Macros
SeaGtGruff
It's fine by me, though it should probably be replaced by my first suggestion (that didn't work) if the power-of-two thing is fixed.
I'll report it in the bug thread later today.
You might also want to make a note on your bB page that you can't use any commands that use a library inside a macro, within a bankswitched game. (pf* commands, multiplying by numbers that aren't powers of two, etc.)
OK, thanks. I'll do that later this afternoon when I get back. Sure is nice to get this fixed so quickly. Now I can get back to working on my program. :thumbsup:
I'm getting lost.
Here's an excerpt of the code from:
http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#nybblemethis
  rem  ****************************************************************
  rem  *  Reusable macros for nybble variables.
  rem  *
  macro set_lo_nibble
  {1}={1}&$F0
  {1}={1}|({2}&$0F)
end
  macro set_hi_nibble
asm
  lda {1}
  and #$0f
  sta {1}
  lda {2}
  asl
  asl
  asl
  asl
  ora {1}
  sta {1}
end
end
  rem  *  One variable is split into two thanks to
  rem  *  macro and def.
  rem  *
  def PEEK_Game_Level=a&$0F
  def POKE_Game_Level=callmacro set_lo_nibble a
  def PEEK_Hit_Points=a/16
  def POKE_Hit_Points=callmacro set_hi_nibble a
That looks to me like set_lo_nibble and set_hi_nibble both want
two parameters and are both only being passed one,
am I missing something?
If you use exclusive or to swap in nibbles
you'll only get the bit's you mask for,
So I'd (re)write RevEng's code like this:
  macro set_hi_nibble
asm
  lda {2}
  asl
  asl
  asl
  asl
  eor {1}
  and #$F0
  eor {1}
  sta {1}
end
end
It might even be possible to write something that
swapped different nibbles depending on a parameter
(I haven't tryed, didn't seem worth it)
I haven't figured out when and where bBasic will choke
on complex expressions.
If bBasic fails to recognize powers of 2 greaer than 3,
would something like this work (again using an xor swap)
(1)=(2)*4*4^(1)&$F0^(1)
(I don't know how many parentheses you'd have to stick in
there to get the order of execution right or if that would
make bBasic choke)
Edited by bogax
I'm getting lost.
If you just want to use the nybble variables, you don't need to know the details.
Here's a simple example that just gives a nybble variable the value of five:
POKE_My_Variable 5
Here's an example that increases it by one:
temp5 = (PEEK_My_Variable) + 1 : POKE_My_Variable temp5
POKE and PEEK is all you have to know.
Edited by Random Terrain
POKE_My_Variable 5
Oh, OK, I get it
def is a simple substitution so that that expands to something like:
callmacro set_lo_nibble a 5
The def statement supplies the first parameter and you supply the
second where you invoke the def'd name.
Finally installed bB :P
macro set_hi_nibble
{1}=(({2}*4*4^{1})&$F0)^{1}
end
Compiles just as one would hope
.L00 ;  macro set_hi_nibble
MAC set_hi_nibble
.L01 ;  {1} =  (  ( {2} * 4 * 4 ^ {1} )  & $F0 )  ^ {1}
; complex statement detected
LDA {2}
asl
asl
asl
asl
EOR {1}
AND #$F0
EOR {1}
STA {1}
ENDM
  macro set_hi_nibble
end
Holy crap, that's awesome! So the new-and-improved macros and defs would look like this:
  macro set_lo_nibble
  {1}=(({2}^{1})&$0F)^{1}
end
  macro set_hi_nibble
end
  def PEEK_game_level=a&$0F
  def POKE_game_level=callmacro set_lo_nibble a
  def PEEK_hit_points=a/4/4
  def POKE_hit_points=callmacro set_hi_nibble a
No need to include div_mul.asm, and it automatically keeps the POKEs within the legal values of 0 to 15! icon_lust.gif
Michael
Here's a slight revision to the defs that use dims for the variable names-- in case it's easier than remembering which letters to use:
  macro set_lo_nibble
end
  macro set_hi_nibble
end
  dim game_level=a
  dim hit_points=a
  dim moose_tracks=b
  dim rabbit_ears=b
  dim saucer_speed=c
  dim something_else=c
  def PEEK_game_level=game_level&$0F
  def POKE_game_level=callmacro set_lo_nibble game_level
  def PEEK_hit_points=hit_points/4/4
  def POKE_hit_points=callmacro set_hi_nibble hit_points
  def PEEK_moose_tracks=moose_tracks&$0F
  def POKE_moose_tracks=callmacro set_lo_nibble moose_tracks
  def PEEK_rabbit_ears=rabbit_ears/4/4
  def POKE_rabbit_ears=callmacro set_hi_nibble rabbit_ears
  def PEEK_saucer_speed=saucer_speed&$0F
  def POKE_saucer_speed=callmacro set_lo_nibble saucer_speed
  def PEEK_something_else=something_else/4/4
  def POKE_something_else=callmacro set_hi_nibble something_else
Of course, you still need to remember whether a given nibble variable uses the lo nibble or the hi nibble, and use the correct defs for that type of nibble variable.
For a lo nibble variable:
dim lonibblevariable=x
def PEEK_lonibblevariable=lonibblevariable&$0F
def POKE_lonibblevariable=callmacro set_lo_nibble lonibblevariable
For a hi nibble variable:
dim hinibblevariable=y
def PEEK_hinibblevariable=hinibblevariable/4/4
def POKE_hinibblevariable=callmacro set_hi_nibble hinibblevariable
Michael
Edited by SeaGtGruff
  • 4 years later...
Ok, which is the one to be used to call the variable "a" on the code in this example
Peek or poke?
Or can I call directly _Game_Level on the code?
Edited by STGraves
  • 7 years later...
Edit: I was wrong, please disregard what I asked before this edit.
So from what I gather, PEEK is the "read" and POKE is the "write", is that correct?
Example: If I want to split the m variable in 2, calling one _M0 and the other _M1, would I read it as:
  if PEEK_M1 = 10 then goto __Label
And write it as
  POKE_M1 10
Without the use of the = sign? Is this correct? So far in testing it all seems to work.
Edited by freshbrood
Variables are rolling over from 0 to 15
I started BASIC programming after systems that used PEEK and POKE heavily.  So, the terminology is awkward for me brains.
You might think about re-naming your defines to keep things straight in your head.
 def read_mapx=mapxy&$0F
 def write_mapx=callmacro _Set_Lo_Nibble mapxy
 def read_mapy=mapxy/4/4
 def write_mapy=callmacro _Set_Hi_Nibble mapxy
Gem I appreciate your responses but a more direct answer would help me better. I get confused easily myself.
(Yes, that's pretty much how they work/no, not exactly etc..) I'm assuming it's yes then, I understand it correctly.
(Also still trying to get an answer on if x is dedicated to use in MASE)
As a non coder-coder I actually appreciate using the proper terms as they may help me learn other "proper" languages.
Thanks again.
