Visual bB 1.0 - a new IDE for batari Basic
batari basic
666 replies to this topic
#301 kamakazi OFFLINE
kamakazi
    Dragonstomper
  • 530 posts
Posted Sun Feb 28, 2010 4:40 PM
So far, I'm enjoying Virtual bB. I also find the sprite editor very useful. Maybe I can create a 7800 project I had in mind for the 2600 first. This, combined with batariBASIC and Stella, are very good tools to have for 2600 development. I did learn upon compiling the sample.bas in batari that PCAE rejected the compiled results stating something like "END of READ REACHED." So, I don't recommend PCAE for testing code.
Another issue that I am having is on my project from scratch. It's probably something I have yet to learn about 2600 programming in general, but all I was wanting to do was design a simple sprite, put it on the screen and move it around a little. Upon compiling, there is no BIN file created, but there is also no error message given. Not sure what to do on this.
UPDATE: Nevermind about the scratch project. I figured it out.
Edited by kamakazi, Sun Feb 28, 2010 4:45 PM.
#302 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Sun Feb 28, 2010 4:52 PM
Looks like you figured it out, but in the future if you create a sprite you can actually right click "Preview in Emulator" and it will generate the code for a bin where you can move it around screen. Works the same for Playfields.
-Jeff
#303 devwebcl OFFLINE
devwebcl
    Dragonstomper
  • 992 posts
Posted Tue Mar 2, 2010 5:40 PM
with the version 550 if you try to open a file without having a project the IDE will crash showing the attached message.
in the version 526 it says that you need a project assigned to open a file.
#304 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Tue Mar 2, 2010 6:38 PM
Good catch, though I'm suprised it ever warned at all? The only code I see is a warning if the project root was selected, unless I deleted something. Fixed in the next release for sure.
Thanks!
Jeff
#305 yuppicide OFFLINE
yuppicide
    I am the Black Knight. Give me your money!
  • 6,933 posts
Posted Mon Mar 8, 2010 7:52 AM
Some ideas for VbB:
#1 In the program you can go to Help and bB Language Guide. This is really out dated. Can you update that? It's especially useful for losers like me who are late paying their Verizon FIOS bill and have no internet at home right now.
#2 Currently you have a graphics converter. It outputs the code down the screen. Example:
bitmap_00
	BYTE 000000
	BYTE 000000
	BYTE 000000
	BYTE 000000
 	... etc etc.
bitmap_01
	BYTE 000000
	BYTE 001111
	BYTE 011111
	BYTE 111111
	BYTE 111111
 	... etc etc.
end
How about an option to line up the code as it would be on the screen, in a format like this:
0000000000000000
0000000000001111
0000000000011111
0000000000111111
0000000000111111
.. or however.. this would draw the image you converted in all 1's and 0's. Then I can go in and edit those, hit a button and it will reoutput the ASM code for me. ... maybe it'll open the picture in a playfield editor like thing or maybe it'll open just numbers.
You get my idea what I want to do here? Let's say the conversion is basically pretty nice except for a small blemish here and there. I can easily edit it. I understand that maybe I should be opening a graphic editor and fixing my files there, but to make VbB a more complete development studio I think it would be a nice option. I don't always feel like firing up GiMP (free graphic editor similar to Adobe Photoshop), especially at work because my the computer is slow.
#306 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Mon Mar 8, 2010 10:02 AM
Some ideas for VbB:
The good news is you can fix this yourself. Right now it defaults to loading the manual.html stored in <bb folder>\manual\. Save this link locally from RT's site. If you delete that file it will try to go grab the online copy. I should probably default to the online copy and use the local copy if the internet is not available...
bitmap_00
	BYTE 000000
	BYTE 000000
	BYTE 000000
	BYTE 000000
 	... etc etc.
bitmap_01
	BYTE 000000
	BYTE 001111
	BYTE 011111
	BYTE 111111
	BYTE 111111
 	... etc etc.
end
0000000000000000
0000000000001111
0000000000011111
0000000000111111
0000000000111111
It's a good idea, but right now once you convert to text there is no way to go back to generating the assembly. I'll have to look at the code it might be easier for me to import binary and generate the assembly equivalent.
-Jeff
#307 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Mar 8, 2010 2:35 PM
... or maybe a simple editor built into the IMG to CODE program? Maybe have that program be able to open in full screen, have a larger preview (resizable?) and some simple editing tools.
#308 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Mon Mar 8, 2010 5:19 PM
A mini-graphics editor? You over estimate my graphics skills ;) I think I came up with a good alternative though. I'll send you a PM later that you can test out.
-Jeff
#309 devwebcl OFFLINE
devwebcl
    Dragonstomper
  • 992 posts
Posted Tue Mar 9, 2010 6:27 PM
A little suggestion for VbB is to be able to move the tabs, just like Firefox does today.
Devwebcl
#310 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Tue Mar 9, 2010 8:29 PM
Devwebcl
Great idea. I don't know why I didn't implement that before because it only took about 5 minutes to implement, though I don't have the fancy preview you see with Firefox. This will be in the next release.
Thanks,
Jeff
#311 Cliff Friedel OFFLINE
Cliff Friedel
    Dragonstomper
  • 601 posts
Posted Thu Mar 11, 2010 11:58 AM
Hi. Getting this when I am trying to run the music and sound editor from VbB 1.50. Made sure I have NET 2.0 and NET 3.0 installed. Everything else from VbB seems to be working ok. Any ideas what could be causing this? I would appreciate any help. Thanks.
Cliff
Long Version of the error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileLoadException: Could not load file or assembly 'irrKlang.NET2.0, Version=1.1.3.0, Culture=neutral, PublicKeyToken=a854741bd80517c7' or one of its dependencies. This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem. (Exception from HRESULT: 0x800736B1)
File name: 'irrKlang.NET2.0, Version=1.1.3.0, Culture=neutral, PublicKeyToken=a854741bd80517c7' ---> System.Runtime.InteropServices.COMException (0x800736B1): This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem. (Exception from HRESULT: 0x800736B1)
at VisualbB.SoundLib.vbBSoundLib..ctor()
at VisualbB.DialogMusic..ctor()
at VisualbB.mainIDE.MusicEditorToolStripMenuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
VisualbB
Assembly Version: 1.0.0.550
Win32 Version: 1.0.0.550
CodeBase: file:///C:/A2600Development/VisualbB.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
VisualbB.SoundLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/A2600Development/VisualbB.SoundLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
#312 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Thu Mar 11, 2010 1:40 PM
Cliff
   at System.Windows.Forms.ToolStripMenuItem.onclick(EventArgs e)
   at System.Windows.Forms.ToolStrip.onmouseup(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.onmouseup(MouseEventArgs mea)
   at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
   at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
VisualbB
System
System.Drawing
System.Xml
VisualbB.SoundLib
enabled.
For example:
<configuration>
</configuration>
Make sure you download BOTH zip files and extract them to the SAME folder. In a nutshell it can't find one of the required .dlls.
-Jeff
#313 devwebcl OFFLINE
devwebcl
    Dragonstomper
  • 992 posts
Posted Thu Mar 11, 2010 6:00 PM
Devwebcl
Thanks,
Jeff
Good to hear that.
Also I found out that after the VbB found a Syntax error, it makes bold and red the font of that particular line of code with problem, but after I fix it and re-build the program (and works) still it is red & bold.
#314 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Thu Mar 11, 2010 6:36 PM
Devwebcl
Thanks,
Jeff
Good to hear that.
Yeah unfortunately the syntax editor is not that sophisticated. Hitting <Enter> at the end of the line will force it to re-check the syntax of that line and if the error is gone it will reset the formatting back to normal.
-Jeff
#315 Cliff Friedel OFFLINE
Cliff Friedel
    Dragonstomper
  • 601 posts
Posted Thu Mar 11, 2010 9:04 PM
Cliff
mscorlib
VisualbB
System
System.Drawing
System.Xml
VisualbB.SoundLib
enabled.
For example:
<configuration>
</configuration>
-Jeff
Thought I did that, but I will try again. Thanks.
#316 Cliff Friedel OFFLINE
Cliff Friedel
    Dragonstomper
  • 601 posts
Posted Thu Mar 11, 2010 9:28 PM
Verified that both files have been downloaded and installed. Verified that the DLLs are in the same directory as VbB and that it can run, but still getting the same error. Also ran the configuration editor and made sure that Net 2.0 and 3.0 were installed. Is there anything else I can look at? Thanks.
#317 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Thu Mar 11, 2010 11:32 PM
Can you post what is in your visualbB folder? I still think you are missing a file.
-Jeff
#318 devwebcl OFFLINE
devwebcl
    Dragonstomper
  • 992 posts
Posted Fri Mar 12, 2010 6:35 AM
-Jeff
Great, that does it.
Thanks.
Devwebcl
#319 Cliff Friedel OFFLINE
Cliff Friedel
    Dragonstomper
  • 601 posts
Posted Fri Mar 12, 2010 12:41 PM
-Jeff
Here is a snapshot of my directory.
If it helps, I am running this in a virtualbox that is running windows XP. Not sure that would cause any issues, but I figured I would add it just in case. Everything else seems to work ok from it. Thanks.
#320 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Fri Mar 12, 2010 4:37 PM
-Jeff
"I am running this in a virtualbox that is running windows XP" - I've never tested it under VirtualBox. I recommend copying your folder to a physical machine and see if it works. If so, I think you found your issue.
-Jeff
#321 devwebcl OFFLINE
devwebcl
    Dragonstomper
  • 992 posts
Posted Sun Mar 14, 2010 9:47 AM
Every time that I want to compile I choose the pull-down button to choose between standard or custom batch file.
Could you implement to remember the last option I choose when I press the compile button? so I don't have to choose between those two options every time, only the first time.
Thanks a lot for all the answers :)
Cheers,
Devwebcl
Edited by devwebcl, Sun Mar 14, 2010 9:48 AM.
#322 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Sun Mar 14, 2010 11:54 AM
Cheers,
Devwebcl
Sure, I can make the tool strip compile button remember your last compile option.
-Jeff
#323 MausGames OFFLINE
MausGames
    Dragonstomper
  • 894 posts
Posted Sun Mar 21, 2010 2:04 AM
I decided to try the newest build today, not working out well so far. I'm using 550 with Vista; Anytime I try to go to the end of a line of code and press enter to insert a blank line, I get:
"Unhandled exception has occured in your application. If you click...", "Cannot access a disposed object. Object name: 'RichTextBox'." Going back to 536 for now.
#324 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 26,922 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sun Mar 21, 2010 2:31 AM
Weird. I have Vista and it's working for me.
#325 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Sun Mar 21, 2010 2:50 AM
I'm using Vista - working fine for me? anything else in your code that would be special?
-Jeff
Also tagged with one or more of these keywords: batari basic
