mimo Posted December 17, 2011 Share Posted December 17, 2011 I have an original xbox with a DuoX2 chip fitted. I would like to soft mod a mates xbox with a larger HDD, Is it possible to do this at all? How? Thanks Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 25, 2011 Share Posted December 25, 2011 (edited) It ought to be possible, but the main problem is that an unmodded xbox will not accept a hard drive unless it is locked specifically to the encryption key stored in the EEPROM. You at the very least have to find a way to read the EEPROM data off of the unmodded box. Or if you don't mind taking things apart, a good chip mod should be movable between units. Most of them may only have one wire other than the header, probably to the power/reset button. Move the chip over, get an EEPROM dump (for just in case), format the drive, lock the drive, then remove the chip. Of course newer board revisions will require a header rebuild to support the mod chip. EDIT: Hmmmm... and once you've installed the new hard drive, you will still need at least a softmod to be able to install stuff on it. Edited December 25, 2011 by Bruce Tomlin Quote Link to comment Share on other sites More sharing options...
onlysublime Posted December 26, 2011 Share Posted December 26, 2011 I'm a little confused on exactly what you want to do. What you want to do is softmod your friend's Xbox so that you can install a bigger hard drive? softmodding the old Xbox is by far the easiest way to do things. I have like 4 Xbox's modded that way with all varying HD sizes. My main Xbox is a 320GB. I have a 120GB Xbox. An 80GB Xbox. A 40GB Xbox. The preferred modding thing I use is CASH v1.1 or Cereal killas automated softmod helper. It's an automated wizard-like CD that does everything. Just download it, burn it to disc, run the disc, follow the on-screen prompts and you have a fully modded Xbox that can do everything from running XBMC to emulators to illegal ISOs, etc. etc. 1 Quote Link to comment Share on other sites More sharing options...
mimo Posted December 27, 2011 Author Share Posted December 27, 2011 Thanks, I will have a look into those Quote Link to comment Share on other sites More sharing options...
guy767 Posted January 31, 2012 Share Posted January 31, 2012 The preferred modding thing I use is CASH v1.1 or Cereal killas automated softmod helper. It's an automated wizard-like CD that does everything. Just download it, burn it to disc, run the disc, follow the on-screen prompts and you have a fully modded Xbox that can do everything from running XBMC to emulators to illegal ISOs, etc. etc. Do you have to hot swap a stock Xbox hard drive still with CASH v1.1? I haven't soft modded Xboxes in years but I used the NDURE INSTALLER FOR XBOXHDM via the hot swap method and PC boot disk. It worked well but it was a bit unnerving hot swapping an Xbox drive to my PC that's for certain; getting the timing right for the hot swap was a real pain. Would you recommend CASH v1.1 over NDURE INSTALLER FOR XBOXHDM onlysublime? Is hot swapping and a PC boot disc still necessary or has a better way to softmod an Xbox been created in the past 4 years? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 31, 2012 Share Posted January 31, 2012 You probably already got your answer but.. I'd soft mod the xbox with the existing hard drive. Once it's been soft modded using the tools to figure out the hard drive key should be easy. Quote Link to comment Share on other sites More sharing options...
Jordiway Posted February 9, 2012 Share Posted February 9, 2012 there is a program called flashfxp you can copy the existing hard drive after you mod to the new hard drive Quote Link to comment Share on other sites More sharing options...
