Is there any way to use a bit as 255 or 1?
20 replies to this topic
#1 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 29,027 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Mon May 30, 2011 4:53 PM
I'm trying to figure out how to do the following with fewer steps:
   temp5 = 255 : if B_Direction_x{5} then temp5 = 1
   ballx = ballx + temp5
If I isolate the bit like this:
   temp5 = B_Direction_x & %00100000
I don't get 0 or 1, I get 0 or 32 (which makes sense, but I need zeros and ones).
If I can figure out how to convert that to 0 and 1, I'll still need to figure out how to turn the 0 into 255 and leave the 1 alone. I'm starting to understand bits a little more, but this is still way over my head.
Thanks.
#2 Devin OFFLINE
Devin
    Moonsweeper
  • 489 posts
  • Its all HCLR to me!
Posted Mon May 30, 2011 5:06 PM
Thanks.
You can right shift the result 5 times to get the 1 you need. You could then use the 1 or 0 as an index into a table containing 0 and 255.
#3 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Mon May 30, 2011 5:45 PM
I take it this is for reversing the direction of a ball when it collides with a wall or the like?
   rem * temp5 = 255 : if B_Direction_x{5} then temp5 = 1
   if B_Direction_x{5} then temp5 = 255 else temp5 = 1
perhaps something like this then? asm for speed:
  asm
  lda B_Direction_x
  and #$20  ;Is bit 5 enabled?
  beq set1  ;If 0 then add 1 else add 254
  lda #$FE  ;254 + 1
  adc BallX ;carry should be set so add FE to get 255
  sta BallX ;Save change
  jmp .exit
set1
  inc BallX ;Same as adding BallX + 1 which is what temp5 would hold here
.exit
end
[edit] Thanks for the catch RevEng, forgot to add the ballX :D
Edited by ScumSoft, Mon May 30, 2011 7:00 PM.
#4 RevEng OFFLINE
RevEng
    Bit Player
  • 5,214 posts
Posted Mon May 30, 2011 5:58 PM
RT's original only has one bitwise check vs a bunch of shifting, and it works out being the faster of the first two. ScumSoft's routine is the fastest of the bunch.
But in the spirit of the original question, you can turn the bit into a 255 or 1 in the following way...
temp5=(B_Direction_x&%00100000)/16)-1
The divide by 16 shifts the bit right 4 positions, so it's either 0 or 2. Subtracting 1 from that provides a result that is either 255 or 1.
#5 Random Terrain OFFLINE
Random Terrain
  • 29,027 posts
    Replay Value
    Nonlinear
Posted Mon May 30, 2011 6:27 PM
temp5=((B_Direction_x&%00100000)/16)-1
Thanks. So if I'm reading your post right, my crappy code with the if-then is faster than your code that divides by 16?
#6 RevEng OFFLINE
RevEng
    Bit Player
  • 5,214 posts
Posted Mon May 30, 2011 6:48 PM
Yup. The divide by 16 (or 4 right shifts) in mine is more costly than your code.
If you cherry picked the bit position so there was no dividing, mine would be marginally faster.
Actually, looking again at ScumSoft's code, it's equivalent in runtime to yours. I just didn't notice he skipped the final ballx addition in his.
[edit...]
On second thought, I guess ScumSoft's code could include the ballx addition more efficiently than the assembly generated from your bB code does...
  asm
  lda B_Direction_x
  and #$20
  beq set1
  lda #$FF
  BYTE $2C
set1
  lda #1
  clc
  adc ballx
  sta ballx
end
...but the difference in performance is pretty marginal.
#7 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Mon May 30, 2011 7:15 PM
RT unless you would run that in a loop counting many balls then the efficiency for a single one should be negligible.
Pretty slick code there RevEng, I forgot about the BIT trick since I never use it.
Edited by ScumSoft, Mon May 30, 2011 7:16 PM.
#8 RevEng OFFLINE
RevEng
    Bit Player
  • 5,214 posts
Posted Mon May 30, 2011 8:52 PM
Thanks, but it wasn't particularly clever on my part. Just a memorized trick. :)
As you say, there's hardly a difference between the solutions if you're running them only a few times. In that case the solution that's the most readable and maintainable in bB should be the winner, so the prize goes to RT! :D
#9 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,566 posts
Posted Mon May 30, 2011 9:25 PM
Use temp5 = temp5 ^ %11111110 (or temp5 = temp5 ^ 254). Assuming you've initialized temp5 to 1, this will toggle it between 1 and 255 (-1).
Michael
Edit: Or you could initialize temp5 to 255.
Edit #2: I'm not sure if my answer helps with your specific problem. I was answering the question "How do I toggle a variable between 1 and 255," which isn't exactly the question you were asking.
Edited by SeaGtGruff, Mon May 30, 2011 9:31 PM.
#10 Random Terrain OFFLINE
Random Terrain
  • 29,027 posts
    Replay Value
    Nonlinear
Posted Tue May 31, 2011 3:56 AM
Yeah, I forgot to answer that. It's for bouncing off the edges of the playfield.
It will be running constantly in the example program. This is a condensed version of what I originally had:
   dim B_Direction_x = h
   dim B_Direction_y = i
   ballx = (rand&127) + 8 : bally = 9 : rem * Starting position of ball.
   CTRLPF = $11 : ballheight = 2 : rem * Defines ball size.
   B_Direction_x = 255 + (rand&2) : B_Direction_y = 1 : rem * Ball starting direction.
Main_Loop
   rem  ****************************************************************
   rem  *
   rem  *  Bounce the ball if it hits the edge of the screen.
   rem  *
   rem  '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
   rem  '
   if ballx < 3 || ballx > 158 then B_Direction_x = -B_Direction_x
   if bally < 3 || bally > 88 then B_Direction_y = -B_Direction_y
   rem  *
   rem  *  Move the ball.
   rem  *
   rem  '
   ballx = ballx + B_Direction_x : bally = bally + B_Direction_y
   drawscreen
   goto Main_Loop
Seems like I've done code like that a billion times on the VIC-20 and the Commodore 64, but then it hit me that I was wasting 2 precious variables when I could do the same thing with 2 bits. So here's the condensed version of what I changed it to:
   rem * other bit variable names removed since they are not needed for this post
   dim B_Direction_x = t
   dim B_Direction_y = t
   temp5 = (rand & %00100000) : B_Direction_x = B_Direction_x ^ temp5 : rem * Ball starting direction.
   B_Direction_y{6} = 1 : rem * Ball starting direction.
Main_Loop
   rem  *
   rem  *
   rem  '
   if ballx < 3 || ballx > 158 then B_Direction_x = B_Direction_x ^ %00100000
   if bally < 3 || bally > 88 then B_Direction_y = B_Direction_y ^ %01000000
   rem  *
   rem  *
   rem  '
   temp5 = 255 : if B_Direction_y{6} then temp5 = 1
   bally = bally + temp5
   drawscreen
   goto Main_Loop
Since you said it's readable and maintainable and the speed isn't that bad, I guess I'll leave it the way it is.
Michael
Yeah, I don't need that for this example program, but I should add that to the bB page.
Thanks.
Edited by Random Terrain, Tue May 31, 2011 3:57 AM.
#11 RevEng OFFLINE
RevEng
    Bit Player
  • 5,214 posts
Posted Tue May 31, 2011 4:32 AM
If you do add it, it should be in the general case - xor can be used to toggle a variable between any two chosen values.
Picking 2 numbers out of a hat, say 13 and 96...
1. XOR them together with a calculator first, and note the result. (13^96=109)
2. Set your variable to either 13 or 96 initially.
3. XOR the variable with your calculator value (109) every time you want it to flip to the other value. (because 13^109=96 and 96^109=13)
...I used this same trick to make a compact shuffle animation in 21 Blue. In a loop I xor'ed each card pointer with a value that would change it from pointing to a blank image to a card back image. I replayed the loop 4 times. The first time would make cards appear, the second would make them disappear, the third would make the cards appear again, and the fourth time they'd disappear for good.
#12 roland p OFFLINE
roland p
  • 2,455 posts
  • $23
Posted Tue May 31, 2011 4:47 AM
This way the ball has to go through the border in order to detect a collision
You could first move the ball and then check for collisions.
And when a collision happens you could let it bounce also by mirroring its position:
if ballx < 3 then
   ballx = ballx + (3-ballx)
endif
So when ballx is 2, it will become 4 like it has bounced off the wall.
#13 Random Terrain OFFLINE
Random Terrain
  • 29,027 posts
    Replay Value
    Nonlinear
Posted Tue May 31, 2011 4:55 AM
I didn't even notice that my Microsoft calculator had an XOR button (when switched to the scientific view). I was just playing around with it and that sure is a handy button. That makes it easy to flip between any two numbers. I'll add it to the bB page later today as soon as I figure out exactly where it should go.
Thanks.
#14 Random Terrain OFFLINE
Random Terrain
  • 29,027 posts
    Replay Value
    Nonlinear
Posted Tue May 31, 2011 7:01 AM
Thanks. Before I did the border bounce code, I found out how far the ball could go, then pulled the numbers back so it wouldn't go past the actual borders.
#15 Random Terrain OFFLINE
Random Terrain
  • 29,027 posts
    Replay Value
    Nonlinear
Posted Wed Jun 1, 2011 7:26 AM
If you do add it . . .
I'm still not sure where to put it, so I stuck it here for now:
www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#how_to_flip
I can always move it later if someone can find a better place to put it.
#16 roland p OFFLINE
roland p
  • 2,455 posts
  • $23
Posted Wed Jun 1, 2011 7:37 AM
Never knew you could use the calculator for that :). I always wrote them out and put a '1' in the places that need to flip:
11111111 ;value a
00000001 ;value b
11111110 ;xor value
#17 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,807 posts
  • Medieval Mayhem
Posted Wed Jun 1, 2011 1:44 PM
The calculator in OS X does as well, you just have to switch via the View menu to Programmer.
#18 Random Terrain OFFLINE
Random Terrain
  • 29,027 posts
    Replay Value
    Nonlinear
Posted Thu Jun 2, 2011 6:34 AM
Thanks. I updated the page:
#19 bogax OFFLINE
bogax
    Dragonstomper
  • 793 posts
Posted Sat Jun 4, 2011 2:16 PM
This works (ie bB doesn't choke on it and it assembles)
 dim ballx_dir = a
 dim ballx_pos = b
 macro incv
 asm
 inc {1}
end
end
 macro decv
 asm
 dec {1}
end
end
 if ballx_dir & 32 then callmacro incv ballx_pos else callmacro decv ballx_pos
used my own names, sorry if that's confusing
#20 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,682 posts
  • begin 644 contest
Posted Sat Jun 4, 2011 3:05 PM
 dim ballx_dir = a
 dim ballx_pos = b
 macro incv
 asm
 inc {1}
end
end
 macro decv
 asm
 dec {1}
end
end
That's interesting, though this statement would compile exactly the same as yours without need for macros:
 if ballx_dir & 32 then ballx_pos=ballx_pos+1 else ballx_pos=ballx_pos-1
Edited by batari, Sat Jun 4, 2011 3:43 PM.
#21 Omegamatrix OFFLINE
Omegamatrix
  • 6,241 posts
Posted Sat Jun 4, 2011 3:16 PM
How about:
asm
     lda   B_Direction_x
     and   #$20
     beq   increaseDirection
     dec   ballx
     .byte $0C  ; NOP opcode, skip next 2 bytes
increaseDirection:
     inc   ballX
end
