Tempest Posted May 24, 2010 Share Posted May 24, 2010 Ok this is probably an odd question, but over the weekend I picked up a nice looking Amiga 1080 monitor. Since I don't need it for my Amiga, I thought I'd hook it up to my IIgs since it's bigger and in better shape than my IIgs RGB. The problem is that the monitor port is different than the IIgs. I know the monitor is compatible (they're both analogue RGB monitors) and I've read that you can use it with the IIgs, but I guess I need a different cable. Anyone know of where I can get one? I assume it's a standard RGB > Apple RGB type cable. Tempest Quote Link to comment Share on other sites More sharing options...
madmax2069 Posted June 5, 2010 Share Posted June 5, 2010 This might be able to help you a little. http://tinyurl.com/332po9m Quote Link to comment Share on other sites More sharing options...
smariotti Posted May 16, 2011 Share Posted May 16, 2011 This might be able to help you a little. http://tinyurl.com/332po9m You'll find what you need there. Mainly the pinout: Commodore 1084d & 1084dS Analog/Digital Connector 9 PIN D-SUB FEMALE viewed at the monitor _____________ \ 5 4 3 2 1 / \_9_8_7_6_/ Pin Name Analog Mode Digital Mode 1 GND Ground Ground 2 GND Ground Ground 3 R Red Red 4 G Green Green 5 B Blue Blue 6 I not used Intensity 7 CSYNC Composite Sync not used 8 HSYNC not used Horizontal Sync 9 VSYNC not used Vertical Sync ____________________________ of the DB-9 at the 1080/1084 monitor. What's NOT apparent is that you'll need to wire a 75 Ohm resistor between composite sync and ground at the DB-9 end of the cable to attenuate the sync signal so that the commodore monitor is happy with it. I built this cable. It works, with the resistor added 1 Quote Link to comment Share on other sites More sharing options...
