ColecoFan1981 Posted November 7, 2010 Share Posted November 7, 2010 Hi, How does one go about playing just one note in Atari BASIC? On the TI-99/4A's BASIC, the command to play a single note is: CALL SOUND(1000,440,2) where... "1000" indicates the duration of the note in milliseconds (from 1 to 4.25 seconds) "440" is the tone level in Hz, and "2" is the volume of the tone. I also have to realize that on the Atari 8-bit machines the sounds and tones are in descending numbers rather than ascending. So, what would I enter to play a 60 Hz tone (mains hum)? Thank you, Ben Quote Link to comment Share on other sites More sharing options...
Bryan Posted November 7, 2010 Share Posted November 7, 2010 This should help: http://www.atariarchives.org/basic/showpage.php?page=298 http://www.atariarchives.org/dere/chapt07.php http://www.atariarchives.org/creativeatari/An_Atari_Library_of_Sound.php Quote Link to comment Share on other sites More sharing options...
ColecoFan1981 Posted November 7, 2010 Author Share Posted November 7, 2010 This should help: http://www.atariarch...ge.php?page=298 http://www.atariarch...ere/chapt07.php http://www.atariarch...ry_of_Sound.php I also want to know if the kind of tone I want to generate would involve the use of PEEK and POKE. The tone numbers from lowest to highest are given as 0-255 in descending order (255 being lowest and 0 being highest). So, again, here is a list of sounds I would like to generate on Atari BASIC: *Lawn mower - gasoline *Lawn mower - electric Thank you again, Ben Quote Link to comment Share on other sites More sharing options...
miker Posted November 7, 2010 Share Posted November 7, 2010 For first try: SOUND 0,255,12,6 for second: SOUND 0,132,12,2 and turn it off by SOUND 0,0,0,0. Quote Link to comment Share on other sites More sharing options...
ColecoFan1981 Posted November 7, 2010 Author Share Posted November 7, 2010 For first try: SOUND 0,255,12,6 for second: SOUND 0,132,12,2 and turn it off by SOUND 0,0,0,0. Thank you! Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 7, 2010 Share Posted November 7, 2010 For first try: SOUND 0,255,12,6 for second: SOUND 0,132,12,2 and turn it off by SOUND 0,0,0,0. Thank you! Quick explanation - 1st # is voice (0-3 is acceptable), 2nd is frequency (0-255), 3rd is distortion/noise (0-15 is range, IIRC 8 and 12 are pure but it has been a few years), 4th is volume (0-15 range). 1 Quote Link to comment Share on other sites More sharing options...
ColecoFan1981 Posted November 7, 2010 Author Share Posted November 7, 2010 For first try: SOUND 0,255,12,6 for second: SOUND 0,132,12,2 and turn it off by SOUND 0,0,0,0. Thank you! Quick explanation - 1st # is voice (0-3 is acceptable), 2nd is frequency (0-255), 3rd is distortion/noise (0-15 is range, IIRC 8 and 12 are pure but it has been a few years), 4th is volume (0-15 range). The sound can also be turned off by typing END when you're done running the program. And SOUND can also be abbreviated to "SO." ~Ben Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted November 8, 2010 Share Posted November 8, 2010 For first try: SOUND 0,255,12,6 for second: SOUND 0,132,12,2 and turn it off by SOUND 0,0,0,0. Sometimes I have noticed the sound doesn't cut cleanly off when you do SOUND 0,0,0,0, there's like a snippet of white noise that lasts a fraction of a second ... so you should do this: When you use SOUND 0,132,12,2 .... cut off the sound by using SOUND 0,132,12,0 thereby keeping your frequency and timbre values the same. Quote Link to comment Share on other sites More sharing options...
