Atari 8-bit IRC client: FujiChat (0.3 released)
54 replies to this topic
#1 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Fri Nov 7, 2008 4:51 PM
Guess it's time to open up the alpha-testing to the public...
FujiChat is a simple IRC (Internet Relay Chat) client for Atari 8-bit (400/800/XL/XE) computers, based on the uIP TCP/IP stack (by Adam Dunkels). It uses a SLIP connection to talk to the outside world, and supports a subset of the IRC commands available in full-featured clients. 48K of memory is required (and extended memory is not used, so it can coexist with RAMdisk drivers and such).
Download binary, source, and documentation: http://rogue3.homeip...y/fujichat.html
Be aware that this version is mostly just a proof-of-concept. It's pretty functional as a no-frills IRC client, but *slow*, and doesn't even support DNS yet (connect to server IP addresses only, there's a short list built into the program), and you can only join one channel at a time (private messages do work though). Also, it's got the Bob-Verter R: handler hard-wired into it right now (works with R-Verter or an SIO2PC only). The SLIP setup is fairly complex, and I've only written instructions for connecting to a Linux host (it should be possible to use SLIP on Windows with either "Direct Cable Connection" or SLIrP + Cygwin, but I've no experience with either). If anyone gets the SLIP stuff working on any other OS than Linux, I'd be very interested in adding to the documentation.
The 0.1 version is known not to work with the FreeNode IRC network, BTW. It works OK with NewNet, Undernet, and EFnet.
Anyway, all disclaimers and caveats aside... your Atari can now have an IP address! Stop by the #atari channel on NewNet (using any of the built-in server IPs) once you get everything set up, I'd love to hear from you!
update: 0.2 released, 2008-11-13
update: 0.3 released, 2008-11-16
Edited by Urchlay, Sun Nov 16, 2008 3:25 AM.
#2 pepax OFFLINE
pepax
    Moonsweeper
  • 305 posts
Posted Sat Nov 8, 2008 6:50 AM
Cool!!!!!!
#3 Beetle OFFLINE
Beetle
    Dragonstomper
  • 515 posts
  • Atarian at 8, 16, 32 and 64 Bits
Posted Sat Nov 8, 2008 2:19 PM
Hi atarians,
It works really nice already. Much more than a 'proof of concept', Urchlay!
I played around with it and in my opinion 40 chars per line is not so convincing.
I was happy to see that Fujichat is compatible with SDX's CON64 and CON80 (software 64 and 80 columns)
as well as with Atari XEP80.
64 characters per line
80 characters per line
80 characters per line, by XEP-80
Don't fear a bit of configuration work on a Linux Box - its worth it!
I also heard Urchlay is looking for a way to connect via SLIP to
PCs with Windows installed, too.
#4 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Sat Nov 8, 2008 7:43 PM
Thanks... but I won't consider it a "real" client until it's as easy to use as something like irssi or rhapsody. Still got a ways to go...
Now *that* is good news!
At some point FujiChat will have to include its own 80-column (or whatever) driver, but it's good to know it'll already work with something other than plain old GR.0.
Can I borrow your screenshots for the FujiChat web page, when I get ready to make a real page for it?
#5 Beetle OFFLINE
Beetle
    Dragonstomper
  • 515 posts
Posted Sat Nov 8, 2008 7:49 PM
Sure, go ahead!
#6 Velcro_SP OFFLINE
Velcro_SP
    Chopper Commander
  • 132 posts
Posted Mon Nov 10, 2008 5:02 AM
Amazing and very very cool! Looks great! The 80 column looks great and I think the 40 column looks great too! Way to go Urchlay!
#7 danwinslow OFFLINE
danwinslow
  • 2,593 posts
Posted Mon Nov 10, 2008 7:31 AM
Amazing. Really good work.
#8 a8isa1 OFFLINE
a8isa1
  • 1,564 posts
Posted Tue Nov 11, 2008 3:43 PM
Works fine with my ATR8000.
- Steve Sheppard
#9 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Tue Nov 11, 2008 3:47 PM
Nice.
Does the ATR8000 and your cable have all the hardware handshaking lines hooked up? If so, can you try it with the unpatched version of slattach and let me know if it works?
That's actually pretty important for e.g. Windows users: it's probably possible to get Windows to do SLIP, but not possible to grab the source to its SLIP driver, patch, and recompile :)
#10 a8isa1 OFFLINE
a8isa1
  • 1,564 posts
Posted Tue Nov 11, 2008 5:20 PM
Nice.
Sorry. No can do.
My "null modem" is just quick hack. All I had to work with is a RJ11 to DE9 adaptor that is configured to be the PC end of my enternal SIO2PC. As a null modem I have only TX, RX, and ground. I can't modify it. The DE9 end uses insertion pins and I lost my extractor tool.
- Steve Sheppard
Edited by a8isa1, Tue Nov 11, 2008 5:27 PM.
#11 Beetle OFFLINE
Beetle
    Dragonstomper
  • 515 posts
Posted Tue Nov 11, 2008 6:56 PM
I'll try to get my BlackBox RS232 wired just for testing this. It should have all lines there.
#12 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Thu Nov 13, 2008 10:39 PM
FujiChat 0.2 has been released. It's still "alpha" quality, but there are some new features:
- DNS support. No more typing server IP addresses
- Local and peer IP addresses are now configurable from within the program instead of hard-coded
- FujiChat now works with FreeNode IRC servers
- Can now exit to DOS after disconnecting from server, instead of having to reboot
- Miscellaneous stuff (visual bell, message beep, ...)
#13 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Sun Nov 16, 2008 3:28 AM
FujiChat 0.3 has been released. The major update in this version is that DNS is much more reliable.
Also the UI has been improved a bit.
See http://rogue3.homeip...chlay/ChangeLog for details, http://rogue3.homeip...y/fujichat.html for downloads & docs.
#14 atarixle OFFLINE
atarixle
    Moonsweeper
  • 316 posts
Posted Sun Nov 16, 2008 9:13 AM
this is so cool ... only thing we need now is a ethernet2serial adapter ... at the moment this is still my (virtual) linux box, so the hardware-effort is still the same at the moment as when I use the atari as a dumb terminal to get to the net
but anyway, to see the atari8 doing the TCP/IP and IRC is so damn cool and fun too! great work!
#15 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Sun Nov 16, 2008 12:04 PM
...or PBI ethernet? Or something like the USB cart with a USB Ethernet adaptor... All of these are possibilities. uIP already can handle Ethernet of course, I'd just need to write a glue layer to shuffle Ethernet frames between the hardware and uIP stack.
Danke! TCP/IP and IRC on the Atari has been my "holy grail" for a couple of years now. It feels good to be getting something done... but it still needs a lot of work before it can replace the fancy clients like irssi or mirc.
#16 David_P OFFLINE
David_P
    Dragonstomper
  • 939 posts
Posted Sun Nov 16, 2008 2:40 PM
There are already threads on AA discussing Ethernet on a cart - on the PBI would be another option. There are Ethernet interfaces designed to interface with 8-bit systems - see http://microcontroll...roducts_id=1202. Perhaps we need to define a hardware standard for the Atari 8-bit - that will provide HW and SW developers with standards to address, vice everyone doing thier own thing and further fragmenting the market.
I also seem to recall a "Project ICE - Internet Connectivity for Eight-bits"; I think that page may still be online, with source code available.
#17 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Mon Nov 17, 2008 2:31 PM
I've had great fun getting this running, working great with an Atari 850 interface!
#18 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Mon Nov 17, 2008 6:37 PM
Those of you who have tried it, probably noticed FujiChat 0.3 doesn't work with most (all?) 80-column software drivers...
I'm trying to optimize RAM usage to fix this... if anyone using a Black Box, MIO, P:R: connection, or any other device with an RS232 port could tell me the value of MEMLO with the R: handler booted, I'd be much obliged.
To do this, boot BASIC with your R: driver loaded, then:
? PEEK(743)+256*PEEK(744)
I've already got numbers for the Bob-verter, ATR8000, and Atari 850 drivers, just need to make sure there's nothing weird about any of the others.
Also, it'd be helpful to know the MEMTOP numbers for the various 80-column drivers (SDX's con80/con64, ACE-80, Omniview-80, Bit3 if anyone's got one). I suspect the XEP-80 loads low, so MEMLO would be the important number for that one.
To get MEMTOP:
? PEEK(741)+256*PEEK(742)
(actually, FujiChat runs with BASIC disabled, so the true MEMTOP would be 8K higher)
I've decided against using anything like a custom display list for the chat display, and I really don't want to get sidetracked trying to write my own 80-column driver (especially since so many good ones already exist).
Basically the plan is to move the whole program down as low as possible in RAM, including using the tape buffer, page 6, everything I can without stepping on DOS or the R: driver... and use high RAM for a scrollback buffer (dynamically sized depending on MEMTOP, 80-column software drivers using GR.8 might not get any scrollback at all).
#19 Beetle OFFLINE
Beetle
    Dragonstomper
  • 515 posts
Posted Sat Nov 22, 2008 5:01 PM
Hi atarians,
using this modified script for the linux host,
i am able to onnect two Ataris using SIO2PC and FujiChat.
Perhaps it is of use to someone.
#!/bin/sh
modprobe slip &> /dev/null
ifconfig sl0 down &> /dev/null
ifconfig sl1 down &> /dev/null
a8_slattach -L -p slip -s 9600 /dev/ttyS0 &
sleep 1
a8_slattach -L -p slip -s 9600 /dev/ttyS1 &
sleep 1
ifconfig sl0 192.168.10.1 pointopoint 192.168.10.2
ifconfig sl1 192.168.11.1 pointopoint 192.168.11.2
ifconfig sl0 mtu 576
ifconfig sl1 mtu 576
echo "1" > /proc/sys/net/ipv4/ip_forward
iptables -t nat -F
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
#20 Urchlay OFFLINE
Urchlay
  • 1,161 posts
Posted Sat Nov 22, 2008 7:36 PM
Ah, you got it working, nice.
For those of you using Windows, I found a set of directions on setting up XP to do SLIP:
http://www.sics.se/~...s/slipintro.pdf
After setting up SLIP, you'd need to also have the XP machine do NAT (aka "Internet Connection Sharing" in Windows-speak), or else you need to add a static route to your router for the newly-created SLIP network (not sure if the consumer-oriented D-LinkSysGear type stuff even has a way to add a static route though). According to Microsoft's web site, Vista has dropped SLIP (aka "Direct Cable Connection") support.
If anyone does get FujiChat working with Windows (any version), I'm really interested in including a good set of instructions with FujiChat.
#21 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Sun Nov 23, 2008 5:31 PM
Here is a quick video I made of Fujichat v 0.3, booted from an Atarimax 1mb flashcart.
I thought maybe some folks that dont have hardware might like to have a look.
Charlie
#22 Beetle OFFLINE
Beetle
    Dragonstomper
  • 515 posts
Posted Mon Nov 24, 2008 12:54 PM
I tried SDX with CON64 and CON80 again. FujiiChat 0.4 still works with them. They use only RAM under OS or even banked RAM.
#23 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Sat Dec 20, 2008 5:57 PM
I've been able to get the atari800 emulator r: device connected to a real serial port working very well today.
I'm even able to run FujiChat in emulation.
Check out the screen shot of Fujichat running in an atari800 curses-only emulation. I'm only using this mode because the serial port I needed to use is on a box with no monitor. But you should be able to run in a full blown x11 mode. This mode is cool though.
The other "Getting the Atari Online" thread got me playing with atari800 r: emulation.. and what do you know, it works!
Charlie
#24 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Mon Dec 22, 2008 11:15 AM
Allright I've improved the process a bit. Thanks to this project,
http://www.ant.uni-b...inas/nullmodem/
you can use a virtual null modem to connect:
1. to the atari800 r: device configured to connect to a real serial port. Also must edit the source so it will use the serial port the nullmodem prjoect creates for you, I used /tmp/loop0.
2. to the sl0 slip interface. I used /tmp/loop1.
Bam! Fujichat in an emulator with no need for real serial ports or cables. All you really need is a linux box with SLIP support in the kernel.
Charlie
#25 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Mon Dec 22, 2008 12:06 PM
Figured a screen shot would be nice. Running in x11 mode here too.
Charlie
