How To Load XB and E/A Files (TI-99/4a)
4 replies to this topic
#1 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,124 posts
Posted Mon Jan 25, 2010 8:30 AM
Can someone tell me the commands for running Extended Basic and Editor Assembler files on the TI-99/4a? Also, how do you catalog a disk so you can see what files are on there? Do you need Disk Manager for that or can it be done from XB or E/A?
Tempest
#2 oracle_jedi OFFLINE
oracle_jedi
    Dragonstomper
  • 512 posts
  • Nothing to Declare
Posted Mon Jan 25, 2010 9:12 AM
E/A games are either Option 3 "Load and Run" or Option 5 "Run Program File".
Select the relevant option and enter the name of the program.
For example, to run Submarine Commander from disk 1, select option 5 and enter in upper case:
DSK1.SUBCOMMAND
Extended BASIC games often auto-load. It looks for a file called "LOAD" on disk 1 and runs it if it finds it.
If not, you can use the RUN command as follows:
RUN "DSK1.MYPROGRAM"
You can also load and run as follows:
OLD "DSK1.MYPROGRAM"
RUN
To catalog a disk, beside the Disk Manager module, you can use a program like Disk Manager 2000 which runs under EA.
Most EA3 and EA5 games can be run under Extended BASIC using a tool like YLOAD.
So... you can insert Extended BASIC, load YLOAD and use that to EA3 load Disk Manager 2000.
Really all you need is Extended BASIC.
#3 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,124 posts
Posted Mon Jan 25, 2010 9:13 AM
Why is the command called OLD? Just seems funny. Must stand for something.
Tempest
#4 Bones-69 OFFLINE
Bones-69
    Chopper Commander
  • 216 posts
Posted Wed Apr 21, 2010 11:39 PM
My preference these days is Rich Extended Basic (RXB) over standard XB. Under RXB you can simply type CALL DIR("DSK1.") for a disk catalogue, it's very handy and convenient.
I have wondered the same.... Open Load Device? I really don't know, just guessing...
#5 Charlie_ OFFLINE
Charlie_
  • 2,904 posts
Posted Thu Apr 22, 2010 10:05 AM
Because it was previously saved, making it "OLD"? :)
The disk system on the TI99 is very weird. It is hard to do the most simple tasks.
I haven't tried DM2K yet, but DM2.0 is very useful. I found it strange that it didnt allow for the copying of a file if you have only a single disk drive. Unless there is something I missed?
Does DM2K allow for this?
Edited by Chazbeenhad, Thu Apr 22, 2010 10:06 AM.
