Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted November 14, 2010 Share Posted November 14, 2010 (edited) Beautiful little baby ! Looks like a Munch Man clone. Just better ! Edited November 14, 2010 by sometimes99er Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 (edited) Fixed the code, added an interrupt enable/disable at the beginning of my KSCAN loop to allow for exit to title screen. LP LIMI 2 LIMI 0 * * Owen Brand, Nov 13, 2010 * * Clear the screen. * Assumes the default graphics mode I. * DEF START REF VSBW,VWTR,VMBW,KSCAN CTAB EQU >0380 ; equate location of colorset table in RAM * The linker will branch to this location * to start our program. START LI R0,CTAB ; table location LI R1,CSET ; definitions LI R2,32 ; number of bytes to write BLWP @VMBW * Interrupts need to be disabled any time the VDP * is being accessed. LIMI 0 * Always know where your workspace is! LWPI >8300 * Set the background color to white >F * VDP register 7 controls the text mode * text color and the background color for * the other modes. All other VDP registers * are assumed to have set graphics mode 1. LI R0,>071F ; Register 7, black on white BLWP @VWTR ; Write the register * Set up to clear the screen. Assumes the * Name Table is set to address >0000 in VRAM. * All the names (tile / character values) in * the Name Table will be set to the space character * which is, well, a space, so it has no foreground * bits, so the screen will show only the background * color. * * Note, only the HIGH BYTE is transfered to the VDP * hence using >2000 loads 32 (>20) into the MSB of R1. CLR R0 ; Start at >0000 in VRAM. LI R1,>2000 ; Write 32 (space char) LI R2,768 ; 32x24 tiles = 768 total to write LOOP BLWP @VSBW ; Write the byte INC R0 ; Next VRAM screen location DEC R2 ; Count the byte just written JNE LOOP ; If not done, write again * The DEC instruction compares the result of the decrement to * zero automatically (as do many instructions), so the JNE is * really saying "jump if R2 is not zero". * This will place a "@" at screen location 110 LI R0,110 ; Screen location in VDP RAM LI R1,>4000 ; ASCII code for "@" BLWP @VSBW ; Write it JOYCK LI R1,>0100 *check for joystick 1 input MOVB R1,@>8374 *check for Y return LP LIMI 2 LIMI 0 BLWP @KSCAN *check for input CLR R1 *clear register for Y return check MOVB @>8376,R1 *move Y return value into MSB of R1 CI R1,>0400 *is the Y value "4"? (up) JNE T1 *if not, go to the next comparison AI R0,-32 JMP PRINT T1 CI R1,>FC00 *compares MSB of R1 to >FC (down) JNE T2 *if not, go to the next comparison AI R0,32 JMP PRINT T2 MOVB @>8377,R1 *move X-return byte into R1 CI R1,>0400 *is the X value "4"? (right) JNE T3 *if not, go to the next comparison INC R0 JMP PRINT T3 CI R1,>FC00 *final comparison... is the X value >FC? (left) JNE LP *it was not, therefore no motion happened, jump to KSCAN DEC R0 PRINT LI R4,3000 *Start the delay loop DEC R4 *decrement register 4 (part of delay) JNE $-2 *jump back one word in memory to DEC LI R1,>4000 *load the ASCII character to print BLWP @VSBW *print it JMP LP *back to KSCAN routine CSET BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 ;set "@" to "red" BYTE >C0,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 END START Thanks for all your help guys. =) ***edit*** Again, it messed up my indentation. =) But whatever. I could attach the actual object code, but it's nothing all that great yet. I'll be adding borders and whatnot tomorrow. I don't know what to do with this next, but probably change it to where it won't create a trail, but re-draw it each time. Then draw some "treasure chests" on the screen (probably just an "X") and allow the user to "pick them up"... Maybe have a status on screen somewhere showing how many the user has collected. Just to get the hang of it. This could end up being the starting skeleton for Calimari Carl in assembly. =) Edited November 14, 2010 by Opry99er Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted November 14, 2010 Share Posted November 14, 2010 3. Personally I'm opposed to the VSBW and company routines, but using them now can help make your code *look* smaller. Just keep in mind that at some point you will need to learn what they do and replace them. Also, remember they *drastically* slow down your program. 4. Comment you code. Typically most people comment every line in assembly. I find this a *little* helpful sometimes, but what is more useful is a block comment that describes what the following code does. Use comments of individual instructions to explain why you are using a certain value or memory address. I keep hearing about how slow the internal VDP routines are, but quite honestly they fit the bill for the vast majority of the time for most projects. I suggest you stick with them until you hit an unacceptable performance point. Test your program with them, and if you are happy then everything is cool. Otherwise, replace them (not too hard to do). I know the purists here are probably pulling their hair out by now and clamoring for my lynching, but I am a simple guy that does not need to complicate his life unnecessarily As far as commenting, trust me when I say that you cannot comment enough! Since comments do not take any memory space after compilation, go wild! I tend to comment almost every line because I can't understand my own code a couple of days later Interesting trivia: In the late 1950's, the legendary MIT hacker Peter Samson was notorious for not commenting his code with ONE exception: In one well distributed program running for hundreds of lines, there was only one comment next to an instruction containing the number 1750. The comment was RIPJSB. Can you figure it out? (source: Hackers by Steven Levy. Amazing book if you have never read it). Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Pretty cool how small the object code is. =) I wonder if there's anyone who can read this and tell what it does... without seeing source. =) 000BA A0000B0200B0380B0201C009AB0202B0020B0420B0000B03007F369F 0001 A0012B0000B02E0B8300B0200B071FB0420B0000B04C0B0201B2000B02027F347F 0002 A0028B0300B0420B0000B0580B0602B16FBB0200B006EB0201B4000B04207F331F 0003 A003EC002CB0201B0100BD801B8374B0300B0002B0300B0000B0420B00007F33FF 0004 A0054B04C1BD060B8376B0281B0400B1603B0220BFFE0B1011B0281BFC007F2CAF 0005 A006AB1603B0220B0020B100BBD060B8377B0281B0400B1602B0580B10047F31BF 0006 A0080B0281BFC00B16E1B0600B0204B0BB8B0604B16FEB0201B4000B04207F2D8F 0007 A0096C003EB10D7B1010B1010B1010B1010BC010B1010B1010B1010B10107F34AF 0008 A00ACB1010B1010B1010B1010B1010B1010B10107F788F 0009 200007FED7F 0010 50000START 30096VSBW 3001EVWTR 3000EVMBW 30052KSCAN 7F2F8F 0011 : 99/4 AS 0012 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted November 14, 2010 Share Posted November 14, 2010 (edited) I keep hearing about how slow the internal VDP routines are, but quite honestly they fit the bill for the vast majority of the time for most projects. I suggest you stick with them until you hit an unacceptable performance point. Test your program with them, and if you are happy then everything is cool. Otherwise, replace them (not too hard to do). I know the purists here are probably pulling their hair out by now and clamoring for my lynching, but I am a simple guy that does not need to complicate his life unnecessarily As far as commenting, trust me when I say that you cannot comment enough! Since comments do not take any memory space after compilation, go wild! I tend to comment almost every line because I can't understand my own code a couple of days later You're right. PS. I don't use them, so ... Interesting trivia: In the late 1950's, the legendary MIT hacker Peter Samson was notorious for not commenting his code with ONE exception: In one well distributed program running for hundreds of lines, there was only one comment next to an instruction containing the number 1750. The comment was RIPJSB. Can you figure it out? (source: Hackers by Steven Levy. Amazing book if you have never read it). "Rest In Peace Johann Sebastian Bach" (year of death). Edited November 14, 2010 by sometimes99er Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted November 14, 2010 Share Posted November 14, 2010 I think that's me trying to draw a straight line after a few adult beverages -grin- Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted November 14, 2010 Share Posted November 14, 2010 My son, Rasmus, 2 year old, saw your picture and said: Train ! Train !! I wanna play train ! Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted November 14, 2010 Share Posted November 14, 2010 Interesting trivia: In the late 1950's, the legendary MIT hacker Peter Samson was notorious for not commenting his code with ONE exception: In one well distributed program running for hundreds of lines, there was only one comment next to an instruction containing the number 1750. The comment was RIPJSB. Can you figure it out? (source: Hackers by Steven Levy. Amazing book if you have never read it). "Rest In Peace Johann Sebastian Bach" (year of death). Ahhh! You read the book! if not, well chapeau bas! Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 14, 2010 Share Posted November 14, 2010 Interesting trivia: In the late 1950's, the legendary MIT hacker Peter Samson was notorious for not commenting his code with ONE exception: In one well distributed program running for hundreds of lines, there was only one comment next to an instruction containing the number 1750. The comment was RIPJSB. Can you figure it out? (source: Hackers by Steven Levy. Amazing book if you have never read it). An excellent book. Fantastic and full of our history. Not many people know that "hacking" started with model railroad Signals and Lights. Read up on "Blatties" and "yellow gunkies." Now I have a hankering to dig it out and read it again. Another good book to read is "Soul of a New Machine." Yeah, the kernal code (SEMP: System Event Monitoring Procedure) for my Commodore 64 BBS program had a comment on just about every line. In a lot of cases it was something like "WTF was I thinking here?" or "I'm not sure why this works." Thinking about Head-Slapping Moments in Assembly Language Programming , I was writing a simple screen blanker module for the BBS, a clone of the blanker in the TI. Of course it did not work properly and I had the damnedest time figuring it out. I even rewrote the code. I left it in frustration and came back to it later, and there it was starting me right in the face. If you are familiar with 6502 assembly then you know how CMP works with BNE and BEQ. Right there... there it was, a BEQ instead of a BNE (or opposite, I cannot quite recall and I think this part changes every time I tell the story.) Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted November 14, 2010 Share Posted November 14, 2010 Thinking about Head-Slapping Moments in Assembly Language Programming , I was writing a simple screen blanker module for the BBS, a clone of the blanker in the TI. Of course it did not work properly and I had the damnedest time figuring it out. I even rewrote the code. I left it in frustration and came back to it later, and there it was starting me right in the face. If you are familiar with 6502 assembly then you know how CMP works with BNE and BEQ. Right there... there it was, a BEQ instead of a BNE (or opposite, I cannot quite recall and I think this part changes every time I tell the story.) Damn that sounds familiar For me, the most common error is forgetting that byte operations are done on the most significant byte of a word. My palm is still imprinted on my forehead. Have to go: I'm playing Orbiter on my Pcjr and I have to begin the deorbit procedure! Quote Link to comment Share on other sites More sharing options...
+adamantyr Posted November 14, 2010 Share Posted November 14, 2010 Looking good, Owen! Just set yourself small goals and achieve them one by one. Doing borders and being able to detect and pick up objects on the screen is a good set of goals. I agree with Vorticon about the VDP utilities... I've butted heads with Matthew on this subject before. I'd call writing your own VDP utilities and VDP read/write techniques an optimization step, and probably best for the intermediate programmer who has mastered the basics (replicated everything he could do in BASIC and Extended BASIC) and is ready to move on into what assembly can do for you that can't be done elsewhere. One area that is a must for assembly programming is understanding boolean logic. (AND, OR, NOT, bit masks, etc.) TI BASIC and Extended BASIC use these, but you can use IF/THEN without ever really understanding what's going on under the hood. I had a college course on the subject in my CS path, can anyone recommend a decent book that's good for a beginner here? Adamantyr Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 First, thank you guys for being so supportive. I was doing pretty well back in May--- I was able to accomplish some cool things, but I guess I really didn't quite know what the hell I was doing. Got lucky I guess. Anyway--- I have some cool ideas for what I want to achieve this time around... Doable goals that won't get lost in a fog of uncertainty. My Beryl Reichardt scroller was a nice step, but I had nowhere to go with it. This time around, I plan to start with accomplishable goals--- like make a roguelike. I actually like Nethack quite a bit. I know some folks don't care for that game too much, but it's achievable, I think.... First things first... Let's do screen boundaries and keep one "@" on the screen at a time. code forthcoming. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 (edited) I added this to my code... I won't post the whole thing here, but I want to get some opinions. My program works just fine, it does ALMOST what I expect it to... but the "@" doesn't hit every screen position as I move it up down left and right. It looks like it skips screen positions... As you hold down the key, it disappears from sight. I'm not 100% sure why yet, but I'll know momentarily. The important additions to my code are the re-load of R1 with ASCII >20 and BLWP @VSBW that I do in all my joystick checks now, BEFORE the modification on location and jump to print routine. Here's program flow for the most part on the check for a "down" diretion... Code checks for "down", if not, it jumps... if it IS down, it writes a space character to the current location of the "@", then changes the screen location to print the next "@", giving the appearance that it is moving around the screen. This little chunk of code will show what I mean. If you want to see the whole joystick routine as it currently sits, check the collapsed code box. =) Thanks... I hope to hear some suggestions on how to smooth out this routine here. =) JNE T2 ;if not, jump to next comparison LI R1,>2000 ;load ASCII with space character to write over the current "@" BLWP @VSBW ; write it AI R0,32 JOYCK LI R1,>0100 *check for joystick 1 input MOVB R1,@>8374 *check for Y return LP LIMI 2 LIMI 0 BLWP @KSCAN *check for input CLR R1 *clear register for Y return check MOVB @>8376,R1 *move Y return value into MSB of R1 CI R1,>0400 *is the Y value "4"? (up) JNE T1 *if not, go to the next comparison LI R1,>2000 BLWP @VSBW AI R0,-32 JMP PRINT T1 CI R1,>FC00 *compares MSB of R1 to >FC (down) JNE T2 *if not, go to the next comparison LI R1,>2000 BLWP @VSBW AI R0,32 JMP PRINT T2 MOVB @>8377,R1 *move X-return byte into R1 CI R1,>0400 *is the X value "4"? (right) JNE T3 *if not, go to the next comparison LI R1,>2000 BLWP @VSBW INC R0 JMP PRINT T3 CI R1,>FC00 *final comparison... is the X value >FC? (left) JNE LP *it was not, therefore no motion happened, jump to KSCAN LI R1,>2000 BLWP @VSBW DEC R0 PRINT LI R4,3000 *Start the delay loop DEC R4 *decrement register 4 (part of delay) JNE $-2 *jump back one word in memory to DEC LI R1,>4000 *load the ASCII character to print BLWP @VSBW *print it JMP LP *back to KSCAN routine ***edit*** It seems like the problem is ONLY when the key is held down... It clears immediately, but it won't redraw until I let off the key... hmmmmmm................... Edited November 14, 2010 by Opry99er Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 (edited) Would a better way be to copy the MSB of R1 to another register (MOVB R1,R5) and then use THAT register to keep current screen position? It seems redundant and unnecessary which is why I didn't do it initially, but having a copy of screen location somewhere (preferably a register) would most likely come in handy at some point... assuming this becomes something other than a tester program. This still doesn't solve the problem of the key-press... Where it won't draw the next "@" until I let off the key. I need it to print every screen position as the location is changed... a "smooth" type of motion. Obviously it's not a SPRITE, but I'm thinking I can get it to do every position..... Need to research more. Edited November 14, 2010 by Opry99er Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Okay... I'm not finding the information I need in Lottrup. I've scoured the KSCAN chapter and I don't have any examples of how to fix this problem. I could use a lifeline. =) Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Here's a zip of the source and the object code. Maybe this helps. =) CLR2O.zip Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted November 14, 2010 Share Posted November 14, 2010 Here's the list output after doing an AORG >A000. Asm994a TMS99000 Assembler - v3.008 * Asm994a Generated Register Equates * 0000 0000 R0 EQU 0 0000 0001 R1 EQU 1 0000 0002 R2 EQU 2 0000 0003 R3 EQU 3 0000 0004 R4 EQU 4 0000 0005 R5 EQU 5 0000 0006 R6 EQU 6 0000 0007 R7 EQU 7 0000 0008 R8 EQU 8 0000 0009 R9 EQU 9 0000 000A R10 EQU 10 0000 000B R11 EQU 11 0000 000C R12 EQU 12 0000 000D R13 EQU 13 0000 000E R14 EQU 14 0000 000F R15 EQU 15 * 1 * 2 * Owen Brand, Nov 13, 2010 3 * 4 * Clear the screen. 5 * Assumes the default graphics mode I. 6 * 7 0000 A000 DEF START 8 0000 0000 REF VSBW,VWTR,VMBW,KSCAN 8 0000 0000 8 0000 0000 8 0000 0000 9 AORG >A000 10 0000 0380 CTAB EQU >0380 ; equate location of colorset table in RAM 11 12 * The linker will branch to this location 13 * to start our program. 14 START 15 16 A000 0200 LI R0,CTAB ; table location 16 A002 0380 17 A004 0201 LI R1,CSET ; definitions 17 A006 A0BA 18 A008 0202 LI R2,32 ; number of bytes to write 18 A00A 0020 19 A00C 0420 BLWP @VMBW 19 A00E 0000 20 21 * Interrupts need to be disabled any time the VDP 22 * is being accessed. 23 A010 0300 LIMI 0 23 A012 0000 24 25 * Always know where your workspace is! 26 A014 02E0 LWPI >8300 26 A016 8300 27 28 29 * Set the background color to white >F 30 * VDP register 7 controls the text mode 31 * text color and the background color for 32 * the other modes. All other VDP registers 33 * are assumed to have set graphics mode 1. 34 35 A018 0200 LI R0,>071F ; Register 7, black on white 35 A01A 071F 36 A01C 0420 BLWP @VWTR ; Write the register 36 A01E 0000 37 38 39 * Set up to clear the screen. Assumes the 40 * Name Table is set to address >0000 in VRAM. 41 * All the names (tile / character values) in 42 * the Name Table will be set to the space character 43 * which is, well, a space, so it has no foreground 44 * bits, so the screen will show only the background 45 * color. 46 * 47 * Note, only the HIGH BYTE is transfered to the VDP 48 * hence using >2000 loads 32 (>20) into the MSB of R1. 49 50 A020 04C0 CLR R0 ; Start at >0000 in VRAM. 51 A022 0201 LI R1,>2000 ; Write 32 (space char) 51 A024 2000 52 A026 0202 LI R2,768 ; 32x24 tiles = 768 total to write 52 A028 0300 53 54 LOOP 55 A02A 0420 BLWP @VSBW ; Write the byte 55 A02C 0000 56 A02E 0580 INC R0 ; Next VRAM screen location 57 A030 0602 DEC R2 ; Count the byte just written 58 A032 16FB JNE LOOP ; If not done, write again 59 60 * The DEC instruction compares the result of the decrement to 61 * zero automatically (as do many instructions), so the JNE is 62 * really saying "jump if R2 is not zero". 63 64 * This will place a "@" at screen location 110 65 A034 0200 LI R0,110 ; Screen location in VDP RAM 65 A036 006E 66 A038 0201 LI R1,>4000 ; ASCII code for "@" 66 A03A 4000 67 A03C 0420 BLWP @VSBW ; Write it 67 A03E A02C 68 69 70 A040 0201 JOYCK LI R1,>0100 *check for joystick 1 input 70 A042 0100 71 A044 D801 MOVB R1,@>8374 *check for Y return 71 A046 8374 72 A048 0300 LP LIMI 2 72 A04A 0002 73 A04C 0300 LIMI 0 73 A04E 0000 74 A050 0420 BLWP @KSCAN *check for input 74 A052 0000 75 A054 04C1 CLR R1 *clear register for Y return check 76 A056 D060 MOVB @>8376,R1 *move Y return value into MSB of R1 76 A058 8376 77 A05A 0281 CI R1,>0400 *is the Y value "4"? (up) 77 A05C 0400 78 A05E 1607 JNE T1 *if not, go to the next comparison 79 A060 0201 LI R1,>2000 79 A062 2000 80 A064 0420 BLWP @VSBW 80 A066 A03E 81 A068 0220 AI R0,-32 81 A06A FFE0 82 A06C 101D JMP PRINT 83 A06E 0281 T1 CI R1,>FC00 *compares MSB of R1 to >FC (down) 83 A070 FC00 84 A072 1607 JNE T2 *if not, go to the next comparison 85 A074 0201 LI R1,>2000 85 A076 2000 86 A078 0420 BLWP @VSBW 86 A07A A066 87 A07C 0220 AI R0,32 87 A07E 0020 88 A080 1013 JMP PRINT 89 A082 D060 T2 MOVB @>8377,R1 *move X-return byte into R1 89 A084 8377 90 A086 0281 CI R1,>0400 *is the X value "4"? (right) 90 A088 0400 91 A08A 1606 JNE T3 *if not, go to the next comparison 92 A08C 0201 LI R1,>2000 92 A08E 2000 93 A090 0420 BLWP @VSBW 93 A092 A07A 94 A094 0580 INC R0 95 A096 1008 JMP PRINT 96 A098 0281 T3 CI R1,>FC00 *final comparison... is the X value >FC? (left) 96 A09A FC00 97 A09C 16D5 JNE LP *it was not, therefore no motion happened, jump to KSCAN 98 A09E 0201 LI R1,>2000 98 A0A0 2000 99 A0A2 0420 BLWP @VSBW 99 A0A4 A092 100 A0A6 0600 DEC R0 101 102 A0A8 0204 PRINT LI R4,3000 *Start the delay loop 102 A0AA 0BB8 103 A0AC 0604 DEC R4 *decrement register 4 (part of delay) 104 A0AE 16FE JNE $-2 *jump back one word in memory to DEC 105 A0B0 0201 LI R1,>4000 *load the ASCII character to print 105 A0B2 4000 106 A0B4 0420 BLWP @VSBW *print it 106 A0B6 A0A4 107 A0B8 10C7 JMP LP *back to KSCAN routine 108 109 110 A0BA 1010 CSET BYTE >10,>10,>10,>10 110 A0BC 1010 111 A0BE 1010 BYTE >10,>10,>10,>10 ;set "@" to "red" 111 A0C0 1010 112 A0C2 C010 BYTE >C0,>10,>10,>10 112 A0C4 1010 113 A0C6 1010 BYTE >10,>10,>10,>10 113 A0C8 1010 114 A0CA 1010 BYTE >10,>10,>10,>10 114 A0CC 1010 115 A0CE 1010 BYTE >10,>10,>10,>10 115 A0D0 1010 116 A0D2 1010 BYTE >10,>10,>10,>10 116 A0D4 1010 117 A0D6 1010 BYTE >10,>10,>10,>10 117 A0D8 1010 118 119 120 A0DA 0000 END START 120 Assembly Complete - Errors: 0, Warnings: 0 ------ Symbol Listing ------ CSET ABS:A0BA CSET CTAB ABS:0380 CTAB JOYCK ABS:A040 JOYCK KSCAN REF:A052 KSCAN LOOP ABS:A02A LOOP LP ABS:A048 LP PRINT ABS:A0A8 PRINT R0 ABS:0000 R0 R1 ABS:0001 R1 R10 ABS:000A R10 R11 ABS:000B R11 R12 ABS:000C R12 R13 ABS:000D R13 R14 ABS:000E R14 R15 ABS:000F R15 R2 ABS:0002 R2 R3 ABS:0003 R3 R4 ABS:0004 R4 R5 ABS:0005 R5 R6 ABS:0006 R6 R7 ABS:0007 R7 R8 ABS:0008 R8 R9 ABS:0009 R9 START ABS:A000 START T1 ABS:A06E T1 T2 ABS:A082 T2 T3 ABS:A098 T3 VMBW REF:A00E VMBW VSBW REF:A0B6 VSBW VWTR REF:A01E VWTR Quote Link to comment Share on other sites More sharing options...
+adamantyr Posted November 14, 2010 Share Posted November 14, 2010 I see a few things... your delay was in the wrong place, it should be AFTER you have written the character, not before. I also made some changes to how the joystick is scanned. Since the X and Y values are in a single word, you can easily check for no activity and just loop back. Code below * * Owen Brand, Nov 13, 2010 * * Clear the screen. * Assumes the default graphics mode I. * DEF START REF VSBW,VWTR,VMBW,KSCAN AORG >A000 * Start program at bottom of high memory CTAB EQU >0380 * equate location of colorset table in RAM * Data constants B4 BYTE 4 BN4 BYTE >FC * The linker will branch to this location * to start our program. START LI R0,CTAB * table location LI R1,CSET * definitions LI R2,32 * number of bytes to write BLWP @VMBW * Interrupts need to be disabled any time the VDP * is being accessed. LIMI 0 * Always know where your workspace is! LWPI >8300 * Set the background color to white >F * VDP register 7 controls the text mode * text color and the background color for * the other modes. All other VDP registers * are assumed to have set graphics mode 1. LI R0,>071F * Register 7, black on white BLWP @VWTR * Write the register * Set up to clear the screen. Assumes the * Name Table is set to address >0000 in VRAM. * All the names (tile / character values) in * the Name Table will be set to the space character * which is, well, a space, so it has no foreground * bits, so the screen will show only the background * color. * * Note, only the HIGH BYTE is transfered to the VDP * hence using >2000 loads 32 (>20) into the MSB of R1. CLR R0 * Start at >0000 in VRAM. LI R1,>2000 * Write 32 (space char) LI R2,768 * 32x24 tiles = 768 total to write LOOP BLWP @VSBW * Write the byte INC R0 * Next VRAM screen location DEC R2 * Count the byte just written JNE LOOP * If not done, write again * The DEC instruction compares the result of the decrement to * zero automatically (as do many instructions), so the JNE is * really saying "jump if R2 is not zero". * This will place a "@" at screen location 110 LI R0,110 *Screen location in VDP RAM LI R1,>4000 * ASCII code for "@" BLWP @VSBW * Write it JOYCK LI R1,>0100 *check for joystick 1 input MOVB R1,@>8374 *check for Y return LP LIMI 2 LIMI 0 BLWP @KSCAN *check for input MOV @>8376,R1 * Move joystick XY values into R1 JEQ LP * If 0 (no movement, jump back to KSCAN CB R1,@B4 *is the Y value "4"? (up) JNE T1 *if not, go to the next comparison LI R1,>2000 BLWP @VSBW AI R0,-32 JMP PRINT T1 CB R1,@BN4 *compares MSB of R1 to >FC (down) JNE T2 *if not, go to the next comparison LI R1,>2000 BLWP @VSBW AI R0,32 JMP PRINT T2 SWPB R1 * Swap bytes in R1 for Y comparisons CB R1,@B4 *is the X value "4"? (right) JNE T3 *if not, go to the next comparison LI R1,>2000 BLWP @VSBW INC R0 JMP PRINT T3 LI R1,>2000 BLWP @VSBW DEC R0 PRINT LI R1,>4000 *load the ASCII character to print BLWP @VSBW *print it LI R4,3000 *Start the delay loop DEC R4 *decrement register 4 (part of delay) JNE $-2 *jump back one word in memory to DEC JMP LP *back to KSCAN routine CSET BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 *set "@" to "red" BYTE >C0,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 BYTE >10,>10,>10,>10 END START Adamantyr Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Looks great Adamantyr... Thank you for the optimizations! This is a very nice joystick KSCAN routine here... I imagine I will use it quite a bit in the future. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Wanna change the screen color of this program? Go north for 2 seconds. =) Don't go too far north... you'll hit the Canadian wasteland of "other memory land"* *Adamantyr-- 2010 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Here's a video of the current program. I intentionally went offscreen to show what "other memory land" looks like. =) http://www.youtube.com/watch?v=47pff7mbBAI Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted November 14, 2010 Share Posted November 14, 2010 Sometimes I start out writing (comments) in pseudo code. This step can involve many changes, renaming and rearrangements. Set default screen location Put "@" character code at screen location Delay loop Put "space" character code at screen location Read joystick Change screen location accordingly Go to 2. Writing assembler code to perform just one of the steps above are often quite easy. I can concentrate on the simple task at hand one at a time, knowing that the overall flow has been taken care of (at least I assume so - debugging later). If I have pseudo code on higher levels like Intro screen Main game Game over I'll break down one element into many smaller elements (often into 5 to 10 elements). This process continues in an uneven/not balanced tree structure, until one element is like a comment for a section of assembler instructions (often 3 to 20 instructions). Designing a complete game this way is possible, but can you go all the way without wanting to code (prove certain aspects etc.) ? With Basic we probably design as we code - besides an initial overall design phase/idea. You might have some of the graphics and a screen design, but things change a lot and you add things. This is not necessarily bad, but you might loose the drive at some point. Funny thing is, if you're two (enthusiastic) programmers sitting at one computer, it's much more fun, and the drive isn't lost so easily. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 14, 2010 Author Share Posted November 14, 2010 Thanks sometimes!! Question... Screen boundaries... Should I place a different character value around the edge and check for that particular ASCII value? Kind of a GCHAR sort of thing... Its all I can think to do for the right and left sides of the screen--- top and bottom wouldn't be so difficult... But I think this method might be the most efficient (the method of putting a different ASCII on the edges) Quote Link to comment Share on other sites More sharing options...
matthew180 Posted November 15, 2010 Share Posted November 15, 2010 Separate your graphics rendering from your game logic. You are thinking in terms of the raw information needed to draw on the screen, and that will make your life a lot harder. In games there is a lot of translation that goes on, and the game map is not the same thing you see on the screen. First, don't try to use the registers for specific values (current screen location, player information, etc.) Use variables. Second, the screen should be an output only device. Keep your player's X,Y values in variables, as well as the prospective *new* location. P1X BYTE 16 P1Y BYTE 12 P1XNEW BYTE >00 P1YNEW BYTE >00 Then when you read the keyboard / joystick, do the same thing you do in BASIC, add / subtract 1 from the respective variable. When you want to draw, make a subroutine that puts your players on the screen given an X,Y location. You do bounds checking based on the variable values or the X,Y locations compared to map data, etc. Something like this (mix of pseudo code and real code): P1X BYTE 16 P1Y BYTE 12 P1XNEW BYTE >00 P1YNEW BYTE >00 P1TILE BYTE 64 * K_UPDN and K_LTRT will be -1, 0, or 1 EVEN K_UPDN BYTE >00 K_LTRT BYTE >00 * General use numbers NEG1 BYTE -1 NUM0 BYTE 0 NUM1 BYTE 1 NUM2 BYTE 2 * Boundaries XMIN BYTE 2 XMAX BYTE 29 YMIN BYTE 2 YMAX BYTE 21 GAMELOOP * Save the current X,Y location. * The new location is the current location until there is movement. MOVB @P1X,@P1XNEW MOVB @P1Y,@P1YNEW * Clears both movement indicator bytes. K_UPDN was preceded by EVEN to make sure it is on a 16-bit WORD boundary. CLR @K_UPDN * Start by reading the keyboard. BLWP @KSCAN IF NO KEYPRESS, READ JOYSTICK compare if UP JNE KB01 MOVB @NEG1,@K_UPDN JMP KEYBOARD_DONE KB01 compare if DOWN JNE KB02 MOVB @NUM1,@K_UPDN JMP KEYBOARD_DONE KB02 compare if LEFT JNE KB03 MOVB @NEG1,@K_LTRT JMP KEYBOARD_DONE KB03 compare if RIGHT JNE KEYBOARD_DONE MOVB @NUM1,@K_LTRT KEYBOARD_DONE JMP BOUND_CHECK * Code falls here if no keyboard movement was found. READ_JOYSTICK BLWP @JOYSTICK IF NO JOYSTICK, JUMP TO BOUND CHECK. compare if UP JNE JS01 MOVB @NEG1,@K_UPDN JMP JOYSTICK_DONE JS01 compare if DOWN JNE JS02 MOVB @NUM1,@K_UPDN JMP JOYSTICK_DONE JS02 compare if LEFT JNE JS03 MOVB @NEG1,@K_LTRT JMP JOYSTICK_DONE JS03 compare if RIGHT JNE JOYSTICK_DONE MOVB @NUM1,@K_LTRT BOUND_CHECK * At this point there should be a movement indicator for any direction * of concern, i.e. up, down, left, or right. Reading the keyboard OR * joystick for movement should set the same indicators. * Adjust the new position based on the direction request. AB @K_UPDN,@P1YNEW AB @K_LTRT,@P1XNEW * Check if the new location is legal. CB @P1XNEW,@XMIN JL RENDER CB @P1XNEW,@XMAX JH RENDER CB @P1YNEW,@YMIN JL RENDER CB @P1YNEW,@YMAX JH RENDER * Player updating begins here. * The new move is legal, so erase the player at the current location. MOVB @P1Y,R0 SWPB R0 MOVB @P1X,R0 MOVB @P1TILE,R1 BL @RENDER_PLAYER * Screen rendering starts here. This is done even if the player did not * move or make a legal move. This allows *other* objects to still move * or animate themselves. Even the player make animate (change character * pattern, color, sound, etc) even if the move was not legal. RENDER MOVB @P1YNEW,R0 SWPB R0 MOVB @P1XNEW,R0 MOVB @P1TILE,R1 BL @RENDER_PLAYER * Update the player coordinates. MOVB @P1XNEW,@P1X MOVB @P1YNEW,@P1Y B @GAME_LOOP ******* * Render the player on the screen * R0 contains the X location in the MSB, the Y location in the LSB * R1 contains the player tile to use RENDER_PLAYER * Convert the X,Y into a linear offset value of the screen location. * The formula is: OFFSET = Y*32+X CLR R2 ; Prepare R2 for the X value MOVB R0,R2 ; Save the X coordinate in the MSB of R2 ANDI R0,>00FF ; Isolate the Y coordinate SLA R0,5 ; Multiply Y by 32 SWPB R2 ; Move the X coordinate to the LSB for the addition A R2,R0 ; Add the X coordinate BLWP @VSBW RT That's the basic idea anyway. Use variables to track your player's location, state, tile, color, direction, etc. Same with all the other objects in the game. Since you know where the player is, you can do a bounds check and see if the move is legal before you update the player's location. Also remember that just because the player may not move, the rest of the game does not come to a halt, so you still perform the rendering every frame, which lets you do things like animate other objects, play sounds, update timers, etc. Matthew Quote Link to comment Share on other sites More sharing options...
