coyo5050 Posted May 11, 2010 Share Posted May 11, 2010 I recently picked up a Magnavox Odyssey 2 system the version with the detachable controllers. I just realized the power supply for it is chewed up on it right by the square part that plugs in the the outlet so it really isnt fixable since no cord to work with. The fun thing I noticed is that it has a plug that looks like a 3.5mm end which is different than my other Magnavox Odyssey 2 with the attached controllers. Its a Model AJ9046 Input 120v, 60hz, 17w Output 11VAC, .9AMP Cont. Any suggestions where I could find a replacement? I was thinking about trying Radio Shack tomo. Or any ideas how to open up the square part where it plugs in to repair the wire? Thanks!! Quote Link to comment Share on other sites More sharing options...
Odysseus Posted May 12, 2010 Share Posted May 12, 2010 (edited) I recently picked up a Magnavox Odyssey 2 system the version with the detachable controllers. I just realized the power supply for it is chewed up on it right by the square part that plugs in the the outlet so it really isnt fixable since no cord to work with. The fun thing I noticed is that it has a plug that looks like a 3.5mm end which is different than my other Magnavox Odyssey 2 with the attached controllers. Its a Model AJ9046 Input 120v, 60hz, 17w Output 11VAC, .9AMP Cont. Any suggestions where I could find a replacement? I was thinking about trying Radio Shack tomo. Or any ideas how to open up the square part where it plugs in to repair the wire? Thanks!! Coyo. Yet again i find myself answering your odyssey questions The detachable controller system that i have has the following specs on the ac Output 11.5VAC, 400 MA Input 115 VAC, 60 HZ 12 W It is indeed a 3.5 mm jack style adaptor. I do beleive that you can find a universal adaptor at Radio shack that will work. Or sometimes you can find just the adaptor on ebay. I do like this system .Congrats on finding one. I dont think you can open the box end easily. You may be able to pry it open if you want to try. You seem resourceful enough to try it lol By the way i have heard that you can use the Atari 2600 Power Supply but havent tried it myself but by looking at my service manual for the Odyssey 2 it seems plausible Edited May 12, 2010 by njb12287 Quote Link to comment Share on other sites More sharing options...
zylon Posted May 13, 2010 Share Posted May 13, 2010 A regular NES power cord will work. Quote Link to comment Share on other sites More sharing options...
coyo5050 Posted May 15, 2010 Author Share Posted May 15, 2010 Yeah I was thinking I would try Radio shack. Looks like I would have to saw the original power supply brick apart. Def a 3.5m jack on the end. Quote Link to comment Share on other sites More sharing options...
Odysseus Posted May 17, 2010 Share Posted May 17, 2010 Yeah I was thinking I would try Radio shack. Looks like I would have to saw the original power supply brick apart. Def a 3.5m jack on the end. Why dont you try my 2600 suggestion. No more love COyo. And no the First model of the O2 CANNOT use the NES power adaptor. Very different Quote Link to comment Share on other sites More sharing options...
