Atari 5200 Analogue Controller Repair
Atari Richie
By Atari Richie
(Disclaimer)
This is a guide of what I have done, I don’t know about the longevity of the repair; however the process can be repeated again and again... I cannot be held responsible for any problems that may arise as part of the repair process or any unforeseen reactions or damages from any of the chemicals and equipment used. Always read the Directions, Instructions and Safety Information of any equipment and chemicals you use. I have used this method many times to repair remote controls etc... Without any problems however you don’t bang the buttons when playing space invaders for hours on end, But the process works every time. I have repaired all my broken 5200 controllers using this method and they are all still working.
(End of Declaimer)
What you need:-
Dysfunctional Controller (sometimes can be hard to find one)
High Quality Cotton buds
Contact Cleaner
Screwdriver
Craft knife
Circuitworks Conductive Pen or similar Silver Conductive Paint
(note that if the instructions of the product you use state a drying time greater than 1 hour don’t use it as it’s not going to be solvent based and will give very poor results)
1.
Remove the Start Pause Restart button surround with a craft knife. Insert the knife and use it to lever up the surround.
Lift the Flex circuit up out of the way (sometimes this may have been stuck down)
2.
Remove the 3 screws on the back of the controller.
3.
Split the controller in 2 from the front first as shown (There are two plastic lugs that locate the parts together, be careful and don’t break them).
Pic of the Plastic Lugs:-
4.
The fire buttons slide out with their plastic surrounds.
5.
Clean the flex circuit with the contact cleaner, buy spraying the cotton bud first and then using it to clean the flex circuit contact points.
6.
Clean the button contacts with the contact cleaner, buy spraying the cotton bud first and then using it to clean the carbon contact points.
Leave to dry for 10min
(Be careful not to touch the black dots with your fingers after cleaning as the oil in your skin with stop the silver paint from sticking to the surface).
7.
Now apply the Conductive Pant Pen to all the carbon contact points, note this is not very easily done, I would practice a few times first. If you use the pen it works just like a Tip-ex pen or any other type of corrective pen. You just need to squeeze the pen and push the tip in to allow the paint to flow out. Lift the pen up and down while doing this and paint the surfaces as evenly as possible.
Now leave to dry for 30-45 min. (don’t touch the paint to see if it’s dry, the surface needs to be clan and free of grease)
8.
To reassemble the control is just the opposite of taking it apart, however a good tip would be to check the analogue joystick parts are aliened as shown below, so when you press both half’s together centring the joystick handle then it should be aligned perfectly, though I just give it a wiggle and check it feels right, before you screw it all back together.
And that’s it...
Thanks for looking and I hope it helps someone to enjoy their 5200 with the original controls as nature intended...
Richie :D
  • Like 4
Nice use of the pen--I gotta try that. As many things as I've read about repairing the 5200 controller with new parts or tin foil or whatever, I don't think I've seen this before.
Does it seem to last pretty well?
edit: This has gotta be the best presentation and pics of opening the 5200 controller I've seen.
Edited by brojamfootball
I have used this method many times to repair remote controls etc... With one of my 5200 controllers I played with if for around 12 hours since the repair, and have had no problems. Though if this method was found not to last it’s really easy and quick just to re-apply some more paint. I have noticed a big difference compared with original controllers that I have not needed to fix. It seems that this repair may make the contacts much more responsive than the original Carbon Contact Pads. I plugging in a controller that has never before been used just to see and you have to press the buttons harder on the original than you do with the repair.
And thanks for complement :cool:
Richie
Have you tryied it on earlyer reflex like rev 6 or 7? I have afew of them
Thanks
I only have tried the process on the ones that are made in Taiwan so don’t know I am afraid, but I would think that the problems still lies with the carbon contacts on the buttons.
The cool thing about these pens is that you can draw circuits with them so in theory if the flex circuits contacts were lifting off you could put a little dap on the offending part and use it as glue. Or repair any brakes in the flex circuit board.
  • 4 weeks later...
hmm i wouldnt call this analogue controller repair i would call it "atari 5200 controller button repair"
OMG how pedantic are you?
Don't mind him. He takes his 5200 controllers very seriously. He builds them just like a few of us on here do. Nice article. This will help those guys who are low on the technical side for sure. :thumbsup:
BTW: The flex circuits functionability really plays a part in this. Some flex circuits won't be able to be repaired regardless. Especially the white and blue ones. Not to fear though because those were not used to much.
I wouldn't call that pedantic, I was thinking the same thing as well because of your subject title. It's a tutorial on repairing the buttons on the controller, not the actual analog stick. When people refer to a controller being analog vs. digital, they're referring to the actual controlling mechanism - the stick. Nice tutorial either way, but not what was expected.
  • 2 weeks later...
Very Nice.
I used a similiar method, but I used what was called a "Rubber keypad repair kit", which I either bought from DigiKey or Mouser Electronics. it was a Two part mix, much like an epoxy and once it was mixed, you applied it to the rubber silicone dots to improve conductivity. I did it on all four of my 5200 controllers and works well.
  • 7 months later...
Very Nice.
I used a similar method, but I used what was called a "Rubber keypad repair kit", which I either bought from DigiKey or Mouser Electronics. it was a Two part mix, much like an epoxy and once it was mixed, you applied it to the rubber silicone dots to improve conductivity. I did it on all four of my 5200 controllers and works well.
Awesome. I didn't know these things existed. Another alternative is graphite lubricate. It is an EXTREMELY fine graphite powder. I used this a long time ago. It has a nozzle, similar to a glue bottle, and it comes out in little 'puffs'. I used this very sparingly, as to not leave excess residue behind. Next, I used a q-tip to rub it into the rubber, while removing excess. My 5200's have been in and out of storage, in many different climates over the years, and this has held up quite nicely. There's also no drying time.
Sounds like they are all pretty innovative solutions here. If my graphite ever wears out, I wouldn't mind trying the more glue-like solutions. However, this powder has surprisingly stood the test of time.
Woah, I must have missed this last year. Here's a pen on the Internet pretty cheap. Sounds a lot easier than the other concept of gluing aluminum foil or similar onto the buttons. Just make sure you shake the pen well to get the silver mixed in. I may try that. I think I need to replace the flex circuits though with the Rev. 9 from Best, I just have been dilly dallying, compiling a list of other things I need from them before ordering (2600 stick/paddle parts).
  • 7 months later...
So you do need to put conductive paint on the little carbon contacts? Ahh. I don't have that on neither of my controllers. It's all black! Looks like I'll need to hit Radio Shack & paint the buttons.
Last weekend I picked up a CV + got a much-needed 5200 controller that didn't work either. Only 3 buttons on the numeric keypad work. I was under the assumption no conductive paint on the buttons was needed.
Right now I have 2 controllers: A real sorry Rev 7 controller with no top 3 button rubbers, nor the CV joint boot. With no cv joint boot, I have zero luck getting it back together.
The Rev 9 stick I recently got has all the parts, and shows some signs of life.
  • 4 years later...
Look at that! How in the world does the start, pause and reset buttons work when its wrinkled like that!
Yet both left fire bottons dont work. Wtf!
I would imagine that happened while trying to stuff the matrix in without having removed the start / pause / reset bezel first
wouldn't know how to get it nice & flat again but should lay sort of flat once re-assembled .... can get NOS parts here http://www.best-electronics-ca.com/cx52_j.htm#CX52
you're conductive paint should work fine , I've used some to repair broken traces inside "The Space Age" controller
