carmel_andrews Posted December 17, 2009 Share Posted December 17, 2009 How is the Lemmy coming on Claus Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 6, 2010 Share Posted January 6, 2010 Slow, but sure... Bob How is the Lemmy coming on Claus Quote Link to comment Share on other sites More sharing options...
+warerat Posted January 6, 2010 Share Posted January 6, 2010 I researched a bit on the Web and saw some things about the Xilinx Digital Clock Manager core and about Digital Locked Loops, but I could not find enough details to see if such a thing would fit into our smallish CPLD. Do you have details to share? Thought about this today doing while doing some work with a dev board I have with an older Spartan 3 (XC3S1000, 1.8V core, 3.3V tolerant) that has four internal DCMs. I wired up a 3.3V buffer (74LVC244) and fed PHI2 into it and configured one of the DCMs to do CLKx16 (there's a minimum output frequency). From there I made some internal /4 and /8 counters to get the 7.16MHz and 3.58 MHz clocks. It wouldn't be any problem generating 14.318 if necessary either. The acquisition board in my HP logic analyzer only has a resolution of 10ns but it looks like the delay between the generated clocks and PHI2 is somewhere between 20ns-30ns. The buffer adds about 8-10ns, and I don't have PHI2 going into a dedicated clock port on the FPGA which would also factor in. This particular FPGA is a 4ns part. The smallest newer generation device that is flash is a XC3S50AN and is under $10. Those come with two DCMs inside. It's probably not much help if you're planning on going forward with the Atmel part, but I'd just thought I'd show you the result in a Xilinx part using the DCM for one of purposes they were designed for. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 6, 2010 Share Posted January 6, 2010 Very nice... These things (DCMs) are part of the hardware or you have an image that you load? The bulk of what we (I) do is built into GALs and CPLDs - re-programming the Atari PAL and such. Small projects that work well under CUPL/ATMEL hardware. When something larger comes along that needs to scale up, it is more efficient to carry along the same tools/protocol as used in normal projects, rather than move into another line. If we did a lot of large projects or exclusively large projects, it would change our selection criteria. For now, we need small GAL/PAL support. Bob I researched a bit on the Web and saw some things about the Xilinx Digital Clock Manager core and about Digital Locked Loops, but I could not find enough details to see if such a thing would fit into our smallish CPLD. Do you have details to share? Thought about this today doing while doing some work with a dev board I have with an older Spartan 3 (XC3S1000, 1.8V core, 3.3V tolerant) that has four internal DCMs. I wired up a 3.3V buffer (74LVC244) and fed PHI2 into it and configured one of the DCMs to do CLKx16 (there's a minimum output frequency). From there I made some internal /4 and /8 counters to get the 7.16MHz and 3.58 MHz clocks. It wouldn't be any problem generating 14.318 if necessary either. The acquisition board in my HP logic analyzer only has a resolution of 10ns but it looks like the delay between the generated clocks and PHI2 is somewhere between 20ns-30ns. The buffer adds about 8-10ns, and I don't have PHI2 going into a dedicated clock port on the FPGA which would also factor in. This particular FPGA is a 4ns part. The smallest newer generation device that is flash is a XC3S50AN and is under $10. Those come with two DCMs inside. It's probably not much help if you're planning on going forward with the Atmel part, but I'd just thought I'd show you the result in a Xilinx part using the DCM for one of purposes they were designed for. Quote Link to comment Share on other sites More sharing options...
+warerat Posted January 6, 2010 Share Posted January 6, 2010 The DCM is physical hardware that is part of the die. Picture a square-- the perimeter has the interconnect matrix to connect the I/O pins to the logic blocks and LUTs on the interior and the DCMs would be on the corners. To use one you have to instantiate one in a way that so when your definition is "compiled" the synthesizer knows you're referring to a primitive that is native to the device. This is done either with a VHDL/Verilog template or by generating one using the IP core tools that provide GUIs about which features and clock dividers/multipliers you want. Quote Link to comment Share on other sites More sharing options...
ClausB Posted January 9, 2010 Author Share Posted January 9, 2010 I don't know much about interfacing 3.3V logic with 5V systems. Are buffers necessary? Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 10, 2010 Share Posted January 10, 2010 Good question... not sure. I think you can drive a 5v IC with a 3.3v chip, but not the other way around. TTL may not exceed the 3.3v input limit, but CMOS will. On the large ATMEL CPLDs, you can set the outputs to 3.3v or 5v, so they can be run in a 3.3v system. Bob I don't know much about interfacing 3.3V logic with 5V systems. Are buffers necessary? Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted January 10, 2010 Share Posted January 10, 2010 that board looks a bit big for a standard size cart Quote Link to comment Share on other sites More sharing options...
+warerat Posted January 11, 2010 Share Posted January 11, 2010 Good question... not sure. I think you can drive a 5v IC with a 3.3v chip, but not the other way around. TTL may not exceed the 3.3v input limit, but CMOS will. On the large ATMEL CPLDs, you can set the outputs to 3.3v or 5v, so they can be run in a 3.3v system. Bob I don't know much about interfacing 3.3V logic with 5V systems. Are buffers necessary? For this particular part, yes, I have to drive at 3.3V as the FPGA is not 5V tolerant. If I interfaced it directly, I can kiss that $50 FPGA IC goodbye. You can drive 5V TTL logic with 3.3V LVTTL, but not always the other way around. The CPLD family I use for largish designs is XC9500XL-- they run at 3.3V core but are 5V tolerant. Unfortunately as time goes on there seem to be less parts (excluding legacy SPLD/CPLD) that are 5V tolerant. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 11, 2010 Share Posted January 11, 2010 For now, the circuits will be on a flat cable that plugs into the cart port. Down the road, we may cram it all in a cart - maybe a longish one. Bob that board looks a bit big for a standard size cart Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted January 11, 2010 Share Posted January 11, 2010 would adding a dual antic (your previous upgrade) on the upgrade improve things further (more colours/colors and more PMs/sprites etc) Something like that would be well cool and a decent competitor to the vbxe thing, whilst keeping faith with atari tech... Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 14, 2010 Share Posted January 14, 2010 Well... You could output two (or four) 'frames' that would simulate a dual (or quad) ANTIC, but only by adding a lot of complexity. LEM is a minimal, but elegant, hack. Bob would adding a dual antic (your previous upgrade) on the upgrade improve things further (more colours/colors and more PMs/sprites etc) Something like that would be well cool and a decent competitor to the vbxe thing, whilst keeping faith with atari tech... Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 15, 2010 Share Posted January 15, 2010 Can you post the .PLD file? I'll add the pinnodes and define some triggers and latches. Make some video! Bob I have filled in the I/O pins that we know about. The pin assignment also takes care of the active level for the signal - a ! denotes NOT, so !S4 means S4 is active at a zero level. In the equations and such, all you will see is S4 that denotes S4 Active. (even thogh it's a zero level in the hardware) !S4 in the equations section means S4 is Not Active - OK? MAxx are the addresses going to the memory chip from the CPLD. Axx would be an address from the cart socket. MCS is MemoryChipSelect and MWE is MemoryWriteEnable. I tried to keep all the Atari signal names the same as we see them in the Atari documentation. The field to the right of each line is a comment field. Good thing to have if you're going to make something complex. OK. So, combining my pseudocode with your syntax gives us: Name LEM ; PartNo 00 ; Date 12/11/2009 ; Revision 01 ; Designer Claus B. & Bob W.; Company Atari Rulz!! ; Assembly None ; Location ; Device f1504plcc44 ; /* *************** INPUT PINS *********************/ PIN 06 = !S4 ; /* Pages 80-9F select, active low (cart pin 1 and SRAM enable) */ PIN 11 = D4 ; /* Data bus */ PIN 12 = D5 ; /* */ PIN 13 = D2 ; /* */ PIN 14 = D1 ; /* */ PIN 16 = D3 ; /* */ PIN 17 = D7 ; /* */ PIN 18 = D0 ; /* */ PIN 21 = D6 ; /* */ PIN 25 = R/W ; /* Read not Write (cart pin R) */ PIN 26 = !CCTL ; /* Page D5 select, active low (cart pin 15) */ PIN 27 = B02 ; /* Bus clock (cart pin S) */ PIN ?? = B02D ; /* Bus clock thru 140 ns delay */ PIN ?? = C02D ; /* Doubled clock thru 70 ns delay */ PIN = ; /* */ PIN = ; /* */ PIN = ; /* */ PIN = ; /* */ PIN = ; /* */ /* *************** OUTPUT PINS *********************/ PIN ?? = MA13 ; /* SRAM upper address */ PIN ?? = MA14 ; /* */ PIN ?? = MA15 ; /* */ PIN ?? = MA16 ; /* */ PIN 09 = !MWE ; /* SRAM Write Enable, active low */ PIN ?? = C02 ; /* Doubled clock to 70 ns delay */ PIN ?? = LUM0 ; /* Luma outputs */ PIN ?? = LUM1 ; /* */ PIN ?? = LUM2 ; /* */ PIN ?? = LUM3 ; /* */ PIN = ; /* */ PIN = ; /* */ PIN = ; /* */ PIN = ; /* */ PIN = ; /* */ /* *************** PINNODES *********************/ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ PINNODE = ; /* */ Note that we don't need S5 and RD5 because the banked SRAM will occupy pages $80 - $9F. We also don't need RD4 because the SRAM will always be active in that region of RAM, so RD4 should be tied high on the PCB. For the same reason, we don't need to generate MCS because the SRAM CS can be tied to S4 on the PCB. Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted February 4, 2010 Share Posted February 4, 2010 Bob/Claus B...When you finish the mod/upgrade, any chance you could work with the maintainers of the various atari emulators (i.e, m.e.s.s, atari ++ or altirra ) and get your mod/upgrade emulated, you might get more people wanting the upgrade that way, also you might also get more games or software that uses your upgrade's enhanced atari features just a thought, thats all Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 7, 2010 Author Share Posted February 7, 2010 Sorry, Bob, I forgot to get back to you. That is the .PLD file pasted into the codebox. Just copy it from the post (or from a reply page) and paste it into a text file. I have not had time yet to study up on CUPL. Your help is very welcome! Claus Can you post the .PLD file? I'll add the pinnodes and define some triggers and latches. Make some video! Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 7, 2010 Author Share Posted February 7, 2010 Bob/Claus B...When you finish the mod/upgrade, any chance you could work with the maintainers of the various atari emulators (i.e, m.e.s.s, atari ++ or altirra ) and get your mod/upgrade emulated, you might get more people wanting the upgrade that way, also you might also get more games or software that uses your upgrade's enhanced atari features. Yes, good idea. It should be easy to emulate. Much simpler than VBXE. Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted February 7, 2010 Share Posted February 7, 2010 welcome back claus b...was it nice in that 'better place', or were you snowed under with real life (tm&c) Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 20, 2010 Author Share Posted February 20, 2010 welcome back claus b...was it nice in that 'better place', or were you snowed under with real life (tm&c) I've been indulging an old hobby that predates my interest in Atari, programmable calculators. Yes, it is a nice place. Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted February 21, 2010 Share Posted February 21, 2010 Like the TI ones i saw back in the day.....I do remember the HP oblong/rectangular one's, thought they were nifty Quote Link to comment Share on other sites More sharing options...
falcon_ Posted February 23, 2010 Share Posted February 23, 2010 Hi folks I'm also working conceptually right now on a design for something like this. I was checking some calc'd numbers here, and I'm getting different numbers. It was mentioned it takes 8x PHI2 accuracy to match current antic resolution. But I've come up with half that. I'm not trying to have anyone look silly (and hopefully it won't be me hehe) Here is what I found in my searching. According to Mapping Atari, Appendix 3. 1 machine cycle 0.558 uS and is also one PHI2 cycle color clocks 228 / scanline machine cycles 114 / scanline According to Mapping and also Antic mag v3n10 (PBI article) the PHI2 clock cycle is one machine cycle, and one asm instruction takes two PHI2 cycles, or more. Mapping, pg 160, "The shortest 6502 instruction requires two [PHI2] cycles; during that time the electron beam moves four color clocks." According to this, the GR.8 scanline will move 8 pixels during the time for a short 6502 instr.(ie; CLC, etc) to complete. But there are Two PHI2 clocks for that timeframe. So for each PHI2 cycle, there is four colorclocks moved on-screen. Since 320x192 hi-res uses 0.5 colorclock/pixel, one colorclock is equivalent to one pixel on the 160px res. screen. Ok so when the 6502 completes one asm instr., like CLC (CLear Carry), two PHI2's have happened, and the electron beam or display has moved 8 GR.8 pixels. Or one text GR.0 character width. My point is there are *TWO* PHI2 signals during this one character width. Aha, if you run at PHI2 cycles, you get GTIA capable resolution. And if you were to turn PHI2 into a double-data-rate/DDR clock system (trigger on rise, and fall) you might get 160 pixel/scanline res., and this is without clock multiplier parts, except for altering how PHI2 is used. A DDR-style PHI2 would have about 228 nS/cycle, and of course you would need to get your video register index finished as early as possible there. The LEM project is very fascinating! It's very similar to a trick I am thinking about as well. I sure hope you folks won't mind if I make something with this technique too?? I'm trying to work-out/design a coprocessor that can use this video concept. Will I be stepping on any toes if I also complete my project?? sincerely _falcon_ Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 23, 2010 Author Share Posted February 23, 2010 It was mentioned it takes 8x PHI2 accuracy to match current antic resolution. But I've come up with half that. Yes, I agree. See this post: It occurred to me that we don't need an 8x clock, just 4x. Here's why: Our highest resolution mode sends out 8 pixels per Phi2 cycle. Instead of clocking them out of a shift register 8 times per cycle, we can multiplex them out with 8 states per cycle. We can get 8 states by decoding 3 bits - the 1x, 2x, and 4x clocks. So we just need two clock doublers. This is exactly how GTIA does its hi-res mode (ANTIC mode F). Those pixels come out at 7.2 MHz but GTIA only has a 3.6 MHz clock. It uses half a cycle to display one pixel and the other half to display the next pixel. The LEM project is very fascinating! It's very similar to a trick I am thinking about as well. I sure hope you folks won't mind if I make something with this technique too?? This is an open collaboration. Feel free to use any and all ideas and to add your own. Please keep us posted. Quote Link to comment Share on other sites More sharing options...
falcon_ Posted February 24, 2010 Share Posted February 24, 2010 It was mentioned it takes 8x PHI2 accuracy to match current antic resolution. But I've come up with half that. Yes, I agree. See this post: It occurred to me that we don't need an 8x clock, just 4x. Here's why: Our highest resolution mode sends out 8 pixels per Phi2 cycle. Instead of clocking them out of a shift register 8 times per cycle, we can multiplex them out with 8 states per cycle. We can get 8 states by decoding 3 bits - the 1x, 2x, and 4x clocks. So we just need two clock doublers. This is exactly how GTIA does its hi-res mode (ANTIC mode F). Those pixels come out at 7.2 MHz but GTIA only has a 3.6 MHz clock. It uses half a cycle to display one pixel and the other half to display the next pixel. Oops, missed that I guess. The LEM project is very fascinating! It's very similar to a trick I am thinking about as well. I sure hope you folks won't mind if I make something with this technique too?? This is an open collaboration. Feel free to use any and all ideas and to add your own. Please keep us posted. Thanks Claus. I will be posting all about it once I have something in-hand. I don't want to be a boaster-poster. I'm still in design/calc'ing phase, and want solder to flow, soonest! _falcon_ Quote Link to comment Share on other sites More sharing options...
Defender II Posted March 31, 2012 Share Posted March 31, 2012 Necro-Bump for a very interesting project. Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 1, 2012 Author Share Posted April 1, 2012 (edited) The LEM project is not dead, just on hold. My spare time is dominated by coaching my VEX Robotics team. For the second year we won a local tourney and are preparing for the World Tournament. That makes for a long season - August thru April. And summer is flying season around here. My Atari activities have been limited to collecting and repairing - an 800, three 400s, a 5200, a 600XL, an Apple //c, several old TI and HP programmable calculators, and an XEGS on the way. Edited April 1, 2012 by ClausB Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted October 15, 2013 Share Posted October 15, 2013 Bump to show continued interest. With plug n play RAM\Audio solutions availing themselves for those of us nervous with a soldering iron, it rewets my appetite to the possibilitiess. Combining those,along with this, the proposed pluggable 65816 CPU upgrade and a k\b break-out...it culminates in a sort of a make-shift, easy-to-use device (or set of) of an "A8 XM"-like nature, for the non-techy among us. OK, maybe I'm getting a bit carried away. Quote Link to comment Share on other sites More sharing options...
