PFonck Posted September 20, 2002 Share Posted September 20, 2002 The traces on my 600XL's mainboard look awfull, but they seem to be solid, as in not chipping from the board. Is this normal/often seen on 600XL mainboards? (it's not about the two wires) Quote Link to comment Share on other sites More sharing options...
classics Posted September 25, 2002 Share Posted September 25, 2002 If you scrape a little off you should see the copper trace under it is still well attached to the fiberglass. Someone once told me the exact reason so many Ataris have this... something about the mask not being applied at the right step in PCB fabrication, or not being rated high enough for the temperature of the solder bath. Quote Link to comment Share on other sites More sharing options...
