Emehr Posted May 18, 2010 Share Posted May 18, 2010 So I picked up a Flashback 2 at a garage sale this past weekend for $5. One of the sticks was broken and the other stick was a genuine CX-40 from the day. Anyway, the thing is pretty dusty and there's evidence of corrosion on the cart pins so I think, "Hey, this would be a suitable candidate for a mod!". Sure, I have two FB2's at home that I've had since they sold them in stores, and while I had taken one apart I never had the heart to take the solder gun to it. Now's my chance! So I take the little guy home, clean him up, and plug him in to make sure it works. Yep. Okay, now I get down to business. I have an IDE cable I could use but from the pics I've seen of other mods it looks very unwieldy. I have this spool of super thin single strand stuff that I wanted to try instead just to see if it'd work. I hardwired the J3 connection (as opposed to putting a switch there) because I wanted to make sure I had all of the cart pins correct before getting too crazy. After getting everything in place, I plugged it in and voila! Space Jockey running on the FB2! Anyway, I whipped up a visual cheat sheet (a VCS, if you will ) that shows what needs to hook up to what that may be helpful to anyone that wants to mod their Revision C FB2. I'm pretty sure this is a Revision C. If not, I'm sure someone will correct me. And if anyone wants to check my work I gladly welcome it. I didn't want to make a graphic such as this without doing the mod myself. And now that I finally have (after, what four or so years? ), well, here it is. But first, a pic of my mod in action. This was before I added the toggle to switch between built-in games and cart and before I desoldered everything to make the graphic. My next project for this is a bit more ambitious... 2 Quote Link to comment Share on other sites More sharing options...
atwwong Posted May 18, 2010 Share Posted May 18, 2010 Nice work and thanks for sharing the pics! Quote Link to comment Share on other sites More sharing options...
awace Posted May 19, 2010 Share Posted May 19, 2010 Nice work and thanks for sharing the pics! the cart switch has to unhook gnd from c select line select a10 equivilant bank select pin from built in memmory and the other one needs to be hooked up so you essentally replace jumper and remove one to switch between the modes to external cart this is why i think it took a week for me to figure out how to use both sides on the color/bwhite dual double throw double pole it has two 3 pin connections on the switch so i had to scratch all the solder mask from the original toasted 2600 board i used to steal its case ... if i remember correctly anyway ill remove cover since i used ide cable not wire wrap wire like you did cause i knew this question would come up and i dont like to repair something I forgot where they go!.. Ill look now Quote Link to comment Share on other sites More sharing options...
awace Posted May 19, 2010 Share Posted May 19, 2010 Cool only two cover screws its weird i have a half one type cover the top has ch3 switch and a/b and joy holes but the bottom has joy holes and power holes too!!! i forgot about hat .. I take back what I originally said its just one pin gets unhooked in one selection then the other gets hooked in same selection crap back to looking where wires actually go!! The bottom has a hole for A B channel select I cleaned the stickers off but there is a mold marking melted in saying 451 on the bottom outside cavity!. so in one mode one jumper gets grounded and in the other one gets 5v or something like that i forget yea i think the built in memory gets 5v and the cart gets pin 6 connected cause i see interference when cart in I could be totally wrong . but i know when its up in the cart mode it connects on the left top side of the double pole color/bw switch and the bottom right 3 pins on the original 2600 slide switch connects something when the other right top unconnects built in memmory wire when in cart mode but i forget I know they dont have common wire though thats what leads me to think the built in memory needs 5v cause most of those memory sticks are 5v. or mabie its 3.3v but my cap is still on power switch just unhooks pcb from 5v regulator so the power pack has LOAD all the time and wont burn up so i have to unhook funpack power pack wall wart to make it reset remember to start a built in game 1st before FLASHing back to cart slot to FLASH youre games to youre hearts content ALso sometimes you get the this area intentonaly left blank also power on holding reset momentary wilst holding select momentary at same time then power on for test menu then 1972 up 1 down 9 times up seven and down 2 for paddle cart menu on built in to test youre wipers on youre paddle pots. Quote Link to comment Share on other sites More sharing options...
awace Posted May 19, 2010 Share Posted May 19, 2010 (edited) I Apologize for my rantie posts.. Good luck on youre mod I hope you pick an interesting case REMEMBER wire wrap wire snaps easily thats why we replace one by one w ribbon cable !. Its a Royal pain in the butt but its worth it. Its the fact that the original 2600 switches have a missing slip differntal between the dual poles witch makes flashing super fun. REMEMBER FLASHING between built in and external cart could damage both the cartridge or the built in memmory I dont flash the power button only modes.. DO NOT FLASH A ORIGINAL 2600 because this is bad sparks are nasty E S D type things... Edited May 19, 2010 by awace Quote Link to comment Share on other sites More sharing options...
Emehr Posted May 21, 2010 Author Share Posted May 21, 2010 Okay, being completely incapable of leaving well-enough alone, I rescanned the board at a higher resolution and cleaned up the graphic a bit, adding a few more bits of info here and there (see first post). If anybody sees anything that's amiss, please let me know and I'll fix it. Or if you'd like to see anything added, let me know and I'll see what I can do. I'm more of a graphics person. My electronics background is very rudimentary. EDIT: whoops, the graphic should read "+9VDC", not "+5VDC". Update attached to first post... Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted May 21, 2010 Share Posted May 21, 2010 Emehr-- :thumbsup: Nice work dude. Curt Quote Link to comment Share on other sites More sharing options...
Emehr Posted May 22, 2010 Author Share Posted May 22, 2010 Emehr-- :thumbsup: Nice work dude. Curt Thanks, Curt! I'm kinda itchin' to do the other Revision boards now but a) I don't have any of the others (just Rev C's) and b) I'm not sure if there's much interest. The FB2's have been out for a while so most people that have wanted to do mods have probably already done them by now. I'm curious about any other tricks that may be exploited with the board. There are a lot of solder pads that haven't been explored and there's still the Michele/Gizmo pin-out graphic floating around. I'll probably poke around some more and see what I can see. If I find anything cool I'll update the graphic. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted May 23, 2010 Share Posted May 23, 2010 Well, I'll give you a hint... there is a soft reset on the system to exit a game and go back to the menu without powering off Curt Emehr-- :thumbsup: Nice work dude. Curt Thanks, Curt! I'm kinda itchin' to do the other Revision boards now but a) I don't have any of the others (just Rev C's) and b) I'm not sure if there's much interest. The FB2's have been out for a while so most people that have wanted to do mods have probably already done them by now. I'm curious about any other tricks that may be exploited with the board. There are a lot of solder pads that haven't been explored and there's still the Michele/Gizmo pin-out graphic floating around. I'll probably poke around some more and see what I can see. If I find anything cool I'll update the graphic. 1 Quote Link to comment Share on other sites More sharing options...
Havok69 Posted May 25, 2010 Share Posted May 25, 2010 Well, I'll give you a hint... there is a soft reset on the system to exit a game and go back to the menu without powering off Nice - that should have been a button on the production unit! Quote Link to comment Share on other sites More sharing options...
Joecl93 Posted February 11, 2011 Share Posted February 11, 2011 So I picked up a Flashback 2 at a garage sale this past weekend for $5. One of the sticks was broken and the other stick was a genuine CX-40 from the day. Anyway, the thing is pretty dusty and there's evidence of corrosion on the cart pins so I think, "Hey, this would be a suitable candidate for a mod!". Sure, I have two FB2's at home that I've had since they sold them in stores, and while I had taken one apart I never had the heart to take the solder gun to it. Now's my chance! So I take the little guy home, clean him up, and plug him in to make sure it works. Yep. Okay, now I get down to business. I have an IDE cable I could use but from the pics I've seen of other mods it looks very unwieldy. I have this spool of super thin single strand stuff that I wanted to try instead just to see if it'd work. I hardwired the J3 connection (as opposed to putting a switch there) because I wanted to make sure I had all of the cart pins correct before getting too crazy. After getting everything in place, I plugged it in and voila! Space Jockey running on the FB2! Anyway, I whipped up a visual cheat sheet (a VCS, if you will ) that shows what needs to hook up to what that may be helpful to anyone that wants to mod their Revision C FB2. I'm pretty sure this is a Revision C. If not, I'm sure someone will correct me. And if anyone wants to check my work I gladly welcome it. I didn't want to make a graphic such as this without doing the mod myself. And now that I finally have (after, what four or so years? ), well, here it is. But first, a pic of my mod in action. This was before I added the toggle to switch between built-in games and cart and before I desoldered everything to make the graphic. My next project for this is a bit more ambitious... That is very good, btw this cheat sheet will work on the Atari flashback 2+. Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted February 12, 2011 Share Posted February 12, 2011 This is a GREAT visual... Very nicely done Quote Link to comment Share on other sites More sharing options...
Emehr Posted February 14, 2011 Author Share Posted February 14, 2011 This is a GREAT visual... Very nicely done Thanks a lot! Quote Link to comment Share on other sites More sharing options...
MRB2011 Posted June 29, 2011 Share Posted June 29, 2011 Sorry if my question seems stupid, but I am new to all this. Is it possible to change the Difficulty buttons into switches? Would SPST switches work? Thanks! 1 Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted December 4, 2011 Share Posted December 4, 2011 (edited) Sorry if my question seems stupid, but I am new to all this. Is it possible to change the Difficulty buttons into switches? Would SPST switches work? Thanks! yes Edited December 4, 2011 by pimpmaul69 Quote Link to comment Share on other sites More sharing options...
Twoface2 Posted October 23, 2014 Share Posted October 23, 2014 Well, I'll give you a hint... there is a soft reset on the system to exit a game and go back to the menu without powering off Curt Has somebody found this yet? Would be very useful.... Curt? Quote Link to comment Share on other sites More sharing options...
Emehr Posted November 1, 2014 Author Share Posted November 1, 2014 Has somebody found this yet? Would be very useful.... I haven't been brave enough to go poking around on my board. Too afraid to burn something up. If somebody does find it, though, I'll be happy to update the graphic. Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted November 3, 2014 Share Posted November 3, 2014 (edited) Well, I'll give you a hint... there is a soft reset on the system to exit a game and go back to the menu without powering off Curt Curt, This would be a popular mod even for the people unwilling to go the full route in adding a cartridge slot to the FB. If you don't mind me asking, how come you didn't add that info to the cartridge slot mod how-to you posted to your website? If I added a soft reset switch or button to my Flashback 2, my 3 1/2 year old daughter would be more pleased with it. We should probably just call this the "Menu" button or switch mod. Is this present on both the Flashback 2 and the 2+? And is there a way to re-connect "Line 12"? Pardon my ignorance. Edited November 3, 2014 by Lynxpro Quote Link to comment Share on other sites More sharing options...
sdave Posted May 16, 2015 Share Posted May 16, 2015 I'm not sure if anyone is still interested in the soft reset that Curt mentioned above, but I was able to find it on my FB2 rev B. I don't have a photo yet so here is the best text description I can come up with: Remove the main board so that you are looking at the component side. The controller ports and power jack should be on the top edge so that you can read the component designators. Look to the left of U2 (under the upper black blob on rev B.) Find the surface mount resistor R3. There is a small round pad (similar to the cart connecter pads but without any number) just to the left of R3. On the other side of the round pad you should see the text C10. Solder a wire to this pad. Connect a normally open, momentary pushbutton switch to this wire. Connect the other side of the switch to ground (cart connector pads 12 & 24 are both ground.) What you are doing is shorting this pad to ground when you press the switch. This will reset the unit and take you back to the main menu just like you cycled the power switch. I don't have a FB2 rev C available so I'm not sure where this would be located on that version. Looking at the photos above, the layout is quite a bit different. The component designators might be the same (i.e. R4 and C10) but I don't have any way of testing that out. Dave 2 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted May 17, 2015 Share Posted May 17, 2015 I'd love to see pictures of your Rev B with the mod, Dave. I'd like to do that to my Rev B as well. Quote Link to comment Share on other sites More sharing options...
sdave Posted May 21, 2015 Share Posted May 21, 2015 I'd love to see pictures of your Rev B with the mod, Dave. I'd like to do that to my Rev B as well. I'll try to get some up this weekend. I'm also interested to know if anyone has figured out a way to enable the hidden paddle games menu by default on power up. Looking around the processor chip on the board, I see several unpopulated jumpers and an area with a set of resistor pads that appear to be used for configuration (i.e. pins that can be tied high or low to configure default modes.) I'm curious if anyone has experimented with these. Quote Link to comment Share on other sites More sharing options...
hitbyambulance Posted May 30, 2015 Share Posted May 30, 2015 I'll try to get some up this weekend. I'm also interested to know if anyone has figured out a way to enable the hidden paddle games menu by default on power up. Looking around the processor chip on the board, I see several unpopulated jumpers and an area with a set of resistor pads that appear to be used for configuration (i.e. pins that can be tied high or low to configure default modes.) I'm curious if anyone has experimented with these. also interested - just found an FB2 at Half-Price Books for $10, looking to mod this unit. Quote Link to comment Share on other sites More sharing options...
sdave Posted May 30, 2015 Share Posted May 30, 2015 I posted the FB2 menu button (aka soft reset) mod under a new topic. Here's the link: http://atariage.com/forums/topic/238873-fb2-rev-b-menu-button-soft-reset-mod/?hl=menu+button Constructive feedback is appreciated. Quote Link to comment Share on other sites More sharing options...
