I will let you know about the limited production of original SDrive of C.P.U. team.
I called SDrive Micro because due to its small size. My version is a redesigned of original project but to fit in a small box 70x50x20mm. The pcb is dual layer with smd only components, including the microcontroller. The SIO cable is permanent connected to device, and the ID switch can be set from a small hole at bottom. SD socket is a push on - push off type, and inside exist a header for any future programming.
Decal for cost reasons doesn’t exist, so anyone can add whatever you want. If you want to design one, I can provide in pdf the “image” from CAD.
Ok I ask for that as you see it in pictures 45 euro + shipping cost. Payment through Paypal. Any Paypal fee also to buyer.
I can ship that as simple irregular post registered or not. In case of “not registered” buyer must add in its Paypal payment this note “ I declare that the seller is not responsible if I do not ever receive the product and if it is broken.”
Thank you all for looking.
