atarixle Posted July 26, 2014 Share Posted July 26, 2014 (edited) I got AspeQt running in a Wine-Bottle too ... the secret is to create a symbolic link from the Windows »COM1« Port to Mac OS X' »/dev/{USB_serial}« (as intel mac don't have built-in on-board serial boards) device file. Communication works well if you have the right USB2Serial device, like the »Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC« (this is what Linux' lsusb-command tells me). A very good and easy to install Mac OS X driver for this chipset can be downloaded here: http://www.ftdichip.com/Drivers/VCP.htm. in my WineSkin winery build I did it like this: cd ~/Applications/Wineskin/AspeQt\ 0.8.8.app/Contents/Resources/dosdevices/ ln -s /dev/tty.usbserial-FTFW83YT com1 Download: http://wineskin.urgesoftware.com/tiki-index.php Edited July 26, 2014 by atarixle 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 26, 2014 Share Posted July 26, 2014 This looks worth a shot. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 29, 2014 Share Posted July 29, 2014 For information: I just tested the generally available Mac OS X build of Aspeqt on the Intel Snow Leopard laptop with the standard FTDI drivers and everything works absolutely perfectly. Meanwhile, the AMD set-up is clearly a lost cause. Quote Link to comment Share on other sites More sharing options...
atarixle Posted July 30, 2014 Share Posted July 30, 2014 My own build of AspeQt 0.8.2 doesn't work at all, even with the FTDI drivers. Can you give me the link to the OS X build you're using? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 30, 2014 Share Posted July 30, 2014 Can you give me the link to the OS X build you're using? This one works: http://atariage.com/forums/topic/154949-aspeqt-yet-another-sio2pcape-clone/page-31?do=findComment&comment=3033023 And this one: http://frederik.hol.st/atari/8-bit/AspeQt4Mac/ Haven't tried this one yet: http://cl.ly/0c420q0g2Z1m Using 32-bit VCP drivers here: http://www.ftdichip.com/Drivers/VCP.htm Quote Link to comment Share on other sites More sharing options...
mellis Posted July 30, 2014 Share Posted July 30, 2014 For information: I just tested the generally available Mac OS X build of Aspeqt on the Intel Snow Leopard laptop with the standard FTDI drivers and everything works absolutely perfectly. Meanwhile, the AMD set-up is clearly a lost cause. This Apple tech note might explain the difference between Mavericks and earlier OS X versions. Apple is now bundling their own FTDI drivers with the OS. The tech note includes instructions for using the FTDI drivers instead of Apple's own driver. I wonder if doing so might help AspeQT users. https://developer.apple.com/library/mac/technotes/tn2315/_index.html 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 30, 2014 Share Posted July 30, 2014 (edited) This Apple tech note might explain the difference between Mavericks and earlier OS X versions. Apple is now bundling their own FTDI drivers with the OS. The tech note includes instructions for using the FTDI drivers instead of Apple's own driver. I wonder if doing so might help AspeQT users. https://developer.apple.com/library/mac/technotes/tn2315/_index.html I read this a week or two ago but it makes no sense to me. WITHOUT the FTDI drivers installed, OS X doesn't want to make use of the device at all. It shows up in System Profiler but OS X doesn't put anything in /dev/ to allow software to interact with it. WITH the FTDI driver installed, SIO Server works great, SIO2OSX works great, it's just AspeQt that doesn't want to play nice with my system. I think it's GOT to be something in Qt 5.3 but I don't know enough about Qt to even start to figure out what. Edited July 30, 2014 by DrVenkman Quote Link to comment Share on other sites More sharing options...
mellis Posted July 30, 2014 Share Posted July 30, 2014 I read this a week or two ago but it makes no sense to me. WITHOUT the FTDI drivers installed, OS X doesn't want to make use of the device at all. It shows up in System Profiler but OS X doesn't put anything in /dev/ to allow software to interact with it. WITH the FTDI driver installed, SIO Server works great, SIO2OSX works great, it's just AspeQt that doesn't want to play nice with my system. I think it's GOT to be something in Qt 5.3 but I don't know enough about Qt to even start to figure out what. Correct - without a driver, the hardware cannot be used. However, the tech note reluctantly explains how to configure your system to use FTDI's original drivers instead of Apple's bundled driver (which is new in Mavericks). From the symptoms described here, I suspect the problem exists at the driver level. There are many ways to interact with a TTY (serial) device, and it is possible that SIO2OSX and SIO Server happen to use the port and its signal lines in a way that is more in line with the driver author's expected use case. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 30, 2014 Share Posted July 30, 2014 Correct - without a driver, the hardware cannot be used. Right. But the Tech Note SEEMS to say there is an Apple-provided driver that will work instead. Yet with the FTDI driver removed, there is no sign that OS X recognizes the device as something it should be controlling, and doesn't install the Apple driver instead. Perhaps I misunderstood the note. From the symptoms described here, I suspect the problem exists at the driver level. There are many ways to interact with a TTY (serial) device, and it is possible that SIO2OSX and SIO Server happen to use the port and its signal lines in a way that is more in line with the driver author's expected use case. Another mystery though: why does the Windows build of AspeQt, running inside a WINE/CrossOver bottle, run full speed without the excessive processor use and constant data stuttering that I see in the native OS X build I made? In both instances I'm using the AspeQt code, and both versions are using the same FTDI drivers in the same way. The only difference between the two seems to be Qt for windows versus Qt for OS X. It's all very confusing. Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 12, 2014 Share Posted August 12, 2014 I am not sure if there is a way to run it in 64 bit, but I will try to compile a 64 bit version once I install QT to my 64 bit version of Ubuntu. Any luck? Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 12, 2014 Share Posted August 12, 2014 Any luck? Oooops completely forgot about that, probably due to the fact that summer activities other than computer programming takes much of my time, nevertheless I will try to do it tonight and let you know... Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 13, 2014 Share Posted August 13, 2014 (edited) Any luck? Ok here's the 64 bit version of AspeQt v.1.0.0-preview-6 for Ubuntu/Debian. I verified that it loads and runs with my 64 bit version of Ubuntu under VirtualBox. Edited August 13, 2014 by atari8warez Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 14, 2014 Share Posted August 14, 2014 (edited) Decided to give 1.00 Preview 6 a go this evening since I needed to handle a 256KB file in a mounted folder. Unfortunately Aspeqt did not appear to return EOF after byte 262,144 (the last byte of the file) had been read. Fortunately UFlash (the software reading the file) does a sanity check to ensure a ROM file of an incorrect size is not programmed to the flash ROM (otherwise the Ultimate 1MB could have been bricked). I have not ascertained whether the extra byte returned by the CIO is simply a spurious appendage to the actual file, or whether something more serious has occured, such as the entire file content being offset by one or more bytes. I'll try to establish one way or another. Fixed, fix will be available on the next release. Edited August 14, 2014 by atari8warez Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 15, 2014 Share Posted August 15, 2014 It works! Thanks. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 15, 2014 Share Posted August 15, 2014 Great, nice to hear.. Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 17, 2014 Share Posted August 17, 2014 I just noticed that when I start up the program it says: Cannot open Serial Port '/dev/ttyS0': Permission Denied. How do I give it permission? Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 17, 2014 Share Posted August 17, 2014 (edited) I just noticed that when I start up the program it says: Cannot open Serial Port '/dev/ttyS0': Permission Denied. How do I give it permission? You may need to add your Ubuntu user-id to the dialout group. Open a terminal window and type the following: sudo adduser your_user_id dialout Try that and see if it works, if it doesn't then verify that your SIO2PC device is recognized and mounted properly; From the terminal window type the following (the following assumes that you have an FTDI chip based SIO2PC device): dmesg | grep FTDI Above command should produce an output similar to the following: [ 159.987490] ftdi_sio 5-1:1.0 FTDI USB Serial Device converter detected [ 159.989404] usb 5-1: FTDI USB Serial Device Converter now attached to ttyUSB0 Edited August 17, 2014 by atari8warez Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 18, 2014 Share Posted August 18, 2014 I added myself to that group but it still didn't work. I then did that dmesg command but it returned nothing. I'm using a Serial to SIO cable (SIO2PC) that I've used in the past with a PC program. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 18, 2014 Share Posted August 18, 2014 (edited) So the SIO2PC cable you are using is a serial (RS232) type, not a USB to Serial converter type. Do you have a real serial port on your computer? If so, you need to find out the name of the communication port (it wouldn't be ttyUSB0) and change the port name in AspeQt to use that instead. From the terminal window type the following to see available devices: ls /dev and look for a device called ttySx (where x is a number between 0-3) or you can type: dmesg | grep ttyS to list all devices with a name starting with ttyS Edited August 18, 2014 by atari8warez Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 18, 2014 Share Posted August 18, 2014 Yes it's a serial type, not a USB one. I do have a real serial port, I have a card with two of them on it, maybe it's trying to detect the one I'm using for my Amiga transfers? I'll look into this tonight. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 18, 2014 Share Posted August 18, 2014 Apparently I haven't paid attention to the device name in your original post (which says ttyS0 and not ttyUSB0), sorry for the confusion over serial vs. USB. And yeah see if ttyS0 is already used by some other program, you can then change AspeQt to use ttyS1. Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 19, 2014 Share Posted August 19, 2014 New error: Cannot not set serial port speed to 19200. Input/Output error. I get this with ttyS0 and ttyS1. Progress? Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 19, 2014 Share Posted August 19, 2014 That's weird, I've never seen this error before, does the serial port(s) work with other comm programs? Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 19, 2014 Share Posted August 19, 2014 In Windows it does (I use it with SIO2PC and Amiga Explorer). I've never tried with Linux. Do I need a driver of some sort for the card. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 19, 2014 Share Posted August 19, 2014 Honestly, I don't know. I am pretty new to linux and don't have linux on a hardware that has a real serial port. I would think if the card is a standard RS232 serial card linux kernel would already have the drivers for it. Quote Link to comment Share on other sites More sharing options...
