How do we check if two bits are different?
14 replies to this topic
#1 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 27,425 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Wed Sep 28, 2011 2:32 AM
I know we can't use this:
if a{0} <> a{1} then blah blah blah
If I knew how to compare two bits, I forgot and I don't see it on the bB page.
The only thing I can think of is this:
if a{0} then if !a{1} then goto __Pause_Game
if !a{0} then if a{1} then goto __Pause_Game
Is that the best way to do it?
Thanks.
Edited by Random Terrain, Wed Sep 28, 2011 2:46 AM.
#2 RevEng OFFLINE
RevEng
  • 3,977 posts
  • Bitnik
Posted Wed Sep 28, 2011 8:54 AM
You can xor them together. If they differ, the result is 1. If they are the same, the result is 0.
As far as efficiency, if the bits are neighbors you come out ahead 9 bytes of rom space, for your example...
temp1=a^(a/2)
if temp1{0} then goto __Pause_Game
#3 Random Terrain ONLINE
Random Terrain
  • 27,425 posts
    Replay Value
    Nonlinear
Posted Wed Sep 28, 2011 9:23 AM
temp1=a^(a/2)
Thanks. Since it uses division, does that mean it's a little slower?
#4 RevEng OFFLINE
RevEng
  • 3,977 posts
  • Bitnik
Posted Wed Sep 28, 2011 9:50 AM
Yours is a bit faster because the comparisons avoid some work that mine does in constant time. (a division by 2 in this case only adds 2 cycles) I think your worst case scenario is 24 cycles, and mine is 33 cycles.
#5 Mr SQL OFFLINE
Mr SQL
  • 1,304 posts
Posted Wed Sep 28, 2011 10:59 AM
temp1=a^(a/2)
RT,
Bitwise operations are fast but I think it would be easier to just evaluate the bitwise expression if it is handled:
if (a{0} ^ !a{1}) then goto __Pause_Game
#6 Random Terrain ONLINE
Random Terrain
  • 27,425 posts
    Replay Value
    Nonlinear
Posted Wed Sep 28, 2011 2:01 PM
OK, thanks. I better put this on the bB page too.
RT,
Thanks, but I don't think we can do that with batari basic:
http://www.randomter...mmands.html#bit
#7 Emehr OFFLINE
Emehr
  • 4,127 posts
  • Happiness is... a chomping Pac-Man!
Posted Wed Sep 28, 2011 2:21 PM
temp1=a^(a/2)
Can you just bit-shift right once instead of dividing by 2? Or would that use the same number of cycles? (does bBasic support bit shifting?)
#8 Random Terrain ONLINE
Random Terrain
  • 27,425 posts
    Replay Value
    Nonlinear
Posted Wed Sep 28, 2011 2:37 PM
We can use assembly language:
http://www.randomter...s.html#assembly
But I usually try to keep things in bB mode for the bB page to avoid confusing new users. Unless it's something cool like this:
http://www.randomter...#points_roll_up
#9 Mr SQL OFFLINE
Mr SQL
  • 1,304 posts
RT,
Sorry RT,
I meant:
if(a{0}^a{1}) then ...
must have left the other operator in there; should work without the parenthesis if the compiler doesn't like them since only a single term is in the expression.
#10 Random Terrain ONLINE
Random Terrain
  • 27,425 posts
    Replay Value
    Nonlinear
Posted Wed Sep 28, 2011 2:44 PM
Sorry RT,
I meant:
Check out the "Did You Know?" box here:
Unless we were never told about it or something has changed, I think we are very limited when it comes to bit operations and if-thens.
Edited by Random Terrain, Wed Sep 28, 2011 2:45 PM.
#11 Mr SQL OFFLINE
Mr SQL
  • 1,304 posts
Posted Wed Sep 28, 2011 2:50 PM
Sorry RT,
I meant:
You're right, you can't use ^ that way, it flips two arguments I thought it was a comparison operator :(
I think your first solution has the least overhead.
#12 RevEng OFFLINE
RevEng
  • 3,977 posts
  • Bitnik
Posted Wed Sep 28, 2011 4:38 PM
bB automatically turns a divide with a power-of-2 into a number of LSR bit-shifts.
#13 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Wed Sep 28, 2011 5:56 PM
[edit]Very nice bogax!
My solution was way off
Edited by ScumSoft, Sat Oct 1, 2011 3:45 AM.
#14 bogax OFFLINE
bogax
    Dragonstomper
  • 619 posts
Posted Fri Sep 30, 2011 4:48 PM
Not sure I remember the conventions rightly, but assuming bit 0 is the
least significant bit ...
If you add a 1 to a bit you can, in effect, propagate it to a more significant
position via carry
If you add two bits together the sum is the XORing of the two
You can do both at once in this case by adding 1 to a
Then use & to isolate bit 1 to test it (ie a bitwise AND with 2)
if (a + 1)& 2 then goto __pause_game
__pause_game
produces
.L00 ; if ( a + 1 ) & 2 then goto __pause_game
; complex statement detected
LDA a
CLC
ADC #1
AND #2
BEQ .skipL00
.condpart0
jmp .__pause_game
.skipL00
.__pause_game
; __pause_game
That ought to be something like what you want
Edited by bogax, Fri Sep 30, 2011 4:50 PM.
#15 bogax OFFLINE
bogax
    Dragonstomper
  • 619 posts
Posted Fri Sep 30, 2011 10:16 PM
if a/2 ^ a & 1 then goto __pause_game
__pause_game
.L00 ; if a / 2 ^ a & 1 then goto __pause_game
; complex condition detected
LDA a
lsr
EOR a
AND #1
  BEQ .skipL00
.condpart0
jmp .__pause_game
.skipL00
.__pause_game
; __pause_game
