ATR Tools
First Release
227 replies to this topic
#1 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Fri Dec 30, 2011 2:17 AM
This is a Work-In-Progress program that runs on Windows.
It allows you to do many things with ATR, XFD and PRO images...
http://www.fiftyonef...i/AtrTools.html
Download and let me know what you think so far :)
Jay
#2 Larry ONLINE
Larry
  • 4,111 posts
Posted Fri Dec 30, 2011 5:42 AM
I downloaded ATR Tools this AM, and tried it out with some 720-sector images. Does just great in light testing. Very attractive GUI!
I use APE a bunch, and this will be a very nice addition to the tools to maintain images.
Thanks for your work!
-Larry
#3 rdea6 ONLINE
rdea6
  • 2,836 posts
Posted Fri Dec 30, 2011 7:48 AM
Looking forward to Final version!!
#4 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Fri Dec 30, 2011 10:18 PM
Here's a small update if you have already used the installer. Just extract to the install folder...
This fixes the file viewer for XP and newer.
Jay
#5 rdea6 ONLINE
rdea6
  • 2,836 posts
Posted Sat Dec 31, 2011 3:31 AM
Jay
I get an occasional error with VTOC tab.
#6 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Sat Dec 31, 2011 4:43 AM
Which format options did you use to create the ATR?
#7 rdea6 ONLINE
rdea6
  • 2,836 posts
Posted Sat Dec 31, 2011 7:31 AM
NONE
2 sides
80 tracks
Later formated with MyDos and added some files and a directory with some files.
Reloaded to your program and checked some of the tabs, and at the VTOC tab check disk box it crashed.
#8 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,557 posts
  • What is your Alternate Reality?
Posted Sat Dec 31, 2011 7:42 AM
Do you have Sparta-Dos compatibility on your to-do list?
#9 DanBoris OFFLINE
DanBoris
  • 1,025 posts
Posted Sat Dec 31, 2011 11:17 AM
When I run it I get a Path/File Access Error.
#10 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Sat Dec 31, 2011 3:32 PM
NONE
2 sides
80 tracks
The VTOC check currently only works with SD and ED images.
Yep, MYDos too...
Did you use the installer or just the update? and which windows OS?
Jay
#11 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Sat Dec 31, 2011 7:53 PM
NONE
2 sides
80 tracks
Could you post the image so I can verify the fix?
#12 rdea6 ONLINE
rdea6
  • 2,836 posts
Posted Sat Dec 31, 2011 8:31 PM
Attached File  NewDisk.ATR   360.02KB   173 downloads
This is it..
#13 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Sat Dec 31, 2011 11:23 PM
Okay, I made some changes so that the VTOC Check will call the proper procedure for the different DOS formats. SpartaDos and MyDos checkers don't do anything yet...
Also changed the file viewer to show binary files better.
Jay
#14 Larry ONLINE
Larry
  • 4,111 posts
Posted Sun Jan 1, 2012 5:20 AM
Is the proper way to use the updates is to simply replace the .EXE file in the program folder after having used the installer for the original installation?
-Larry
#15 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Sun Jan 1, 2012 6:10 AM
-Larry
For now, yes :)
Jay
#16 DanBoris OFFLINE
DanBoris
  • 1,025 posts
Posted Sun Jan 1, 2012 8:14 AM
Jay
I found the problem, I needed to run it as administrator. I noticed you create the atari.fon file in the program directory. Under Vista, and I think Windows 7, programs can't write to the Program Files directory without permission. That's what was causing the rror.
#17 19Echo OFFLINE
19Echo
    Moonsweeper
  • 424 posts
Posted Sun Jan 1, 2012 9:45 AM
yup, running windows 7 ultimate. Used installer. On first bootup you get the run time error, you then have to chance it to run as administrator for it to work. Picture in the middle, not background
#18 HatNJ OFFLINE
HatNJ
  • 1,511 posts
  • When Im on Im on when Im off Im WAY off
Posted Sun Jan 1, 2012 12:03 PM
getting same error
ahh opened after I used Run As Administrator
#19 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Mon Jan 2, 2012 6:54 PM
True, if ran on an NT based OS and you're not logged in as Administrator, then you need to right-click on AtrTools.exe and select "Run As", then choose "Administrator" from "the following user" and type in your password...
I'll either add code to set the proper permissions to save the font file in the install folder when first ran or just package it in the installer and save the settings in the registry instead of an .ini file...
Jay
#20 kenames99 OFFLINE
kenames99
    Star Raider
  • 80 posts
Posted Mon Jan 2, 2012 11:14 PM
great! another windows only atr program.
#21 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Mon Jan 2, 2012 11:25 PM
It will run on Linux/Mac too if you use Wine/Parallels :)
Jay
#22 kenames99 OFFLINE
kenames99
    Star Raider
  • 80 posts
Posted Mon Jan 2, 2012 11:31 PM
I prefer to run os2. I dont do windows. only linux is the server and it is ONLY a server, no other apps.
#23 AtariGeezer OFFLINE
AtariGeezer
  • 2,903 posts
Posted Mon Jan 2, 2012 11:46 PM
Ohhhhh k...
#24 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,694 posts
Posted Tue Jan 3, 2012 5:24 AM
I know you are frustrated re the Satan that is Windows but please don't be frustrated at AtariGeezer, he's offered other alternatives that you don't have unfortunately...
#25 kenames99 OFFLINE
kenames99
    Star Raider
  • 80 posts
Posted Tue Jan 3, 2012 9:00 AM
I am not frustrated at AtariGeezer at all. just explained my setup to him. I would rather spend my time with opensource software that can be made to run anywhere. I even compile and run atari800 here on os2.
