upgrade kit, which generally cost more than the 10$ I paid for chips + extra's but it is more involved, and made me double and tripple check instructions while doing (my first)
#18 ACML OFFLINE
ACML
    Dragonstomper
  • 828 posts
Posted Mon Jun 12, 2017 8:03 AM
The Atari 400 48K RAM upgrade boards are getting hard to come by.  Best ran out of stock sometime in 2016.  Sadly, this is becoming a recurring theme.  I have a 400 with this upgrade, a B-Key keyboard and the 5200 S-video board that uses an Atari 5 pin DIN monitor jack.  Now it's the 800's equal in half the footprint.  It's a pure nostalgia thing for me.  The 400 was my first computer.  Very thankful that my father shelled out $400 (1981 dollars) for it.  That's like $1,200 today!  If you can find an Atari 48K board, jump on it.  There are a couple video upgrades for the 400 now and as far as keyboards, the B-Key seems to be the most available, but they too are hard to find in the wild.  I think we're in a surge of retro collecting and prices and availability have reflected this.
#19 JoSch OFFLINE
JoSch
    Moonsweeper
  • 440 posts
Posted Mon Jun 12, 2017 8:05 AM
I used ClausB's 400 expansion, which works very well.
#20 slx OFFLINE
slx
  • 1,443 posts
Posted Mon Jun 12, 2017 9:44 AM
Still waiting for a 400 Incognito board....but actually my 400 is waiting for some desk space to have its video upgraded and then get the Axlon card installed that ClausB provided me with a wiring for to use on the 400...
#21 chevymad OFFLINE
chevymad
    Chopper Commander
  • 107 posts
Posted Mon Dec 4, 2017 10:11 PM
Ok, I'm trying to do this upgrade and i've screwed up. I did the first part of the ram card modifications and swapped in 4564 ram from a working 800xl. Then tried the 400 and it worked fine as 16k. So I continued on with the rest of the mod and didn't see the skips in the alphabet for the edge pins. Ending up having a wire connected to pin P instead of M. Computer now boots to a black screen. I fixed the screwup and checked the rest of the routing. As far as I see everying looks correct now. Computer will still play star raiders too. Which chips have I fried???
#22 ClausB ONLINE
ClausB
  • 1,496 posts
Posted Tue Dec 5, 2017 7:53 AM
Was the wiring mistake on the RAM board or on the motherboard? If on the RAM then no damage done. If on the motherboard then two outputs (S3 and A14) were connected which could damage a chip or two.
Edited by ClausB, Tue Dec 5, 2017 8:24 AM.
#23 chevymad OFFLINE
chevymad
    Chopper Commander
  • 107 posts
Posted Tue Dec 5, 2017 8:36 PM
Mistake was on the ram board. So now I guess I need to go back through again and see if I can find any reason at all for a black screen. I noticed that your original instructions say to use 4164 ram chips, do the 4564's I used work? They seemed to be fine @ 16k level.
#24 BillC OFFLINE
BillC
  • 1,791 posts
Posted Tue Dec 5, 2017 10:20 PM
Part #s for the 64k x 1bit DRAM chips can change depending on the manufacturer, 4564 is the # Mostek used.
#25 chevymad OFFLINE
chevymad
    Chopper Commander
  • 107 posts
Posted Tue Dec 5, 2017 10:21 PM
Allright, I found my mistake and the computer is working again. Doesn't look like I fried anything, so far anyway. I made the exact same mistake on the motherboard, but only on one wire. The one that connects to pin M again I had going to P. I somehow managed to put the other wire correctly. Amazing how you can check and recheck your work and make the same mistake over and over again. Anyway, thanks for your help Claus and for creating this upgrade to begin with! :)
