yuppicide Posted November 24, 2010 Share Posted November 24, 2010 I have MAME 32 bit .140 command line with MAMEPlus .139. How do I get it to keep high scores? Quote Link to comment Share on other sites More sharing options...
VectorGamer Posted November 24, 2010 Share Posted November 24, 2010 I have MAME 32 bit .140 command line with MAMEPlus .139. How do I get it to keep high scores? You need to download the latest hiscore.dat file. Not all games are supported. http://highscore.mameworld.info/download.htm Quote Link to comment Share on other sites More sharing options...
yuppicide Posted November 25, 2010 Author Share Posted November 25, 2010 Oh thanks.. guess newer MAME such as the one I have .140 doesn't support high score I guess. I don't wanna go back to a lower version. Quote Link to comment Share on other sites More sharing options...
yuppicide Posted November 25, 2010 Author Share Posted November 25, 2010 Someone one at arcadecontrols website pointed me to a link with high score diff files and a front end to compile your own MAME, so it's possible to add high score support back into newer MAME versions. Quote Link to comment Share on other sites More sharing options...
Buzbard Posted November 26, 2010 Share Posted November 26, 2010 (edited) You can get the highscore.diff file @ Build Your Own Arcade Controls Forum. The same patch also allows you to disable the NAG screen and the Loading screen. Edited November 26, 2010 by Buzbard Quote Link to comment Share on other sites More sharing options...
Video Posted November 29, 2010 Share Posted November 29, 2010 Just a thought, but most emulators have a save state. You could just save your game before turning it off, and as long as you remember to reload the game, it should remember your high score. Actual arcades were rarely battery backed, as they typically stayed plugged in (and turned on) their whole life. Quote Link to comment Share on other sites More sharing options...
lakawak Posted April 25, 2014 Share Posted April 25, 2014 Actual arcades were rarely battery backed, as they typically stayed plugged in (and turned on) their whole life. I was around many arcades in my time. (My local mall had THREE at one time.) and not one of them kept the games turned on when they closed. Plugged in, maybe. But not turned on. Quote Link to comment Share on other sites More sharing options...
Trebor Posted April 25, 2014 Share Posted April 25, 2014 If an Arcade machine had NVRAM (I.E. Williams "classics" - Joust, Bubbles, Sinister, Robotron: 2084), it will keep your high scores even when turned off. For the machines without NVRAM or some sort of battery backup you would lose high scores once powered off. Older versions of MAME (From several years ago) utilize a high score file for saving, but newer versions of MAME do not as utilizing such a file can introduce bugs because it is hacking data to achieve its goal, as well as not truly simulating what the actual arcade machine is doing. Variants of the official version do still support the file though as noted in the above responses. The work around for preserving scores while not introducing hacks into saving the data is to utilize the 'autosave' feature which will automatically save the state of most games upon exit of it being emulated. When you reload the game again, it will pick up exactly where you left off/exited, thereby preserving all scores as if the machine was never powered-off. See this section of the mame.ini file: # # CORE STATE/PLAYBACK OPTIONS # state autosave 1 playback To flush or reset a machine even when autosave is enabled, hold down the Shift key and press F3. This will completely reset emulation of the game. Quote Link to comment Share on other sites More sharing options...
Cynicaster Posted April 28, 2014 Share Posted April 28, 2014 As mentioned, you can simply compile your own build of MAME to enable the functionality. A guide can be found here.I think the easiest route is to choose one of the alternate builds of MAME that supports high scores. I use MAMEPlus, myself.It’s been a few years since I’ve tinkered with the setup, but if I recall, all I had to do was drop the hiscore.dat file in the main directory, and add a new subfolder in there called “hi”.The score saving doesn’t work on all games, but I find that it works on the vast majority, especially the classics.The way it works is it saves the memory location that contains the high score table when you exit the game, and loads that data back into the same memory location when you load the game next time. Be aware that if you use the “reset” function in MAME, that brings the score table back to factory default, and if you then exit the game, that table will overwrite any scores you had saved. Also, if you get a good high score, make darn sure you exit the game before powering down your system, otherwise the score won’t get written to disk. I made this mistake once when I broke my Missile Command high score; I simply powered down my MAME cabinet without exiting the game, and of course, was bummed to learn that the score hadn’t saved the next time I played the game. Quote Link to comment Share on other sites More sharing options...
cimerians Posted May 27, 2014 Share Posted May 27, 2014 I use MAMEUI, I turned auto save state on. Every time I exit MAME it saves and when I fire it up it reloads the state automatically. 1 Quote Link to comment Share on other sites More sharing options...
