RXB Posted March 8, 2018 Share Posted March 8, 2018 (edited) Well I really screwed this pooch on this one. Found a error in RXB 2015 that does not crash easy but could potentially create a crash. *********************************************************** * CALL MOTION(#SPR,YSPEED,XSPEED,...) *********************************************************** SPRMOV CALL COMB Insure at "(" * RXB PATCH CODE ************* * SPRMV2 CALL SPNUM2 Get sprite number SPRMV2 CALL SPGS # or ALL or GO or STOP SPRMV3 CALL SPMOVE Store velocity SPRMV4 CEQ COMMAZ,@CHAT Loop if more BS SPRMV2 BR GB0F2 * LNKRTN (>A01C) *********************************************************** *********************************************************** * MOTION PATCH for GO and STOP SPGS XML PGMCHR ( or , CEQ ALLZ,@CHAT ALL? BR SPGS1 No. XML PGMCHR Skip ALL XML PGMCHR Skip , DST 1,@FAC First sprite CALL SPNUM5 Get sprite table CALL SPMOVE Store velocity ST 28,@FAC Last sprite DCLR @VAR0 Index SPGSA MOVE 2,V@>0780,V@>0780(@VAR0) DADD 4,@VAR0 Index +4 DEC @FAC Sprite -1 BR SPGSA Done? B SPRMV4 No. (Should put SPRMV4 end routine here.) SPGS1 CEQ NUMBEZ,@CHAT #? BR SPGS2 No. CALL SPNUM6 Standard routine. B SPRMV3 (Should put a RTN here.) SPGS2 CEQ GOZ,@CHAT GO? BR SPGS3 No. AND >BF,@>83C2 GO!!! B SPGS4 Done. SPGS3 CEQ STOPZ,@CHAT STOP? BR ERRSYN No OR >40,@>83C2 STOP!!! SPGS4 XML PGMCHR Skip GO or STOP B SPRMV4 (Should put SPRMV4 end routine here.) *********************************************************** Using a B (branch) instead of a CALL resulted in a return never used in GPL could potentially create a crash or GPL Stack Full. Replaced the B with a CALL and in next version of RXB will have this potential error repaired. Edited March 8, 2018 by RXB 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 8, 2018 Share Posted March 8, 2018 These things keep us all humble. Sometimes I think about making a sign for my wall that says "Bugs-R-US" It's a great BASIC just the same Rich. 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted March 8, 2018 Share Posted March 8, 2018 (edited) I believe I have a legacy copy of GKXB on diskette in my boxes somewhere.... Edited March 8, 2018 by Opry99er 3 Quote Link to comment Share on other sites More sharing options...
Ed in SoDak Posted March 9, 2018 Share Posted March 9, 2018 (edited) Well myself I often run a line number to test a section of code, just figured others do the same thing. Especially when testing multiple versions of the same XB code. The Timex/Sinclair 1000's BASIC allowed either RUN 1700 or GOTO 1000 on the command line. Both from a program that hadn't been run since entering it or loading. Like you, I used that a lot when writing or debugging code to skip all the intro, ect. code. On the TI, I just add a GOTO NN to a program as the first or very early line to jump to where I'm currently working or testing my code. The SXB cart allows a CALL GOTO(variable) and a few other nice features. Set that up as an input in the front of the program and you could just enter the line you wish to jump to and execute from there. -Ed Edited March 9, 2018 by Ed in SoDak Quote Link to comment Share on other sites More sharing options...
RXB Posted March 9, 2018 Share Posted March 9, 2018 The Timex/Sinclair 1000's BASIC allowed either RUN 1700 or GOTO 1000 on the command line. Both from a program that hadn't been run since entering it or loading. Like you, I used that a lot when writing or debugging code to skip all the intro, ect. code. On the TI, I just add a GOTO NN to a program as the first or very early line to jump to where I'm currently working or testing my code. The SXB cart allows a CALL GOTO(variable) and a few other nice features. Set that up as an input in the front of the program and you could just enter the line you wish to jump to and execute from there. -Ed Yea Craig Miller did not like the GOTO (line number) option as he stated it would not work in Re-sequence of line numbers. As you have it in a variable how could you possibly adjust it up or down? This is not even to mention MOVE that moves sections of lines to another line number. Or COPY that duplicates a set of lines to another line number. All of these were included in GKXB by Miller Graphics. (Maybe the reason.) Quote Link to comment Share on other sites More sharing options...
Ed in SoDak Posted March 9, 2018 Share Posted March 9, 2018 Another quirk of the Timex was it didn't care if a line number existed or not. It would simply jump to the following line. That BASIC didn't have a resequence command, but you could run USR routines to add such things. While SXB might support GOTO(A) I don't use it. I keep my programs mostly compatible with TIXB. In my Timer program, I did a VERSION check and branched to code appropriate for whichever cart was mounted. A way to deal with losing a branch with GOTO(A) if you resequence, I kept REM statements at the front of the program noting where things took place in the code and it would be fairly easy to manually update such. SXB allows selective resequencing from line XXXX to YYYY only, so you could expand tight sections or move lines back to where they were or shuffle lines around. Sure, there's other and better ways, but the SXB is pretty flexible. I like elegant programs myself, but mine seldom reach that status. -Ed 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 22, 2018 Share Posted March 22, 2018 Another quirk of the Timex was it didn't care if a line number existed or not. It would simply jump to the following line. That BASIC didn't have a resequence command, but you could run USR routines to add such things. While SXB might support GOTO(A) I don't use it. I keep my programs mostly compatible with TIXB. In my Timer program, I did a VERSION check and branched to code appropriate for whichever cart was mounted. A way to deal with losing a branch with GOTO(A) if you resequence, I kept REM statements at the front of the program noting where things took place in the code and it would be fairly easy to manually update such. SXB allows selective resequencing from line XXXX to YYYY only, so you could expand tight sections or move lines back to where they were or shuffle lines around. Sure, there's other and better ways, but the SXB is pretty flexible. I like elegant programs myself, but mine seldom reach that status. -Ed Just a point of fact SXB and RXB and XB 2.7 use GKXB routines of COPY, RES, MOVE and EDIT commands. Quote Link to comment Share on other sites More sharing options...
RXB Posted March 22, 2018 Share Posted March 22, 2018 Found another error in RXB 2015 that slipped through the cracks since RXB 2001. CALL JOYST(3,X,Y) or CALL JOYST(4,X,Y) will both be accepted and should error out. I used the normal CALL KEY section shared and this was missed by me previously. This will be repaired in RXB 2018 with other errors I am looking for. Quote Link to comment Share on other sites More sharing options...
Casey Posted March 26, 2018 Share Posted March 26, 2018 It looks like RXB works the same way as TI BASIC and TI Extended BASIC do with regard to CALL JOYST. We know that TI reserved joystick units 3 and 4 for "possible future use" like CALL KEY was on the 99/4. Units 3 and 4 were reserved for the never release wireless controllers, right? Is there any way to make use of them with the hardware we have? (Not saying you shouldn't change it to only allow units 1 and 2, but more just curious about the hardware we have now). Quote Link to comment Share on other sites More sharing options...
RXB Posted March 27, 2018 Share Posted March 27, 2018 (edited) It looks like RXB works the same way as TI BASIC and TI Extended BASIC do with regard to CALL JOYST. We know that TI reserved joystick units 3 and 4 for "possible future use" like CALL KEY was on the 99/4. Units 3 and 4 were reserved for the never release wireless controllers, right? Is there any way to make use of them with the hardware we have? (Not saying you shouldn't change it to only allow units 1 and 2, but more just curious about the hardware we have now). Well the same routine as used by the CALL KEY routine was used for CALL JOYST and that routine worked with 0 to 5 thus why you could do CALL JOYST(3,X,Y) or CALL JOYST(4,X,Y) I am not a hardware guy but I do not think that is possible but in GPL Programming Manual (page D2) : "REMOTE KEYBOARD (KEY BOARDS) Remote handsets 3 and 4 can be mapped into a 40 key keyboard in the same manner as handsets 1 and 2 ." And a drawing of Handheld Unit 3 or 4 is shown (page D6) : (It looks just like the Number Pad portion of a standard PC Keyboard.) i.e. Clear 7 8 9 Period Go 4 5 6 X Set 1 2 3 No Next Stop 0 = Yes Key values: 13 7 8 9 A 12 4 5 6 8 11 1 2 3 C 10 F 0 E Q Edited March 27, 2018 by RXB 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 29, 2018 Share Posted March 29, 2018 Just a update on what I am working on today: CALL JOYSTMOTION(keyunit,X,Y,#sprite,Row-velocity,Col-velocity,KEY) GOTO line-number How does this work? keyunit is same as XB normal CALL JOYST(keyunit,X,Y) After that is same as XB normal CALL MOTION(#sprite,Row-velocity,Col-velocity) So here is the kicker, it changes the Row-velocity,Col-velocity to Positive or Negative per JOYSTICK USE: Thus Row-velocity,Col-velocity reflect choice made by the JOYSTICK direction this moves the Sprite for you. If no JOYSTICK movement the SPRITE does not move. (Built in IF joystick THEN move sprite) Ok now what about KEY? This checks the FIRE BUTTON and saves that value for you, but also works with the GOTO line-number If you press the FIRE BUTTON it uses the GOTO line-number, but if no FIRE BUTTON then it goes to next line. Or if you use a :: the next XB command.... Here is a XB Program similar to this single RXB line command: 100 CALL CLEAR 110 CALL SPRITE(#1,65,2,9,190,20,0) 120 CALL JOYST(1,X,Y) 130 CALL MOTION(#1,-(Y*5),(X*5)) 140 CALL KEY(1,K,S) 150 IF K=18 THEN CALL BEEP 160 GOTO 120 Lines 120 to 150 are an approximation of RXB CALL JOYSTMOTION As you can see this would speed up XB programs and eliminate code that slows XB down. Specfically those IF something THEN line-number 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted March 29, 2018 Share Posted March 29, 2018 Specfically those IF something THEN line-number This looks good. Of course the real speed improvement here comes from bundling the three CALLs into one. The more CALLs you can eliminate the better. IF/THEN is way faster than doing a call and there shouldn't be a whole lot of speed increase from including that, although it might help a bit. I am assuming the added stuff is optional - i.e. CALL JOYST(keyunit,X,Y) works normally, or CALL JOYSTMOTION(keyunit,X,Y,#sprite,Row-velocity,Col-velocity) would work without the KEY. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 29, 2018 Share Posted March 29, 2018 (edited) No Key will still be there as it does the same thing as CALL JOYST(keyunit,x,y) & CALL MOTION(#sprite,RV,CV) & IF joystick movement move sprite & CALL KEY(keyunit,Key,S) I can set it up to not use the GOTO line-number but fail to see the reason for that? I guess I could also make KEY and GOTO optional, but why make something then just not use it? By the way when you do a CALL KEY or CALL JOYST it always scans and fills address: >8375 Key, >8376 JOY Y and >8377 JOY X even if you do not use Key or Joystick values. Why would you want to use another CALL KEY as that would be doubling what was done? Edited March 29, 2018 by RXB Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted March 29, 2018 Share Posted March 29, 2018 I guess I could also make KEY and GOTO optional, but why make something then just not use it? Why would you want to use another CALL KEY as that would be doubling what was done? Suppose you only wanted info from the joysticks like munchman and had no need for CALL KEY. If it is always included then you are including an unnecessary extra step. What about CALL JOYST(keyunit,X,Y) without the motion? Is motion optional? Quote Link to comment Share on other sites More sharing options...
RXB Posted March 30, 2018 Share Posted March 30, 2018 Suppose you only wanted info from the joysticks like munchman and had no need for CALL KEY. If it is always included then you are including an unnecessary extra step. What about CALL JOYST(keyunit,X,Y) without the motion? Is motion optional? Let me explain the GPL COMMAND "SCAN" When you use SCAN it goes to the OS ROM zero and ALWAYS fills >8375, >8376, and >8377 even if you only want a key or joystick. So the fact that it fills these ALWAYS does not cost me one single clock cycle more. Now you are correct that GPL ASSIGN a value to KEY will cost me some time and address space. So you are right I should make KEY, and GOTO Line number optional thanks for suggestion. As for this question: "What about CALL JOYST(keyunit,X,Y) without the motion? Is motion optional?" They are separate routines entirely thus share some code: *********************************************************** * SUBPROGRAM FOR 'KEY' *********************************************************** KEY CALL SPAR GET KEY UNIT * RXB PATCH LABEL ************ GABD1 XML SPEED Insure in range BYTE RANGE * of 0 - 5 BYTE 0 DATA 5 CALL KEYJOY Get variables for code and st * and scan keyboard * KEYJOY returns key status BS KEY1B KEY STATUS = 1 DNEG @FAC Assume status = -1 CEQ >FF,@RKEY But correct if = 0 BR KEY1B DCLR @FAC KEY STATUS = 0 KEY1B XML ASSGNV Assign value in variable DST >4001,@FAC Re-store F.P. 1 in FAC CZ @RKEY If key-code = 0 BS KEY2 CEQ >FF,@RKEY No key depressed, BS KEY1C key code assigned to -1 * FORMAT FOR KEYCODES ABOVE 99 ADDED FOR 99/4A HIGHEST * KEYCODE (OTHER THAN >FF) IS >C6=198 * 5/7/81 CHE 100,@RKEY BR GAC04 INC @FAC SUB 100,@RKEY ST @RKEY,@FAC2 FLOATING FORMAT (>4001__00000 B GAC07 GAC04 ST @RKEY,@FAC1 FLOATING FORMAT (>40__0000000 GAC07 BR KEY2A KEY1C DNEG @FAC KEY CODE ASSIGNED TO -1 BR KEY2A KEY2 DCLR @FAC (>000000000000000) KEY2A XML ASSGNV ASSIGN VALUE TO VARIABLE * RXB PATCH CODE ************* * BR LNKRTN RTN *********************************************************** * RXB PATCH WAS SUBPROGRAM FOR 'JOYSTICK' *********************************************************** CALL SPAR KEY UNIT XML SPEED Insure in range BYTE RANGE * of 1 - 4 BYTE 1 DATA 4 CALL KEYJOY GET VARIABLES FOR X, Y * AND SCAN KEYBOARD ST @JOYY,@VAR0 JOYSTICK Y POSITION CALL JOYXY -4 to +4 DST >4001,@FAC Re-store F.P. 1 in FAC ST @JOYX,@VAR0 JOYSTICK X POSITION CALL JOYXY -4 to +4 BR LNKRTN *********************************************************** * INSURE LEFT PARENTHESIS AND THEN PARSE TO A COMMA *********************************************************** * RXB PATCH CODE LPARR CEQ COMMAZ,@CHAT BS CPAR XML SPEED * Must be BYTE SYNCHK * at a BYTE LPARZ * left parenthesis BR CPAR3 * RXB PATCH CODE SAVES 3 BYTES (LOL) * CPAR XML SPEED * BYTE SYNCHK * BYTE COMMAZ CPAR CALL SPAR2 * RXB COMMA SPEED CHECKER * RXB PATCH LABEL *********** CPAR2 XML PARSE Do the parse BYTE COMMAZ * Stop on a comma * RXB PATCH CODE SAVES 3 BYTES (LOL) * XML SPEED * Must be * BYTE SYNCHK * at a * BYTE COMMAZ * left comma CALL SPAR2 * RXB COMMA SPEED CHECKER RTN ***************************** CPAR3 XML SPEED * Similar to LPARR DATA COMMAZ * Syntax check , BR CPAR2 * Parse value *********************************************************** ********************************************************** GKEY1 DST @ENLN,@FAC2 Get last address DSUB 3,@FAC2 Point to first LINE# GKEY2 CALL GRSUB3 Read from VDP/RAM BYTE FAC2 DCEQ @EEE1,@FAC Same? BS GKEY3 Yes, found line# DCH @STLN,@FAC2 No line# left BR ERRLNF ERROR LINE NOT FOUND DSUB 4,@FAC2 Next LINE# BR GKEY2 Loop GKEY3 DST @FAC2,@EXTRAM Got LINE# DADD 4,@EXTRAM Point to begining of line DINCT @EXTRAM Point to ADDRESS DST @EXTRAM,@PGMPTR Set pointer to line to run DINCT @PGMPTR Point to tokens CALL RETURN Return to XB ********************************************************** * SUBPROGRAM FOR 'JOYSTICK' ********************************************************** JOYST CALL SPAR KEY UNIT * RXB PATCH LABEL ************ JOYRPT XML SPEED Insure in range BYTE RANGE * of 1 - 4 BYTE 1 DATA 4 * GET VARIABLES FOR X, Y * AND SCAN KEYBOARD ST @FAC1,@VAR0 Keyboard selection CALL NUMVAR Get variable for key-code CEQ COMMAZ,@CHAT If not comma - error BR ERRSYN XML PGMCHR Get next character CALL NUMVAR Get variable for key-status ST @VAR0,@KEYBD Keyboard selection MOVE 8,G@FLT1,@FAC Set up float SCAN SCAN the keyboard * RXB PATCH CODE SAVE KEY & JOYST ST @RKEY,@FNUM KEY VALUE DST @JOYY,@VAR9 JOYY & JOYX CLR @KEYBD Clear the code(No affect on s ST @JOYY,@VAR0 JOYSTICK Y POSITION CALL JOYXY -4 to +4 DST >4001,@FAC Re-store F.P. 1 in FAC ST @JOYX,@VAR0 JOYSTICK X POSITION CALL JOYXY -4 to +4 RTN *********************************************************** ZJOYST CALL JOYST JOYAGN CEQ COMMAZ,@CHAT BR LNKRTN CALL CPAR3 CALL JOYRPT BR JOYAGN ************************************************************ * CALL JOYMOTION(keyunit,X,Y,#sprite,R-vel,C-vel,KEY,..) ************************************************************ ZJOMO CALL JOYST * Get Key unit, X & Y CEQ COMMAZ,@CHAT * COMMA? BR ERRSYN * SYNTAX ERROR XML PGMCHR * Skip COMMA CEQ NUMBEZ,@CHAT * #? BR ERRSYN * SYNTAX ERROR CALL SPNUM3 * SPSAL=SPRITE ADDRESS CALL COMMA * Parse up to comma and skip CALL RANGEV * Check if numeric and convert * to integer ST @FAC1,@SPTMP * Store Y velocity XML PARSE * Get X velocity BYTE RPARZ * Check for ")" or less CALL RANGEV * Numeric check and convert * to integer ST @SPTMP,@FAC * @FAC=Y velocity, @FAC1=X velocity * CHECK DIRECTION OF JOYST AND SET UP FAC FOR LOADING VALUES DCEQ >0000,@VAR9 * >0000 JOYST BR ZJOMO1 DCLR @FAC ZJOMO1 DCEQ >0400,@VAR9 * UP BR ZJOMO2 CLR @FAC1 ZJOMO2 DCEQ >FC00,@VAR9 * DOWN BR ZJOMO3 NEG @FAC CLR @FAC1 ZJOMO3 DCEQ >00FC,@VAR9 * LEFT BR ZJOMO4 CLR @FAC NEG @FAC1 ZJOMO4 DCEQ >0004,@VAR9 * RIGHT BR ZJOMO5 CLR @FAC ZJOMO5 DCEQ >04FC,@VAR9 * UPLEFT BR ZJOMO6 NEG @FAC1 ZJOMO6 DCEQ >0404,@VAR9 * UPRIGHT BR ZJOMO7 ZJOMO7 DCEQ >FCFC,@VAR9 * DOWNLEFT BR ZJOMO8 NEG @FAC NEG @FAC1 ZJOMO8 DCEQ >FC04,@VAR9 * DOWNRIGHT BR ZJOMO9 NEG @FAC ZJOMO9 CALL SPMOVG * Load Sprite values, pass to XB CEQ COMMAZ,@CHAT * COMMA? BR ERRSYN * SYNTAX ERROR XML PGMCHR * Skip COMMA CEQ 18,@FNUM * FIRE BUTTON? BR ZJOMOA * No DST 18,@FAC * Load FIRE KEY XML CIF * Convert to floating point XML ASSGNV * Put put 18 in KEY variable ZJOMOA CEQ RPARZ,@CHAT * )? BR ERRSYN * SYNTAX ERROR XML PGMCHR * Skip ) CEQ GOTOZ,@CHAT * GOTO flag? BR ERRSYN * SYNTAX ERROR XML PGMCHR * Skip GOTO CEQ LNZ,@CHAT * Line# token? BR ERRSYN * SYNTAX ERROR XML PGMCHR * Skip line# token ST @CHAT,@FAC * Store high byte line# XML PGMCHR * Skip high byte line# ST @CHAT,@FAC1 * Store low byte line# XML PGMCHR * Skip low byte line# B GKEY1 * Find Line# and run it ********************************************************** Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted March 30, 2018 Share Posted March 30, 2018 Sorry, I feel like a dope for asking that. I thought you had modified CALL JOYST to do all those things, when actually it is a new program CALL JOYSTMOTION. Now I see the light! 3 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted March 30, 2018 Share Posted March 30, 2018 A very interesting subprogram. Combines many things into one simple call. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 30, 2018 Share Posted March 30, 2018 (edited) Going to make another one: CALL JOYSTLOCATE(keyunit,X,Y,#sprite,Row,Column,INDEX,KEY) GOTO line-number This would LOCATE a SPRITE by adding INDEX to the location like say 8 pixels to location according to JOYST INDEX could be any value needed, so not smooth like motion but jumping sprite to where you want per JOYST I will also make it like motion so you can eliminate KEY and GOTO line-number if you choose. Of course the Row and Column will be updated when returned values go back to XB, this would mean Row and Column are always the last location for the sprite on screen. Edited March 30, 2018 by RXB 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted March 30, 2018 Share Posted March 30, 2018 CALL JOYSTMOTION(keyunit,X,Y,#sprite,Row-velocity,Col-velocity,KEY) GOTO line-number I think you could make this even more versatile. You really don't need to know what key was pressed-it will be the fire button or nothing, so get rid of the KEY. There are three possible states for the fire button: not pressed; newly pressed; and held down more than one cycle. So as an idea you might make it work this way: 10 CALL JOYSTMOTION(keyunit,X,Y,#sprite,Row-velocity,Col-velocity) 100 ELSE 200 20 !fire button not pressed 100 !fire button newly pressed 200 !fire button held down Probably should make the 100 ELSE 200 optional. If the fire button is not used by the program then just go on to the next line. Also probably should make the ELSE 200 optional, same as it is when using an IF/THEN statement. 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted March 30, 2018 Share Posted March 30, 2018 ^^likey^^ Quote Link to comment Share on other sites More sharing options...
RXB Posted March 30, 2018 Share Posted March 30, 2018 (edited) CALL JOYSTMOTION(keyunit,X,Y,#sprite,Row-velocity,Col-velocity,KEY) GOTO line-number I think you could make this even more versatile. You really don't need to know what key was pressed-it will be the fire button or nothing, so get rid of the KEY. There are three possible states for the fire button: not pressed; newly pressed; and held down more than one cycle. So as an idea you might make it work this way: 10 CALL JOYSTMOTION(keyunit,X,Y,#sprite,Row-velocity,Col-velocity) 100 ELSE 200 20 !fire button not pressed 100 !fire button newly pressed 200 !fire button held down Probably should make the 100 ELSE 200 optional. If the fire button is not used by the program then just go on to the next line. Also probably should make the ELSE 200 optional, same as it is when using an IF/THEN statement. How would I know the FIRE button has been held down? In XB a variable saves that value so where in GPL am I going to permanently store this? Scratch pad? (Already to cramped for space) VDP RAM? (RXB already has just about reached any limit for those locations I am already using >3EFF that is reserved) I guess KEY is not needed but the GOTO is required, but I could use the ELSE CALL JOYSTMOTION(keyunit,X,Y,#sprite,Row-velocity,Col-velocity,KEY) GOTO line-number ELSE line-number If key pressed GOTO line-number and if key held down ELSE line-number if no key next line. And both optional as before. Thanks I guess I could remove KEY. But have no clue how to save KEY and where unless it is included and I checked if it was 18 previously? So I guess KEY is required to be used to check if previously if KEY was pressed for held down. Edited March 30, 2018 by RXB Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted March 31, 2018 Share Posted March 31, 2018 Quite simple once you know how. Do a KSCAN. After KSCAN >8375 has the key that was pressed, or >FF if no key was pressed. Then check the status byte at >837C. If bit 2 is set then a new key was pressed. If bit 2 is not set and >8375 is not >FF then the same key was held down. Dunno how to do it in GPL, but here is one way do do it in assembly: HXFF00 DATA >FF00 HX2000 DATA >2000 CB @>8375,@HXFF00 JEQ NOKEY MOV @>837C,R1 COC @HX2000,R1 JNE SAMEK JEQ NEWK I am assuming that after finishing the stuff within the parentheses you then jump to the XB code directly after the parenthesis (i.e. GOTO linenumber ELSE linenumber). If so I think XB would permit more than just GOTO. You should be able to execute the more complicated code allowed with IF/THEN/ELSE. Quote Link to comment Share on other sites More sharing options...
RXB Posted March 31, 2018 Share Posted March 31, 2018 Quite simple once you know how. Do a KSCAN. After KSCAN >8375 has the key that was pressed, or >FF if no key was pressed. Then check the status byte at >837C. If bit 2 is set then a new key was pressed. If bit 2 is not set and >8375 is not >FF then the same key was held down. Dunno how to do it in GPL, but here is one way do do it in assembly: HXFF00 DATA >FF00 HX2000 DATA >2000 CB @>8375,@HXFF00 JEQ NOKEY MOV @>837C,R1 COC @HX2000,R1 JNE SAMEK JEQ NEWK I am assuming that after finishing the stuff within the parentheses you then jump to the XB code directly after the parenthesis (i.e. GOTO linenumber ELSE linenumber). If so I think XB would permit more than just GOTO. You should be able to execute the more complicated code allowed with IF/THEN/ELSE. IF THEN ELSE are tokens but the GPL code for IF is way different then what I am doing and would require tons of code. I am using the GOTO token but not the normal GPL code same with ELSE I can use the token but not the actual routines. Besides if you need the KEY for additions routines how would you know if the key was pressed if you have no variable? Also I can make it so it returns any key-pressed to the KEY thus accomplish more then one function at once. Hitting a key on keyboard like SPACE or ENTER or Q or the FIRE Button, yet only the FIRE button responds to the GOTO line-number THEN line-number I can think of a Flight Simulator in XB that would like that feature. Or a CAR shifting gears or Brake or Hand Brake slides... Your view would turn into a major rewrite of the code for IF THEN ELSE just to make this work, much more involved then I want to spend time on when current code can do almost exactly the same thing without out major rewrites. Quote Link to comment Share on other sites More sharing options...
RXB Posted April 2, 2018 Share Posted April 2, 2018 Hello well I found out what happens when you use the Ryte Data GPL Assembler and generate to many labels...it crashed! I had so many labels in my source that the GPL Assembler ran out of space to make a DSR for creating a Object or LIst files. Understandable I had thousands of labels and just ate up all the VDP of the 12K VDP available. I want to thank Tursi for volunteering to help solve this madding problem I have had for 2 weeks. Quite by accidentally was looking for errors and removed a number of duplicate labels and the GPL Assembler did not crash? While looking at the VDP memory using Classic99 it looked like it just stopped generating labels so that confirmed what I suspected. Quote Link to comment Share on other sites More sharing options...
RXB Posted April 10, 2018 Share Posted April 10, 2018 Hello Well major changes to RXB future updates I ran out of GROM space finally. In order to fix this issue I am forced to eliminate some RXB commands: CALL PROTECT(pathname,filename,flag) CALL RMDIR(pathname,directory-name) CALL SCSI(pathname,string-variable) CALL SECTOR(pathname,read/write-flag,#sectors,sector-string) Because SECTOR was for Hard Drives or Disk it was huge. The only other way to get more space is to eliminate REA or move it to another GROM page, not likely. 1 Quote Link to comment Share on other sites More sharing options...
