Thwart an underground invasion with your transforming weaponry. The ground is scarred by craters, a reminder of the recent Dalaus invasion. And continuous acid rains give the sky an eerie irridescence. You are the only Transbot pilot left from the now defunct regime. So you must battle wave after wave of orbiting debris. To try to get to the notorious Dalaus artificial intelligence computer. Fortunately, your astro-plane can go through 6 different transformations. Turn into a robot warrior and more. By the time you transform, you should be able to penetrate the fortress of Dalaus. And rid the galaxy of her evil influence forever!
Deadline for high scores is July 21, 2011. Start on the default difficulty level, do not use continues.
Scoreboard:
zylon 183,660
JibbaJabba 147,340
bigbee99 136,840
roadrunner 80,540
JacobZu7zu7 35,380
4Ks 20,160
Hints & Tips:
Weapon D needed to enter the underbase, otherwise you just keep going on above. ~ zylon
Currest HSC Points:
zylon 372
roadrunner 320
Sonic R 118
4Ks 88
feldhaus97 56
JibbaJabba 32
CRV 30
CebusCapucinis 26
patbb 22
JacobZu7zu7 16
thegoldenband 12
bigbee99 12
Edited by 4Ks, Fri Jul 22, 2011 8:52 PM.
