Bad Man Jose Posted February 16, 2012 Share Posted February 16, 2012 The question of course, is can it be fixed. I have a friend of mine who has two INTV I master components and he is having issues with the controllers. Is it hopeless to try to repair them or is there a place out there that would work on them? Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted February 16, 2012 Share Posted February 16, 2012 (edited) if controllers are the problem, is it only the left controllers? If so take the right good controller out of of one and put it in the other and have one working system. Edited February 16, 2012 by pimpmaul69 Quote Link to comment Share on other sites More sharing options...
Bad Man Jose Posted February 16, 2012 Author Share Posted February 16, 2012 He describes the issue as " The directional disc on one side is inconsistent moving to the right on one console and to the left on the other. One is worse than the other if I rmember correctly." Apparently he is experiencing it with both controllers on both systems Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted February 16, 2012 Share Posted February 16, 2012 You can still buy replacement Intellivision mylar flexboards; GameGavel member edintv has several for sale: http://www.gamegavel.com/display.cgi?seller=edintv&categories=18100&search=1 I used two of these to refurbish a pair of Intellivision controllers just recently. The process of replacing them is a bit of a pain, but it brought the controllers back to life. Quote Link to comment Share on other sites More sharing options...
Games For Your Intellivision Posted February 17, 2012 Share Posted February 17, 2012 I have found that the Mylar does not usually wear out. Many times, taking apart a controller, cleaning it carefully.......prying up the metal 'fingers' that touch the mylar carefully, and screwing the controller back together tightly does the trick. I find that most of the time, the component on the hand controllers that fails the most is the wire....the mylar not so much. Quote Link to comment Share on other sites More sharing options...
roberto Posted February 17, 2012 Share Posted February 17, 2012 What about the black screen (of death)? One of my systems suddenly went black... this is what can also happen with dirty carts/contacts but I clean everything carefully and tried several carts so it shouldn't be the case this time. Any suggestions on possible causes/fixes? Quote Link to comment Share on other sites More sharing options...
Rev Posted February 17, 2012 Share Posted February 17, 2012 I have found that the Mylar does not usually wear out. Many times, taking apart a controller, cleaning it carefully.......prying up the metal 'fingers' that touch the mylar carefully, and screwing the controller back together tightly does the trick. I find that most of the time, the component on the hand controllers that fails the most is the wire....the mylar not so much. I also heard before somewhere that a circuit pen could be used if an actual 'break' was found on the printed circuit. But yeah, i have several systems where hte wires are hanging out of the controllers. I need to disassemble them. Quote Link to comment Share on other sites More sharing options...
AlvinKarpis Posted February 17, 2012 Share Posted February 17, 2012 I took my controllers apart and gave them a good cleaning and made sure that everything was connected and good Now they work great Quote Link to comment Share on other sites More sharing options...
