Surprise! Donkey Kong with Pokey sound
168 replies to this topic
#151 darryl1970 OFFLINE
darryl1970
    Dragonstomper
  • 531 posts
Posted Thu Nov 1, 2012 8:01 PM
Really cool. I noticed you moved the hammer on the first screen too. There was SO much wrong with this version, but I am starting to see something great come out of it.
#152 NightSprinter OFFLINE
NightSprinter
  • 2,020 posts
Posted Fri Nov 2, 2012 11:48 AM
The only other improvement I could think of off the top of my head would be regarding the barrels on the first screen. Is it possible to get the ones that make the fireballs be blue in color with the skulls on the lids?
#153 tep392 OFFLINE
tep392
  • 1,945 posts
Posted Sat Nov 3, 2012 4:32 PM
I have a question for the color guru's here. How do a convert an NTSC color to PAL? All the colors are setup for NTSC right now. I took a guess at the PAL colors but they don't look the same. Can anyone help?
#154 darryl1970 OFFLINE
darryl1970
    Dragonstomper
  • 531 posts
Posted Sat Nov 3, 2012 5:06 PM
I'm attaching screenshots explaining the difference of spring landing between the Arcade and 7800. While doing so I noticed why the spring land points are different:
In the above, the Arcade and 7800 land perfectly the same. Jumpman is able to stand at the top of the ladder without issue.
Now here:
Notice how Jumpman is able to safely stay by the edge of the second set of elevators while the springs go overhead in the Arcade. This is crucial to be able to do in later stages of the game as the springs are too fast to make it up the last ladder to Pauline from the previous ladder. You need the extra second or two provided by being at that placement and then make the dash for the ladder.
You can't do that in the 7800, as the spring - as the screenshot shows, falls directly in the spot. However, looking at both sets of screenshots shows the real problem:
While the Arcade level has been stretched horizontally to meet the 7800 resolution, it was not done so in a proportional manner. Look at the start and end marks of structures as they are not in the same spot correspondingly to what is adjacent as in the Arcade. The distances are not proportionally the same. Start and end points are different - spacing is different.
Unfortuantely, it looks like this is one 'fix' that cannot be done. At least not with the current level design.
I think the key to some of the things I've read on here (Mario's head, springs, etc) would be to make the collision detection more forgiving. There was a hack for the 8-bit version of Donkey Kong, and somebody fixed it so Mario only hit his head at the very end of the girders (like the arcade). Collision detection also screws up some of the cool jumps, possible in the arcade. (So does the lack of a "spring-back" effect). Additionally, Mario can hammer a barrel from the half-way point. It's kind of lame.. lol. If Mario's head wasn't so sensitive, and the springs bounces less choppy, the levels would work out. It was just poor original programming. Not quite as bad as the Adam version, but close!
Edited by darryl1970, Sat Nov 3, 2012 5:12 PM.
#155 tep392 OFFLINE
tep392
  • 1,945 posts
Posted Sun Nov 4, 2012 11:48 AM
It's possible. I would need to use the oil can's palette, find space for the graphics, and add code to change the palette in the display list depending on which barrel is being displayed. Only hickup is if I run out of time in the vertical blank for the extra code. As it is, the code doesn't finish until after the next screen starts to draw.
#156 tep392 OFFLINE
tep392
  • 1,945 posts
Posted Sun Nov 11, 2012 9:00 AM
... just a few ideas about the graphics, now please do not shoot me :)
Many thanks for your kind attention.
Marco
Posted Image
Posted Image
Posted Image
Grooveybee thinks I can safely add another line to the display, so these mockup's look possible. :)
#157 TrekMD OFFLINE
TrekMD
  • 2,867 posts
Posted Sun Nov 11, 2012 9:21 PM
Awesome!
#158 Defender_2600 OFFLINE
Defender_2600
    Moonsweeper
  • 457 posts
Posted Sun Nov 11, 2012 10:08 PM
This is really a great news!! :)
I did not think it was necessary add another line to the display because I used the animation of end of the level as a reference to determine the highest visible line, but of course it was only an empirical evaluation.
So it looks like we finally have the space to place Pauline as in the arcade version!
Fingers crossed ...
Guys thank you!!
Marco
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#159 KevinMos3 OFFLINE
KevinMos3
  • 1,347 posts
  • Founder of the Timothy Dalton as Bond fan club
Posted Sun Nov 11, 2012 10:25 PM
Just keep in mind that if that is done, you may not be able to see the high score or the top of Pauline's head on a CRT because of overscan. Some of Bob's 320 mode games are like that on some of my TVs as well. In Moon Cresta, for example, the score and extra lives are not visible on some of my TVs.
For the high score, many people may not care since it's not really vital to gameplay, but Pauline's head being cut off (if it turns out that way after testing), may be a bit harder to overlook.
#160 tep392 OFFLINE
tep392
  • 1,945 posts
Posted Mon Nov 12, 2012 12:09 PM
One of the problems with CRT's is overscan variation. I remember some of the old sets my parents owned had knobs on the back to adjust overscan. Those adjustments are in service menu's on most newer sets.
By my calcs, Mooncresta is allowing about 10% overscan at the top. The screen map in the Maria documentation shows 25 blank lines before the 192 high game area, which would be a conservative 15% overscan. The DK playfield is already 208 lines high, so I could move it down a bit to add another line, but the top and bottom may get cut off a little on some sets. I'm not sure how much I should really push it. I think I can squeeze everything in below the top of the ladder, so I might go that route.
#161 tep392 OFFLINE
tep392
  • 1,945 posts
Posted Mon Nov 12, 2012 12:10 PM
Fingers crossed ...
Guys thank you!!
Marco
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
I like what you have done. I actually finished moving Pauling to the top girder about the time you posted this. ;)
I still need to work on score locations and the bonus timer.
#162 Defender_2600 OFFLINE
Defender_2600
    Moonsweeper
  • 457 posts
Posted Tue Nov 13, 2012 11:35 AM
amazing !! :-D
#163 Defender_2600 OFFLINE
Defender_2600
    Moonsweeper
  • 457 posts
Posted Tue Mar 19, 2013 3:48 PM
Hello Perry,
I studied very carefully the graphics of Mario and I saw that there is a good room for improvement.
I redesigned all the sprites, I tried to get the maximum geometric symmetry than the arcade version to replicate the animation with the greatest possible coherence.
If you like it or if it can be of help, I'm happy to share.
As always, thank you for your kind attention.
Marco
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#164 tep392 OFFLINE
tep392
  • 1,945 posts
Posted Tue Mar 19, 2013 5:46 PM
Awsome work! Thanks!
#165 Defender_2600 OFFLINE
Defender_2600
    Moonsweeper
  • 457 posts
Posted Tue Mar 19, 2013 6:25 PM
I'm really happy that you like. Thank you. :)
#166 darryl1970 OFFLINE
darryl1970
    Dragonstomper
  • 531 posts
Posted Wed Mar 20, 2013 9:34 AM
Hello Perry,
Marco
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Awesome job! This will make a huge improvement!
#167 boxpressed OFFLINE
boxpressed
  • 2,516 posts
Posted Tue Aug 13, 2013 1:00 PM
I just added a POKEY to my CC2 but can't get any sound at all using the .BIN that GroovyBee uploaded. The regular Donkey Kong works with the awful sound. Commando and Ballblazer work with POKEY sound.
Does someone have the MENU.TXT settings for this version? I think I have the wrong bankswitching/startup code info. Here's what I'm using:
7800_48K 78BIOS
These are the same ones for regular Donkey Kong. I've messed around with a few others, but they produce a scrambled-up screen. Thanks for any help!
#168 Trebor OFFLINE
Trebor
  • 3,477 posts
Posted Fri Aug 16, 2013 10:19 AM
The problem is that the 48k cart wasn't designed for the POKEY.
Right after the post with the bin Groovy posted, HammR25 followed up (http://atariage.com/...d/#entry2125846) with:
"We need Chad to make a new bankswitch file for this to work properly on the CC2. None of the Pokey bankswitch files would work since DK is 48k. I get it to come up with the normal 48k bankswitch but of course there's no sound. Otherwise it just comes up with a blank screen."
To update on that notion, Chad was already reached out to and has nothing left on the CC2 - including no source code.
That means you're going to need the XM (or a XBOARD) for the old version posted by Groovy a while back, or for any of the more recent versions.
When the Harmony 2 comes out it will work on that too: http://atariage.com/...d/#entry2126133
#169 Defender_2600 OFFLINE
Defender_2600
    Moonsweeper
  • 457 posts
Posted Sun Mar 30, 2014 6:32 PM
As in the other thread (http://atariage.com/...-3#entry2959572), I shared in this topic pictures that show the 7800 graphic with wrong pixel aspect ratio (2.0).
The NTSC 7800 pixel aspect ratio is 1.7 for 160 modes; below I attach some Mario sprites with correct proportions.
Marco
