gHan2000 Posted September 4, 2010 Share Posted September 4, 2010 I have downloaded the Mac OSX version of bB, but I need help installing. I know there are instructions on the website, but those are CONFUSING. Can someone show give a better example of how to install it? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 4, 2010 Share Posted September 4, 2010 So you can't run software as if you have a Microsoft PC? If you can, you can use VbB and everything will be easier: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#gettingstarted Quote Link to comment Share on other sites More sharing options...
+batari Posted September 4, 2010 Share Posted September 4, 2010 bB is a command-line program. It is set up and run from the terminal application in OS X. Download the PC version, then the Mac binaries to the desktop, linked below (ctrl-click, save as, and make sure they are saved to the desktop): http://bataribasic.com/batari_Basic_version_1.0.zip http://bataribasic.com/bB_OSX_binaries_version_1.0.zip Run the terminal app, then the following will install it: cd ~ mkdir Atari2600 cd Atari2600 mkdir bB cd bB unzip ~/desktop/batari_Basic_version_1.0.zip unzip ~/desktop/bB_OSX_binaries_version_1.0.zip Close the terminal app, and reopen (this is also how you run it from now on): Type the following two lines to set up the environment. This only needs to be done once per terminal session: export bB=~/Atari2600/bB export PATH=$PATH:$bB (If you add the above two lines to /etc/bashrc, this doesn't need to be done every terminal session. Only change /etc/bashrc if you know what you are doing and are comfortable editing your system files.) Now test your setup: cd ~/Atari2600/bB/samples 2600basic.sh sample.bas Now try sample.bas.bin in an emulator (located in your home folder, under Atari2600/bB/samples.) Quote Link to comment Share on other sites More sharing options...
gHan2000 Posted October 6, 2010 Author Share Posted October 6, 2010 bB is a command-line program. It is set up and run from the terminal application in OS X. Download the PC version, then the Mac binaries to the desktop, linked below (ctrl-click, save as, and make sure they are saved to the desktop): http://bataribasic.com/batari_Basic_version_1.0.zip http://bataribasic.com/bB_OSX_binaries_version_1.0.zip Run the terminal app, then the following will install it: cd ~ mkdir Atari2600 cd Atari2600 mkdir bB cd bB unzip ~/desktop/batari_Basic_version_1.0.zip unzip ~/desktop/bB_OSX_binaries_version_1.0.zip Close the terminal app, and reopen (this is also how you run it from now on): Type the following two lines to set up the environment. This only needs to be done once per terminal session: export bB=~/Atari2600/bB export PATH=$PATH:$bB (If you add the above two lines to /etc/bashrc, this doesn't need to be done every terminal session. Only change /etc/bashrc if you know what you are doing and are comfortable editing your system files.) Now test your setup: cd ~/Atari2600/bB/samples 2600basic.sh sample.bas Now try sample.bas.bin in an emulator (located in your home folder, under Atari2600/bB/samples.) Thanks, I will try that. Quote Link to comment Share on other sites More sharing options...
gHan2000 Posted October 6, 2010 Author Share Posted October 6, 2010 I have downloaded the Mac OSX version of bB, but I need help installing. I know there are instructions on the website, but those are CONFUSING. Can someone show give a better example of how to install it? If anyone has an installed Mac OS X version of bB, please put it on MegaUpload or MediaFire or something. Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted May 10, 2011 Share Posted May 10, 2011 So I'm all excited to try out the new bB 1.1 beta, but I can't seem to get things to work on my Mac. I've made the bB 1.1 beta folder at the root (~) directory and copied in the Mac OS binaries but it doesn't seem to recognize the new DPC+ kernel. Here's what I'm doing at the Terminal level - am I missing something simple? Last login: Tue May 10 16:46:28 on ttys000 imac-2:~ Todd$ export bB=~/bB/ imac-2:~ Todd$ export PATH=$PATH:$bB imac-2:~ Todd$ cd bB imac-2:bB Todd$ ls 2600bas.bat makefile 2600bas.c msdpc.bas 2600basic msdpc.bas.asm 2600basic.exe msdpc.bas.bin 2600basic.sh optimize 2600basic_variable_redefs.h optimize.exe README.txt optimize.lex bB.asm postprocess dasm postprocess.c dasm.exe postprocess.exe includes preprocess includes.bB preprocess.exe keywords.c preprocess.lex keywords.h statements.c license.txt statements.h mac-readme.txt imac-2:bB Todd$ 2600basic.sh msdpc.bas Starting build of msdpc.bas (2) Parse error: unrecognized character ";" (1): set kernel: kernel name unknown or unspecified 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left 2878 bytes of ROM space left Complete. Build complete. imac-2:bB Todd$ Quote Link to comment Share on other sites More sharing options...
RevEng Posted May 10, 2011 Share Posted May 10, 2011 Can you "echo $PATH"? From the error it looks like it's using the old bB directory, since it doesn't understand the semicolon comments in msdpc.bas. Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted May 11, 2011 Share Posted May 11, 2011 So RevEng has figured out that my Mac OS X binaries are too old to run the beta version. Does anyone have the latest binaries so I don't have to boot up in Windows? Thanks! Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted May 11, 2011 Share Posted May 11, 2011 Disregard - I just fixed the problem using the "make" command in the bB folder after installing the Xcode Tools from the Mac OS X Install DVD. Thanks to RevEng for all his help! Quote Link to comment Share on other sites More sharing options...
DemonoidTentacle Posted September 16, 2013 Share Posted September 16, 2013 bB is a command-line program. It is set up and run from the terminal application in OS X. Download the PC version, then the Mac binaries to the desktop, linked below (ctrl-click, save as, and make sure they are saved to the desktop): http://bataribasic.com/batari_Basic_version_1.0.zip http://bataribasic.com/bB_OSX_binaries_version_1.0.zip Run the terminal app, then the following will install it: cd ~ mkdir Atari2600 cd Atari2600 mkdir bB cd bB unzip ~/desktop/batari_Basic_version_1.0.zip unzip ~/desktop/bB_OSX_binaries_version_1.0.zip Close the terminal app, and reopen (this is also how you run it from now on): Type the following two lines to set up the environment. This only needs to be done once per terminal session: export bB=~/Atari2600/bB export PATH=$PATH:$bB (If you add the above two lines to /etc/bashrc, this doesn't need to be done every terminal session. Only change /etc/bashrc if you know what you are doing and are comfortable editing your system files.) Now test your setup: cd ~/Atari2600/bB/samples 2600basic.sh sample.bas Now try sample.bas.bin in an emulator (located in your home folder, under Atari2600/bB/samples.) I've been trying this over and over again, and I still haven't gotten this to work on my Mac. Is there a step missing? I'm sure I'm entering it into my terminal correctly, as I'm simply copy and pasting each step as I get to it. This it what it says in my terminal after I follow the last stop of testing my setup: Starting build of sample.bas /Users/bc/Atari2600/bB/2600basic.sh: line 3: /Users/bc/Atari2600/bB/preprocess: Bad CPU type in executable /Users/bc/Atari2600/bB/2600basic.sh: line 3: /Users/bc/Atari2600/bB/2600basic: Bad CPU type in executable Compilation failed. Any ideas? It's a little embarrassing that I want to get back into casual programming, but can't even run the program If it's worth anything, I'm running OSX 10.8.4 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 16, 2013 Share Posted September 16, 2013 Personally, I can't imagine using bB without VisualbB for the IDE. I'd take the lazy way out and buy a copy of Parallels. Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 16, 2013 Share Posted September 16, 2013 The bB binaries from batari are PPC based, which is why you're getting the error you are. The instructions used to work, but OS X moved on. I'm not an OS X guy, but I believe the following should work... 1. Download this version as it has bug fixes and updates, both from batari and myself. Unzip it somewhere convenient, ensuring directory structure is preserved. 2. Install XCode Tools from the OS X Install DVD, if it already isn't installed. 3. Open a console window and "cd" to where you unzipped bB in step 1. 4. Type... make echo export bB=$(pwd) >> ~/.profile echo 'export PATH=$PATH:$bB' >> ~/.profile 5. Open another console window to test things out, or source your profile again in the same console window with ". ~/.profile" You probably will need to track down dasm and build and install that as well, since bB doesn't distribute the source for it. Quote Link to comment Share on other sites More sharing options...
DemonoidTentacle Posted September 16, 2013 Share Posted September 16, 2013 (edited) The bB binaries from batari are PPC based, which is why you're getting the error you are. The instructions used to work, but OS X moved on. I'm not an OS X guy, but I believe the following should work... 1. Download this version as it has bug fixes and updates, both from batari and myself. Unzip it somewhere convenient, ensuring directory structure is preserved. 2. Install XCode Tools from the OS X Install DVD, if it already isn't installed. 3. Open a console window and "cd" to where you unzipped bB in step 1. 4. Type... make echo export bB=$(pwd) >> ~/.profile echo 'export PATH=$PATH:$bB' >> ~/.profile 5. Open another console window to test things out, or source your profile again in the same console window with ". ~/.profile" You probably will need to track down dasm and build and install that as well, since bB doesn't distribute the source for it. Cheers for that, I'll be giving that a shot when I get home from work. UPDATE: I followed these step by step (with the exception of Xcode Tools and I already have it), and yet I am still not up and running. As I do step 5, nothing happens after that in my terminal. There's no error, or positive sign. I just proceed to the next line in my terminal. Help? Edited September 17, 2013 by DemonoidTentacle Quote Link to comment Share on other sites More sharing options...
+batari Posted September 18, 2013 Share Posted September 18, 2013 Cheers for that, I'll be giving that a shot when I get home from work. UPDATE: I followed these step by step (with the exception of Xcode Tools and I already have it), and yet I am still not up and running. As I do step 5, nothing happens after that in my terminal. There's no error, or positive sign. I just proceed to the next line in my terminal. Help? If you are running Snow Leopard or older, you can install Rosetta (see here: http://support.apple.com/kb/ph6531 Of if running Lion or newer, build at the command like with Xcode, but no need to go through the GUI. Just go to the source directory (where Makefile is located) and type make. Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted September 18, 2013 Share Posted September 18, 2013 Cheers for that, I'll be giving that a shot when I get home from work. UPDATE: I followed these step by step (with the exception of Xcode Tools and I already have it), and yet I am still not up and running. As I do step 5, nothing happens after that in my terminal. There's no error, or positive sign. I just proceed to the next line in my terminal. Help? I just installed RevEng's bB.1.1d on my Macbook without any problems. Download RevEng's version as above and I renamed the folder bB and put in my root folder. Copy the OS X binaries (listed earlier in this thread) over the existing files in that folder. Then in Terminal, cd to bB and do the "make" command. In order to get the compiler to work properly, type this in now and whenever you start up Terminal: export PATH=$PATH:$bB export bB=$HOME/bB Move zombie_chase.bas out of the samples folder to the bB folder (I've never been able to get it to compile in another folder) and test it out: 2600basic.sh zombie_chase.bas Hope that helps - good luck! Quote Link to comment Share on other sites More sharing options...
DemonoidTentacle Posted September 18, 2013 Share Posted September 18, 2013 (edited) Ok everyone, a big thankyou for all the help I am getting on this, I'm getting further But now I'm getting this: Starting build of zombie_chase.bas batari Basic v1.01dreveng17 ©2005-2013 2600 Basic compilation complete. /Users/bc/bB/2600basic.sh: line 15: /Users/bc/bB/dasm: Bad CPU type in executable Build complete. I'm assuming that dasm is for PPC as opposed to Intel processor (which is what I've got) I'm researching a workaround now. EDIT: I just found this thread http://atariage.com/forums/topic/185212-dasm-for-intel-macs/ Good news... IT'S WORKING!!! Thanks again everyone for your help with this. Now I have a late night ahead of me full of tinkering madness. Edited September 18, 2013 by DemonoidTentacle Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 18, 2013 Share Posted September 18, 2013 [...] export PATH=$PATH:$bB export bB=$HOME/bB [...] (I've never been able to get it to compile in another folder) [...] Try reordering your export lines, and compiling in other folders should work. Your first line PATH update isn't working right because $bB isn't defined yet. Better yet, edit the .profile in your home directory and throw these lines at the end. Every new console you open will have these variables set automatically. Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted September 19, 2013 Share Posted September 19, 2013 Try reordering your export lines, and compiling in other folders should work. Your first line PATH update isn't working right because $bB isn't defined yet. Better yet, edit the .profile in your home directory and throw these lines at the end. Every new console you open will have these variables set automatically. Thanks - I wish you would've told me this about 5 years ago! I know so little about Unix... Quote Link to comment Share on other sites More sharing options...
Coolcrab Posted December 7, 2017 Share Posted December 7, 2017 The bataribasic.com page seems to have expired. are there any MacOS mirrors? Quote Link to comment Share on other sites More sharing options...
pedgarcia Posted December 7, 2017 Share Posted December 7, 2017 I believe you can find everything at http://7800.8bitdev.org/index.php/Batari_basic Paulo Quote Link to comment Share on other sites More sharing options...
