Nerf Herder73 Posted December 5, 2009 Share Posted December 5, 2009 BTW, I saw the "beam" issue, but now has been fixed on Wii7800 and MacMESS. Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted December 5, 2009 Share Posted December 5, 2009 Put me down for the cart when you start taking orders AX Quote Link to comment Share on other sites More sharing options...
DracIsBack Posted December 5, 2009 Share Posted December 5, 2009 So, can you give this one a shot on real hardware? I'm curious to see if this solves the issue. Fixed now! Works great! Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted December 5, 2009 Author Share Posted December 5, 2009 Thanks everyone! Ok, one more update for the day. Then, I think I'll rest for a day. New feature: - the ball breaks through bricks Known Issues: - it only detects on the upper-left corner of the ball-- that'll be corrected later - There is no deflection physics upon hitting a brick-- it just passes through-- again, that'll be corrected later. - Processing is slow-- some of the code for this is unbelievably inefficient-- I plan to clean that up in a later pass. In my opinion, better to get it functional, and clean it up later. At least that way, we can get a feel for how it might look in the end. So, give it a shot! 20091205_arkanoid_fun.bin 20091205_arkanoid_fun.a78 Screenshot: Thanks! -John Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted December 5, 2009 Share Posted December 5, 2009 Hey John - looks awesome! Great work! If I may, one thing I would like to let you know about the ball angles depending on where it hits the paddle. The Vaus is split into 5 locations that have different effects on the ball: (---) (Text representation of the Vaus) ||||| ABCDE If the Vaus is hit at points 'A' and the ball is traveling right, the ball reverses direction at a *low* angle (more horizontal than vertical). Likewise if the Vaus is hit at point 'E' and the ball is traveling left. If the ball is traveling in the opposite direction, it moves in the same direction at a *low* angle. As you may expect, if the Vaus is hit at points 'B' or 'D' in the same scenario as above, the same thing occurs except with the ball at a *high* angle (more vertical than horizontal). If the ball hits the Vaus at point 'C', it just continues whatever direction and angle it's on, just reversing it's vertical path. There are also five different speeds for the ball: super slow, slow, normal, fast, and very fast. Super Slow and Slow can only be achieved when the Vaus catches the 'Slow' pill. ('Super Slow' happens when the Vaus catches two 'Slow' pills before the ball has a chance to speed up). Hope I didn't overstep my bounds, but I played this game non-stop in college, and I've finished it almost as many times Just trying to help. Bob EDITED for spelling Quote Link to comment Share on other sites More sharing options...
DracIsBack Posted December 6, 2009 Share Posted December 6, 2009 Lookin' slick! Arkanoid was one of my favorites. Delighted to see it coming to the 7800 finally! Quote Link to comment Share on other sites More sharing options...
nonner242 Posted December 6, 2009 Share Posted December 6, 2009 I'll take a cart for sure love the Ark! Looks GREAT! Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted December 6, 2009 Share Posted December 6, 2009 Come on Nonner, no box art yet?! AX Quote Link to comment Share on other sites More sharing options...
TrekMD Posted December 6, 2009 Share Posted December 6, 2009 This keeps on looking better and better! Thank you and keep up the good work. Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted December 6, 2009 Author Share Posted December 6, 2009 Hey John - looks awesome! Great work! If I may, one thing I would like to let you know about the ball angles depending on where it hits the paddle. The Vaus is split into 5 locations that have different effects on the ball: (---) (Text representation of the Vaus) ||||| ABCDE If the Vaus is hit at points 'A' and the ball is traveling right, the ball reverses direction at a *low* angle (more horizontal than vertical). Likewise if the Vaus is hit at point 'E' and the ball is traveling left. If the ball is traveling in the opposite direction, it moves in the same direction at a *low* angle. As you may expect, if the Vaus is hit at points 'B' or 'D' in the same scenario as above, the same thing occurs except with the ball at a *high* angle (more vertical than horizontal). If the ball hits the Vaus at point 'C', it just continues whatever direction and angle it's on, just reversing it's vertical path. There are also five different speeds for the ball: super slow, slow, normal, fast, and very fast. Super Slow and Slow can only be achieved when the Vaus catches the 'Slow' pill. ('Super Slow' happens when the Vaus catches two 'Slow' pills before the ball has a chance to speed up). Hope I didn't overstep my bounds, but I played this game non-stop in college, and I've finished it almost as many times Just trying to help. I would be honored to have anyone contribute technical info about the game. That'll save me tons of research time. Ok, so boiling it down, it sounds like there are 2 main vectors I need to worry about for direction (forgetting all mirrored directions). It sounds like there's approximately a 30 and a 60 degree angle case (that's just a generalization-- we can figure out the exact angles needed). If that's the case, I need to play the Nintendo version and see how it compares to the Arcade. Additionally, for the speeds, what was the criteria for speed-up? I thought that the NES version was it a gradual speed-up, but it sounds like in the arcade version, there were X amounts of speed. Was it triggered by brick/wall hits, or by time? Not sure if that's an easy one to find out, but hey, if anyone would know, it'd be the community. If it ends up that there's a difference between arcade and NES gameplay, I may just have to allow the mode to be user-selectable. -John Quote Link to comment Share on other sites More sharing options...
Bakasama Posted December 6, 2009 Share Posted December 6, 2009 @ Propane13, I got question about the colors. How many does this game use? Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted December 6, 2009 Share Posted December 6, 2009 Thanks, John The ball can have other trajectories, depending on the floating enemies and how it hits the bricks. If memory serves me right, the ball can have a total of 4 different trajectories (not including mirroring). Regarding the speed, most of the time it's the number of hits that speed a ball up, but I noticed that sometimes if the ball hits the top of the playfield it speeds up also, but on some boards it doesn't. I think it's an internal setting on a per-board basis. I need to give it a play again. I haven't played the NES version. Is it fairly arcade accurate? Bob Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted December 6, 2009 Share Posted December 6, 2009 I haven't played the NES version. Is it fairly arcade accurate? :thumbsup: I think it does justice to the physics. I've played the F3 arcade version the most of any. I consider the NES version a great home version. AX Quote Link to comment Share on other sites More sharing options...
gdement Posted December 6, 2009 Share Posted December 6, 2009 I remember the Apple IIGS version had a level editor. That might contain some clues about which things are level settings vs universal game rules. But I don't remember if the game I saw was Arkanoid 1 or 2, so it might not apply. Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 6, 2009 Share Posted December 6, 2009 Hi John Really great work.If you plan to release it,count me in for a cart...... greetings Walter Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted December 6, 2009 Share Posted December 6, 2009 Someone wrote an editor for the arcade version as well (included here, with the folder containing the 'Arkanoid' Rom to edit) Arkedit.zip 1 Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted December 6, 2009 Author Share Posted December 6, 2009 Another version ready. Updates: - Using PacManPlus's evaluation, there is now some smarter physics when the ball hits the vaus. The ball now supports 2 vectors (plus mirrors), and 5 "hotspots" on the Vaus. So, the user now has some control over the ball's direction. - If you clear a board, you move on to the next board - Hitting gold bricks in an up/down direction makes the ball change up/down direction - Hitting other bricks in an up/down direction makes the ball change up/down direction and removes the brick. Known issues: - still running at 1/2 speed-- I will optimize later - Ball "gets stuck" underneath Vaus if you lose (this is a temporary workaround for another bug). However, you're dead anyway, so it's not a big deal. - Hitting bricks sideways does weird things to happen. I need to update my brick-collision routine to check for this case-- currently, it doesn't process that case. So, if you hit a brick from the side, it'll destroy the brick in most cases, and then continue moving sideways. You can see this very evidently in levels like level 7. 20091206_arkanoid.a78 20091206_arkanoid.bin Enjoy! -John Quote Link to comment Share on other sites More sharing options...
Mord Posted December 7, 2009 Share Posted December 7, 2009 Lookin' good. I'd better start putting money away with the way 7800 projects are starting up left and right this year. Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted December 7, 2009 Author Share Posted December 7, 2009 Today's update-- about 90% of ball/brick collision physics are working properly. They now include sideways collision support, which makes the game more accurate. I do note that there are some issues with a few "edge cases". Essentially, the remaining bug that I see involves some scenarios where a brick is next to the outside border of the level, the ball changes direction from hitting the border, and it may miss a collision. But, rounds like 4 and 7 (that have no bricks touching the border) should be pretty problem-free. Additionally, I've made it so the reset button doesn't send you back to start-- it just resets the level you're on. So, if you wanted to just play a level until you beat it, you can, without hitting select a ton of times. 20091207_arkanoid.a78 20091207_arkanoid.bin Enjoy! -John Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted December 7, 2009 Author Share Posted December 7, 2009 @ Propane13, I got question about the colors. How many does this game use? Currently, it uses 17 colors. -John Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted December 7, 2009 Author Share Posted December 7, 2009 Someone wrote an editor for the arcade version as well (included here, with the folder containing the 'Arkanoid' Rom to edit) Thanks for this! This will be fun to look at to see "how they did it". -John Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted December 7, 2009 Author Share Posted December 7, 2009 Ok-- question for all the Arkanoid players out there. In the arcade or NES version of Arkanoid-- what happens when the ball is traveling up and right, and hits the corner of a brick? Does it turn around (down and left)? Does it just change the X direction (now it goes up and left)? Or, does it change the Y direction (now it goes down and right)? I've currently coded it such that it will turn around completely (X and Y), but I wanted to check if this is accurate. Thanks! -John Quote Link to comment Share on other sites More sharing options...
Shawn Posted December 7, 2009 Share Posted December 7, 2009 Today's update-- about 90% of ball/brick collision physics are working properly. They now include sideways collision support, which makes the game more accurate. I do note that there are some issues with a few "edge cases". Essentially, the remaining bug that I see involves some scenarios where a brick is next to the outside border of the level, the ball changes direction from hitting the border, and it may miss a collision. But, rounds like 4 and 7 (that have no bricks touching the border) should be pretty problem-free. Additionally, I've made it so the reset button doesn't send you back to start-- it just resets the level you're on. So, if you wanted to just play a level until you beat it, you can, without hitting select a ton of times. 20091207_arkanoid.a78 20091207_arkanoid.bin Enjoy! -John John, I've had a smile from ear to ear playing this game your working on. Thanks so much!! Shawn Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted December 7, 2009 Share Posted December 7, 2009 This is looking really good so far! Quote Link to comment Share on other sites More sharing options...
DracIsBack Posted December 7, 2009 Share Posted December 7, 2009 I've had a smile from ear to ear playing this game your working on. Thanks so much!! Me too! I thought he was taking a day off, but then two more builds appeared! Hey Shawn - what is your avitar? Quote Link to comment Share on other sites More sharing options...
