GrizzLee Posted October 13, 2010 Share Posted October 13, 2010 Title says it all. I've owned several ADAMS over the years, none ever have sound with the Atari module. Is there an EASY fix? OR am I looking at building custom circuitry? -Lee Quote Link to comment Share on other sites More sharing options...
jblenkle Posted October 13, 2010 Share Posted October 13, 2010 Title says it all. I've owned several ADAMS over the years, none ever have sound with the Atari module. Is there an EASY fix? OR am I looking at building custom circuitry? -Lee As I recall, the sound output on the Atari module will only work when hooked up to the ColecoVision, not the ADAM...or at least not the ADAM if you are using a monitor cable to output the video and sound. My memory is fuzzy on this. I'm sure NIAD Jim knows. Quote Link to comment Share on other sites More sharing options...
NIAD Posted October 13, 2010 Share Posted October 13, 2010 (edited) Title says it all. I've owned several ADAMS over the years, none ever have sound with the Atari module. Is there an EASY fix? OR am I looking at building custom circuitry? -Lee As I recall, the sound output on the Atari module will only work when hooked up to the ColecoVision, not the ADAM...or at least not the ADAM if you are using a monitor cable to output the video and sound. My memory is fuzzy on this. I'm sure NIAD Jim knows. Dude! You got me. I can actually state for a fact that I never plugged-in an Exp. Mod. #1 - Atari VCS Adaptor to an ADAM Computer. The only time I used the VCS Adaptor was with a ColecoVision system. The method of Audio/Video hookup (RF Box and Cable or Monitor Cable) on the Stand-Alone system should not matter. GrizzLee... do you have a Stand-Alone ADAM or the Exp. Mod. #3 ADAM? Does anyone else know the answer? Edited October 13, 2010 by NIAD Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted October 13, 2010 Share Posted October 13, 2010 Title says it all. I've owned several ADAMS over the years, none ever have sound with the Atari module. Is there an EASY fix? OR am I looking at building custom circuitry? -Lee As I recall, the sound output on the Atari module will only work when hooked up to the ColecoVision, not the ADAM...or at least not the ADAM if you are using a monitor cable to output the video and sound. My memory is fuzzy on this. I'm sure NIAD Jim knows. Dude! You got me. I can actually state for a fact that I never plugged-in an Exp. Mod. #1 - Atari VCS Adaptor to an ADAM Computer. The only time I used the VCS Adaptor was with a ColecoVision system. The method of Audio/Video hookup (RF Box and Cable or Monitor Cable) on the Stand-Alone system should not matter. GrizzLee... do you have a Stand-Alone ADAM or the Exp. Mod. #3 ADAM? Does anyone else know the answer? What's this all about? I could swear I used an Expansion Module #1 on my ADAM when I was a kid, and I don't recall ever having any sound problems. I think I'd remember something like that... Quote Link to comment Share on other sites More sharing options...
ed1475 Posted October 13, 2010 Share Posted October 13, 2010 (edited) Title says it all. I've owned several ADAMS over the years, none ever have sound with the Atari module. Is there an EASY fix? OR am I looking at building custom circuitry? -Lee The Atari module has sound with the Adam if you use RF output. It sounds like you're using the "Aux video" output for video & sound. I've got a homemade "Aux video" cable and I can't get sound from the Atari module either unless I use the RF output cable. The Atari module only has RF sound output. Edited October 13, 2010 by ed1475 Quote Link to comment Share on other sites More sharing options...
GrizzLee Posted October 13, 2010 Author Share Posted October 13, 2010 Title says it all. I've owned several ADAMS over the years, none ever have sound with the Atari module. Is there an EASY fix? OR am I looking at building custom circuitry? -Lee The Atari module has sound with the Adam if you use RF output. It sounds like you're using the "Aux video" output for video & sound. I've got a homemade "Aux video" cable and I can't get sound from the Atari module either unless I use the RF output cable. The Atari module only has RF sound output. Ahhh, that makes a bit more sense. No solutions though eh?? Yes, I run my ADAM using A/V cables. I modified my Adam so I don't need the funky din connector (I addded another RCA jack for the sound. But no sound when the Atari module is plugged in). -Lee Quote Link to comment Share on other sites More sharing options...
