TI-99/4A development resources
TI-99/4A Forth Extended Basic Books Game Development Emulators VDP9918 TMS9900 Compilers
102 replies to this topic
#1 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Thu Nov 19, 2009 11:35 AM
Don't forget to visit Ninerpedia; our wiki about the TI-99/4A. Check here.
If you are the owner of one of the programs or sites and do not want it posted, please let me know and it will be removed immediately.
Also if you think a reference to an important development resource is missing, then please let me know and I'll be happy to add to the list.
If you are new to the TI-99/4A or returning after a long time, then you might want to check out the TI-FAQ page here.
Latest update: May 9th 2013
1. EMULATORS
  • classic99  win
    Windows-based emulator including TI-99 ROMs under license from Texas Instruments.
    Debugger, memory heatmap, OS file support, support for 128K bank-switch carts, can create ROM/GROM cartridges, possibility to record AVI movies.
    User manual is included.
    (Author: Tursi)
  • MESS  win+linux
    Multiple system emulator that supports the TI-99/4, TI-99/4A, TI-99/8, and Geneve.
    Emulates more than 400 systems. Requires ROMs from the original systems.
    Features a powerful Debugger, most accurate emulation, support for 64K bank-switch carts / Gram Kracker / UCSD p-system card.
    Possibility to record AVI movies.
    Also see the MESS section in ninerpedia.
    The MESS debugger documentation can be found here.
    (Author: mizapf)
  • V9t9  win+linux
    TI-99/4A emulator written in java. Has support for TMS9918A VDP, TMS9919 sound & TMS5220 speech.
    Debugger included. V9t9 also supports the UCSD P-Code system.
    Some of the advanced V9t9 features include: ability to save/restore emulator state, record & playback, support for V9938 VDP.
    This emulator needs the Java Runtime Environment available for free at Oracle.
    V9t9 discussion thread can be found here.
    (Author: eswartz)
  • Win994a  win
    Windows-based emulator of the TI-99/4a
    Good TMS9900 cross-assembler included. No debugger.
  • Ti994w  win
    Windows based emulator with 80 column support
  • TI-99/Sim  linux
    Linux-based software simulation of the TI-99/4A.
  • PC99  DOS
    Commercial DOS-based emulator licensed by Texas Instruments to sell ROMs.
2. PROGRAMMING LANGUAGES
Assembler
  • Winasm99  win
    Windows based TMS9900 cross assembler with GUI and ability to build 8K cartridge roms.
    Is part of the Win994a emulator.
  • asm990  linux
    Linux based cross Assembler for the TI 990 with optional TI-99/4A output mode.
    You'll also need lnk990 a separate linker which can be found on the same page.
  • TIasm  win
    TMS9900 cross assembler TIasm will build 8K console (>0000) or cartridge (>6000) rom.
    Is part of the old V9T9 emulator package. Source is included.
Basic
  • Power BASIC  TI-99/4A
    This is a port of the 'Power BASIC' interpreter used with the TMS9995-based Powertran Cortex machine.
    It is written in pure assembly. Graphic commands, sprites and saving to disk are supported. Currently no sound and speech supported.
    Power BASIC instruction manual available.
Fortran
  • 99-9640 Fortran  TI-99/4A & Geneve
    The zip archive contains LGMA Products' FORTRAN v4.4 in both a version for the TI-99/4A and the Geneve 9640 computer.
    Documentation in PDF format included. The discussion thread on Atariage can be found here.
    Special thanks to: dano
    Posted Image
Forth
  • Turboforth  TI-99/4A
    A brand new implementation of the Forth langugage for the TI-99/4A.
    The Forth system itself is written in assembler and is optimized for speed.
    It runs from the cartridge space so there's plenty of space for your program in the 32K memory expansion.
    Click here for seeing some Turboforth video tutorials.
    (Author: Willsy)
Pascal
  • Turbo Pasc'99  TI-99/4A
    The zip archive has the patched version of Wiposofts Turbo Pasc'99 which you can run on your favorite emulator or on the TI-99/4A itself.
    While Turbo Pasc'99 is not as complete an implementation of Pascal as the UCSD Pascal system, it does have the advantage of not requiring
    any special hardware other than 32K RAM and a disk drive, and will likely meet the programming needs of most TIers.
    Check here for an english translation of the german documentation.
    This version is started by running the Editor Assembler #EA5 program image DSK1.TP99A
    Special thanks to: Vorticon, apersson850, retroclouds and lucien2
3. TOOLKITS AND COMPILERS
Assembly language
  • SPECTRA2  TI-99/4A
    Library for programming games in TMS9900 assembly language.
    Has routines for handling tiles, sprites, sound & task scheduler.
    Full documentation is included.
    (Author: retroclouds)
TI Basic
  • Harry Wilhelms' Basic compiler  TI-99/4A
    The zip archive contains the disk with compiler and documentation. As this is a TI-Basic compiler no sprites are supported.
    This is the compiler used to convert the great TI-Basic game Bouncing Babies to assembly language.
    Here's a tutorial video by Opry99er showing how to compile a basic program.
    And this is another video demonstrating the difference in speed between normal and compiled code.
    (Author: senior_falcon)
    Posted Image
Extended Basic
  • Harry Wilhelms' XB Compiler v2.1  TI-99/4A
    New compiler for compiling Extended Basic programs. XB Compiler supports most Extended Basic features, including sprites.
    The zip archive contains both the compiler and its documentation.
    The development thread can be found here.
    Posted Image
  • The Missing Link 2.0 (TML)  TI-99/4A
    The zip archive contains "The Missing Link 2.0" and its documentation.  This was published by Texaments in 1990.
    It gives the XB programmer easy access to the bit mapped features of the 9918 VDP.
    Full color cartesian graphics, turtle graphics, sprite graphics (32 sprites with auto motion) are supported.
    Text can be displayed on screen with fonts having sizes ranging from 4x6 pixels to 8x8 pixels.
    The manual is updated with many previously undocumented features. A tutorial called Potatohead" is included.
    There is a loader that embeds A/L programs in high memory - they can be saved as an XB program and run directly out of high memory.
    Posted Image
  • My Little Compiler (MLC)  TI-99/4A
    Library for using assembler-like language & routines from Extended Basic.
    Great for putting more power in Extended Basic programs. Now includes a precompiler for high-level language syntax. Demo Pong game and documentation included.
    The MLC development thread can be found here.
    Check out the video by rocky007 on his MLC based TI-99/4A port of Kaboom!
    (Author: moulinaie)
4. UTILITIES
File transfer
  • TIImageTool  win + linux
    TIImageTool is a tool that allows you to open disk image files as used with many emulators, and to work on them with common disk operations (like cut/copy/paste of files).
    It is particularly tailored for use with MESS but can also be used with other emulators.
    Has support for v9t9 format, PC99 format, CHD format, working with files & directories, Archiver support (can process Archiver files on the images), ...
    This utility needs the Java Runtime Environment available for free at Oracle.
    Supports Cf7a+ card images.
    (Author: mizapf)
  • TI99Dir  win
    TI99 filemanager for windows. Great for transferring disk images to the TI-99/4A.
    Supports Cf7a+ cards and Cf7a+ card images.
    Posted Image
  • Cf2k - Compact Flash 2000  TI-99/4A
    Cf2k (Compact Flash 2000) is a file manager for the TI99/4a with a CF7A+ compact flash adapter.
    With CF2k it is possible to protect/unprotect files, rename files/volumes, format volume, mount volume, copy/move/delete files,
    execute program files, ...
    Supports Cf7a+ cards.
    Posted Image
  • TI99-PC  win
    The Windows software TI99-PC will read, write, format, catalog, copy and convert
    TI-99/4A floppy disks on a PC. You will be able to transfer your real TI floppy disks
    from/to the TI-99/4A.
    Posted Image
  • CS1er tape conversion  win
    After your have converted your TI-99/4A cassettes to WAV soundfiles, you can use
    this windows software to extract your programs as FIAD disk images for your
    favourite TI-99/4A emulator. Detailed instruction manual enclosed.
Audio
  • ePSGMOD player  TI-99/4A
    Player for running PSG tunes composed with Mod2PSG2 tracker.
    (Author: Tursi)
  • ModConvertPSG  win
    This program converts 4-channel NoiseTracker (and ProTracker?) MOD files into VGM files using only the PSG.
    It produces sound chip data in VGM format, which is a standard format so it's easy to find players to test it with.
    It's a very simple format that basically has timing information and the actual bytes that you send to the sound chip.
    Here is a demovideo.
    (Author: Tursi)
  • QBOX Pro  win
    QBOX Pro is the windows software that converts WAV files to LPC speech data for playback on the TI-99/4A speech synsthesizer.
    This is a 16bit windows application but it still runs in Windows 2000/XP/Vista.
    It requires the BWCC.DLL library which can be found here.
Graphics
  • Convert9918  win
    Windows program for converting images into TMS9918A Graphics II (bitmap) mode.
    Output is in TI-Artist format or raw image/pattern dump.
    The article Modern Graphics on the 9918APDF gives an interesting overview on the techniques used in Convert9918.
    (Author: Tursi)
  • Grapefruit  win
    This utility for Windows lets you convert graphics to text (programming language data statements) to be included
    in your programs (basic, extended basic or assembler).
    Supports double sized sprites. Includes code to demo character or sprite design. Includes 14 charactersets/examples to
    work with. Has a built-in character editor, but still the idea is to work with your graphics in your favourite graphic
    package (eg. Photoshop).
    Turn on an 8x8 grid in your graphic software to assist you.
    This utility needs the .NET framework available for free at Microsoft.
    (Author: sometimes99er)
  • TI-99/4A Limelight Font Ripper  win
    With this windows tool you'll be able to extract/rip fonts from different file formats and save as a
    image file for use in TI utilities like Magellan, CartographPC and Grapefruit.
    It reads Commodore 64 fonts (*.64c), Nintendo Entertainment System fonts (*.nes) and TI-99/4A Classic99 VDPDUMP (*.bin)
    A collection of more than 200+ converted fonts can be found here.
    Here is a demovideo of Limelight.
  • GraphiCV  win/linux/osx
    Sprite Editor written in java. Draw your sprites on the PC and export them for use in Extended Basic and Assembler.
    Also supports export to Colecovision C format.
    Work with multiple sprite "layers" for creating multi-colored sprites.
    Click here for the GraphiCV development thread on atariage.
    (Author: unhuman)
  • Magellan  win/linux/osx
    TI-99/4A map editor written in java. This is the updated, unofficial 1.5 version.
    Draw your maps/screens on the PC and export them for use in Extended Basic and Assembler.
    Has a rich feature set: Import character set from '.PNG' or '.GIF' file, copy & paste, drawing functions, Export in XB display merge format, etc.
    Possibility to export maps as data statements for Extended Basic and Assembler, binary export also possible.
    Click here for the Magellan development thread on atariage.
    (Author: The Codex)
  • Sprite Editor  TI-99/4A
    TI-99/4A sprite editor written in C99. Runs from Editor/Assembler #EA5.
    Draw your sprites in an emulator or on the TI-99/4A machine.
    The zip file contains both the files for use in emulator and a TI disk image for easy transfer to the TI-99/4A.
    README file with detailed instructions included.
    You can see the Sprite Editor at work building some sprites: Jet Set Willyvideo and Parsecvideo.
    (Author: Willsy)
  • Patterns  flash
    TI-99/4A sprite editor written in Flash for many operating systems and browsers. Draw your sprites, export to clipboard and paste
    patterns directly into program lines of emulated Extended Basic (Classic99 or MESS).
    This utility needs Flash player available for free at Adobe.
    Most have this installed already.
    Here is a demovideo of Patterns.
Others
  • Notepad++  win
    Notepad++ is a free source code editor that supports several languages.
    Runs in Windows environment.
  • Notepad++ syntax highlighting file  win
    Syntax highlighting file for Assembler and Extended Basic to be used with the Notepad++ text editor.
5. MANUALS
Assembly language
  • Editor/Assembler reference manual  PDF + online
    The official Editor/Assembler reference manual. Note that this is not a tutorial for beginners.
    Still, it's an essential manual when writing assembler for the TI-99/4A.
    The Scribd online version can be found here.
    Posted Image
  • TMS9900 Microprocessor Data Manual  PDF
    Data Manual on the TMS9900 16-bit processor. The TMS9900 is the CPU used in the Texas Instruments TI-99/4A Home Computer.
    Contains instruction execution times, opcode size, etc.
    Posted Image
  • Guide for ROM command module  PDF
    Description on how to write software that runs from cartridge ROM.
  • COMPUTE!'s beginner's guide to assembly language on the TI-99/4A  PDF + online
    The Lottrup book. The only manual available today focusing on programming games in TMS9900 assembler.
    The examples in the book are for the Mini Memory line-by-line assembler which is rather limited.
    The manual also contains a few errors. Check here for the corrections.
    Nonetheless this book is a must-read for everyone seriously interested in writing assembler games for the TI-99/4A.
    Posted Image
  • Introduction to Assembly Language for the TI Home Computer  PDF
    The Molesworth assembly language introduction book.
    Covers VDP communication, keyboard reading, file access and a lot more.
    Posted Image
  • The Art of Assembly series  PDF
    The full series of articles by the late Bruce Harrison compiled as PDF. Over 600 pages, very well written and thorough.
    Posted Image
GPL / OS (Monitor)
  • GPL Programmers Guide  PDF
    The original GPL programming reference manual from Texas Instruments.
    Covers all opcodes and advanced stuff like coincidence detection, I/O routines, etc.
    Posted Image
  • TI-Intern  PDF
    Details on "Monitor", the OS of the TI-99/4A. Disassembly of console ROM/GROMS and GPL interpreter.
    Has details on interrupt routine, utility subprograms, basic interpreter, etc.
    Posted Image
    Posted Image
Basic / Extended Basic
LOGO
Forth
UCSD Pascal
  • The UCSD Pascal manual package  ZIP + PDF
    The official UCSD Pascal programming manuals. The zip file (70 megabytes) contains all manuals in PDF format.
    Here are the PDF manuals for online viewing: Compiler, Editor, Filer, Utilities, Assembler, Linker, p-code card
    The UCSD system disk images in v9t9/MESS format can be found here.
    Posted Image
Graphics, sound & speech
6. TUTORIALS
Assembly language
7. VIDEO TUTORIALS
TMS9918/TMS9928 Video Display Processor
Speech Synthesizer
Basic Compilers
GPL
File transfer
  • (TI99->PC) RS232 File Transfer  video
    Video tutorial on file transfer from the TI-99/4A to the PC using a serial connection cable.
    (Author: Opry99er)
  • (PC->TI99) RS232 File Transfer VIEW PART 1 / VIEW PART 2  video
    Video tutorial split in 2 parts dealing with file transfer from the PC to the TI-99/4A using a serial connection cable.
    In detail: DL a game from TI Gameshelf, Use ARC303G to unarchive it, Test in Classic99, Transfer using QModem and MFM, Running game on TI.
    (Author: Opry99er)
8. WEB SITES
  • TI-99/4A @ wikipedia
    Introduction and basics of Texas Instruments TI-99/4A Home Computer.
  • ninerpedia
    Wiki with information on MESS and its multicart format (RPK). Home of the TI-FAQ.
    Posted Image
  • Thierry Nouspikel's Tech Pages
    Probably the best TI hardware and software tech page. It has a wealth of technical details on all things TI-99/4A.
    This includes GPL, GROM, keyboard scanning, speech, etc.
    You can also download the full site as a zip file for offline viewing.
    Posted Image
    Posted Image
  • Mainbyte's home of the TI-99/4A
    Very good tech site with many detailed pictures and reference area.
    Includes various projects for upgrading your TI-99/4A, e.g. build a supercart cartridge.
    Posted Image
  • Jon's hexbus page
    Several hardware projects including pictures. Home of the 64K bank-switched cartridge project.
    (Author: acadiel)
    Posted Image
  • [Code|Hack|Create]
    New website run by Matthew of the Atariage group. The site covers many new hardware projects as the F18A FPGA based VDP and Bank-switch mini 256K.
    There's also a store where you can buy cartridge PCB's and other funky stuff.
    Author: matthew180
    Posted Image
  • The nanoPEB & CF7+ Website
    The official website. Has the documentation, tools and some source code of the popular TI-99/4A Compact Flash device.
    Posted Image
  • TI projects page
    Several hardware and software projects for the TI-99/4A by Fred Kaal.
    Home of TI-99Dir and TI99HDX.
    Posted Image
    Posted Image
  • TI-99/4A Home Computer Book Archive
    A new site where you find many books about the TI-99/4A not seen elsewhere.
    (Author: airernie)
    Posted Image
  • TI-99/4A Game Shelf
    Provides a gallery of interesting games with images of the opening screen as well as an
    in-play snapshot, along with a brief review tested on a real TI 99/4A system. Hardware
    requirements are also listed. Has many good Extended Basic games.
    (Author: Vorticon)
    Posted Image
  • WHTech
    WHTech is the primary archive - though it's a bit overwhelming.
    But pretty much all software, hardware docs, etc, are available there.
    It's undergoing a reorganization at the moment to hopefully make it more useful.
  • Navigate WHTech using PEEKBOT
    Alternate interface that allows you to view/download the contents of files stored in disk images on WHTech.
  • 99er.net
    Site with useful file archive and forum functionality.
9. LIST GROUPS
Edited by retroclouds, Thu May 9, 2013 12:37 PM.
#2 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Sun Dec 6, 2009 9:50 AM
ok, I just updated the list of TI-99/4A development resources  :)
#3 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Sun Dec 6, 2009 1:27 PM
TMS9900 cross assembler TIasm will build 8K console (>0000) or cartridge (>6000) roms. TIasm with source can be found here:
ftp://ftp.whtech.com/emulators/v9t9/v9t9src.zip
#4 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Sun Dec 6, 2009 1:48 PM
Thanks for the hint, I'll update the list  ;)
#5 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Sun Dec 6, 2009 2:05 PM
View Postkroy2049, on Thu Nov 19, 2009 11:35 AM, said:
  • classic99
       Best debugger, OS file support, support for 64K bank-switch carts
       Status: Still under active development
  • MESS
       Multiple system emulator that supports the TI-99/4A
       Basic debugger, most accurate emulation, support for 64K bank-switch carts
The MESS debugger has many features that the Classic99 does not have and vice versus.
#6 Tursi OFFLINE
Tursi
  • 1,793 posts
Posted Sun Dec 6, 2009 5:15 PM
Classic99 supports 128k bank switch carts, actually.
For MakeCart, today it only outputs GROM code - you can't burn the result to an EPROM and have it work (so the comment is a little misleading). I did start the ROM output version though and will get that done eventually. ;)
Edited by Tursi, Sun Dec 6, 2009 5:17 PM.
#7 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Mon Dec 7, 2009 3:10 AM
  • classic99
  • MESS
Noted, I've just adjusted the wording a bit. I also just checked the debugger page at MESS wiki;
The debugger really has some features I didn't think were there. Cool :cool:
I'll also try to be more objective ;)
Oh, on a sidenote, I just checked David Pitts' page and his asm990 cross-assembler runs on Linux, now supports
macros and has a "TI-99/4A mode". It can't create any cartridge images yet. But definitly worth testing more.
I'll be adding that to the resources together with TI-asm.
Edited by retroclouds, Tue Jul 17, 2012 11:49 AM.
#8 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Mon Dec 7, 2009 3:14 AM
Thanks for the info on this Tursi. I've updated the post.  :)
#9 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Mon Dec 7, 2009 4:06 AM
Although MESS does not have a "memory heatmap" as Classic99, you gotta love the flexibility of MESS’ watchpoints ...
Examples:
hotspot 0,10
Looks for hotspots on CPU 0 using a search buffer of 16 entries, reporting any entries which end up with 250 or more hits.
hotspot 1,40,#1000
Looks for hotspots on CPU 1 using a search buffer of 64 entries, reporting any entries which end up with 1000 or more hits.
wp 1234,6,rw
Set a watchpoint that will halt execution whenever a read or write occurs in the address range 1234-1239 inclusive.
wp 23456,a,w,wpdata == 1
Set a watchpoint that will halt execution whenever a write occurs in the address range 23456-2345f AND the data written is equal to 1.
wp 3456,20,r,1,{printf "Read @ %08X\n",wpaddr; g}
Set a watchpoint that will halt execution whenever a read occurs in the address range 3456-3475. When this happens, print Read @ <wpaddr> and continue executing.
temp0 = 0; wp 45678,1,writeval==f0,{temp0++; g}
Set a watchpoint that will halt execution whenever a write occurs to the address 45678 AND the value being written is equal to f0. When that happens, increment the variable temp0 and resume execution.
:cool:
#10 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Mon Dec 7, 2009 4:17 AM
... possibility to record AVI movie ...
With or without sound, I don’t think that is important features. There are many excellent screen and window video grapping software applications available and also for free.
I sometimes use Camtasia Studio to grap, zoom and analyze pixels and animations frame by frame.
Also, feel free to delete my comments/viewpoints, as to keep this thread a bit "clean".
#11 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Mon Dec 7, 2009 4:31 AM
... support for 128K bank-switch carts ...
Now that Classic99 supports 128K bank-switch carts, you might add MESS’ ability to support RAM in cartridges with "type of" Mini Memory (4K persistent), MBX (1K persistent) and SuperSpace II (32K).
Yes, you should be able to make games using persistent RAM to keep track of high scores, remember settings, save and load game facilities etc. - all ultraquick !
#12 Tursi OFFLINE
Tursi
  • 1,793 posts
Posted Mon Dec 7, 2009 10:27 AM
The feature lists will start getting very long if we put in all the little features. Classic99 supports RAM in cartridges too (just not persistent, nobody's ever asked for it ;) ). I think it's fine that there's a summary list and a link, so long as what's listed is accurate and relatively independent.
#13 Kurt_Woloch OFFLINE
Kurt_Woloch
    Dragonstomper
  • 810 posts
Posted Tue Dec 15, 2009 12:58 PM
I just downloaded the latest version of MESS, and contrary to the last one I used, the TI-99 emulation doesn't support cartridges anymore! Can anyone tell me why this has been removed and how cartridges can be loaded into MESS now?
#14 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Tue Dec 15, 2009 2:08 PM
Well, MESS does still handle cartridges. There is a new format for storing ROMS.
The ROMS are now in .rpk files (basically a zip file with .rpk extension containing rom and metadata).
Check here:
http://ninerpedia.or...MESS_ROM_format
and here:
ftp://whtech.com/emulators/cartridge_images/rpk/
#15 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Tue Dec 15, 2009 2:15 PM
Yep, as of version 0.135. Unfortunately the old method has been cancelled and even makes the system crash. The new method takes more and newer types of cartridges.
MESS history:
http://www.ninerpedi...version_history
#16 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Sun Jan 17, 2010 12:38 PM
Made a few updates and added several new resources  :)
#17 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Sun Jan 17, 2010 1:50 PM
Added my new tutorial "how to build a multi-bank ROM image". Enjoy  :D
#18 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Mon Jan 18, 2010 2:13 AM
Still not there ?
#19 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Mon Jan 18, 2010 5:15 AM
Still not there ?
ooopps, sorry about that  :ponder:
Will add it this evening, I promise  :D
#20 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Mon Jan 18, 2010 12:48 PM
Still not there ?
ok, I've just added the reference to TIasm  :)
#21 sometimes99er OFFLINE
sometimes99er
  • 2,301 posts
Posted Mon Jan 18, 2010 2:02 PM
Excellent !
#22 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Sat Jan 23, 2010 12:10 PM
Several updates: added reference to QBOX Pro & speech tutorial by Mark W., Added reference to TI-Intern.
#23 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Sun Jan 24, 2010 1:57 PM
Added reference to TI99-PC
#24 retroclouds OFFLINE
retroclouds
  • 1,256 posts
Posted Sun Jan 31, 2010 12:24 PM
Added repositories section, Grapefruit and TI-99/4A user reference guide.
#25 Willsy OFFLINE
Willsy
  • 1,217 posts
Posted Thu Feb 11, 2010 7:24 AM
Syntax highlighting file for TMS9900 assembly language and TI Extended Basic.
For use with Notepad++
