sometimes99er Posted May 17, 2012 Share Posted May 17, 2012 (edited) I *really* like Dark Star for the Jupiter Ace. The Jupiter Ace has the same screen resolution as the TI: 32x24 so this game is very easy to do on the TI. It could really be done in any language. http://www.youtube.com/watch?v=pQUt7r5OMC8 In TF it would be nice. You could just draw each level in the editor! No source code required to design each level. Then each level can be loaded and displayed very easily. If you want to change a level, just edit it in the block editor! Much the same, just another variant, and something I did less than a month ago. A stupid example of how I waste my time or enjoy fooling around - no strings. “Coding by example” is a way to go. Maybe you could do a line by line, from XB to TF, conversion (here in this thread) ? Easy to include in your book (under Examples or indeed Coding by examples). Edited April 4, 2018 by sometimes99er Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted May 17, 2012 Author Share Posted May 17, 2012 (edited) It even says "Original TI game" !? Edited December 29, 2014 by sometimes99er Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 17, 2012 Share Posted May 17, 2012 It may be this one (a TI calculator game)... Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted May 17, 2012 Author Share Posted May 17, 2012 (edited) Nah, think not - link from your link Edited December 29, 2014 by sometimes99er Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 17, 2012 Share Posted May 17, 2012 Hmmm.... How about... 13 VALUE X \ man x coordinate 9 VALUE Y \ man y coordinate 0 VALUE XT \ temp x 0 VALUE YT \ temp y 0 VALUE MOVES \ number of moves : DrawScreen ( --) 1 GMODE \ 32 column graphics mode 1 SCREEN \ black screen DATA 4 $FF00 $FF00 $FF00 $FF00 96 DCHAR DATA 4 $1818 $3CE7 $E73C $1818 104 DCHAR DATA 4 $0000 $0018 $1800 $0000 105 DCHAR DATA 4 $3C42 $8199 $9981 $423C 112 DCHAR 12 6 8 COLOR 13 11 0 COLOR 14 3 0 COLOR 2 8 96 16 HCHAR 3 23 96 11 VCHAR 14 8 96 16 HCHAR 3 8 96 11 VCHAR 5 11 96 1 HCHAR 6 22 96 1 HCHAR 12 12 96 1 HCHAR 11 19 112 1 HCHAR 13 TO X 9 TO Y X Y 104 1 HCHAR ; : CheckPos ( x y -- flag) XT YT GCHAR \ read screen at xt,yt CASE 96 OF 1 ( hit wall) ENDOF 112 OF 2 ( allow loop to exit) ENDOF \ othwerwise... X Y 105 1 HCHAR \ draw trail XT TO X YT TO Y \ update x & y to new position X Y 104 1 HCHAR \ draw man in new position MOVES 1+ TO MOVES \ increase moves counter 0 \ push 0 flag (prevent loop from ending) ENDCASE ; : Game ( --) DrawScreen 0 TO MOVES BEGIN 0 JOYST \ scan joystick #1 CASE 2 OF ( left) Y 1- TO YT X TO XT CheckPos ENDOF 4 OF ( right) Y 1+ TO YT X TO XT CheckPos ENDOF 8 OF ( down) X 1+ TO XT Y TO YT CheckPos ENDOF 16 OF ( up) X 1- TO XT Y TO YT CheckPos ENDOF 0 \ default case (joystick in centre position) ENDCASE 2 = UNTIL \ loop until CheckPos returns 2 on the stack ." HURRAH! IN " MOVES U. ." MOVES!" CR ; Just ask if there's anything you don't understand... Explanation of DATA Explanation of DCHAR Explanation of COLOR Explanation of JOYST (open the above links in a new tab) TF Color Sets.pdf TF COLOR set reference (they are numbered differently to BASIC, since TF gives you access to all 32 colour sets). Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted May 17, 2012 Author Share Posted May 17, 2012 (edited) Ah, thanks. Thanks for taking the time – doing the conversion. Actually looks pretty straightforward. Hmmm ... Guess I could try and tweak it into something like Dark Star (one screen to start with). The ZX version is apparently also black & white. The source might be here. Lots of versions here - even MSX. Edited May 17, 2012 by sometimes99er Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 17, 2012 Share Posted May 17, 2012 I'm just working on a 'proof of concept' for Dark Start now... I'll post it when I have something... Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 17, 2012 Share Posted May 17, 2012 Here's the story so far: \ dark star forget levelsblock 72 CONSTANT LevelsBlock \ starting block for levels 0 VALUE Column 0 VALUE Row HEX : BrickUDG DATA 4 7FAA D5A8 D0A0 C080 80 DCHAR DATA 4 FEA9 4101 0101 0101 81 DCHAR DATA 4 8080 8080 8080 807F 82 DCHAR DATA 4 0101 0101 0101 01FE 83 DCHAR ; : RobotUDG DATA 4 0000 030F 1F1F 3F3F 84 DCHAR DATA 4 3F3F 1F1F 0F07 0000 86 DCHAR DATA 4 0000 C030 D8E8 ECFC 85 DCHAR DATA 4 FCFC F8F8 F0E0 0000 87 DCHAR ; : HelperUDG DATA 4 007F 4D5F 7070 5070 88 DCHAR DATA 4 7050 7070 5F4D 7F00 8A DCHAR DATA 4 00FE B2FA 0E0E 0A0E 89 DCHAR DATA 4 0E0A 0E0E FAB2 FE00 8B DCHAR ; : OrbUDG DATA 4 0000 0000 0304 0808 8C DCHAR data 4 0808 0403 0000 0000 8E DCHAR data 4 0000 0000 C020 9050 8D DCHAR data 4 1010 20C0 0000 0000 8F DCHAR ; : EmptyUDG DATA 4 0 0 0 0 90 DCHAR ; DECIMAL : DefineGraphics 16 1 15 COLOR 17 1 15 COLOR 18 1 15 COLOR BrickUDG RobotUDG HelperUDG OrbUDG EmptyUDG ; : NextColumn Column 2+ TO Column ; : NextRow Row 2+ TO Row ; : DrawIt ( a b c d --) Column 1+ Row 1+ GOTOXY EMIT Column Row 1+ GOTOXY EMIT Column 1+ Row GOTOXY EMIT Column Row GOTOXY EMIT NextColumn ; : DrawBrick 128 129 130 131 DrawIt ; : DrawRobot 132 133 134 135 DrawIt ; : DrawHelper 136 137 138 139 DrawIt ; : DrawOrb 140 141 142 143 DrawIt ; : DrawEmpty 144 144 144 144 DrawIt ; : DecodeLevel ( level --) \ loads the level from a block, decodes it, and displays it PAGE 0 TO Column 0 TO Row LevelsBlock + BLOCK \ -- vdpaddr get the block DUP 0= ABORT" Cannot load level from disk" 9 0 DO \ 9 rows 16 0 DO \ 16 columns DUP \ dup the address V@ \ get a byte from VDP CASE ASCII B OF DrawBrick ENDOF ASCII @ OF DrawRobot ENDOF ASCII # OF DrawHelper ENDOF ASCII * OF DrawOrb ENDOF \ otherwise... DrawEmpty \ draw empty space ENDCASE 1+ \ advance to next position in block LOOP 48 + \ advance to start of next line in block NextRow \ advance to next screen row 0 TO Column \ reset column LOOP DROP ; : Go 1 GMODE DefineGraphics 0 DecodeLevel ; http://www.youtube.com/watch?v=-NALNEkemkU Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted May 17, 2012 Author Share Posted May 17, 2012 Very cool. Looks good. Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted May 19, 2012 Author Share Posted May 19, 2012 (edited) <deleted> Edited June 9, 2012 by sometimes99er Quote Link to comment Share on other sites More sharing options...
PeBo Posted December 28, 2014 Share Posted December 28, 2014 Looks like resurecting old topics is becoming a hobby for me... So how does one load this kick-ass game on a REAL 4A without a TurboForth1.2 Command Module??? Even more important (for folks like me who are eprom burning illiterate (for now)), where the heck can one acquire a TurboForth cartridge of ANY version??? I would really like to play with this language now that I've seen what it can do, but only if I can eventually use it WITHOUT an emulator. I've spent days googling and only found a 4 year old post saying they are "occassionally available on ebay", but in searching ebay I couldn't even find an old listing. So am I going to have to mortgage my home when I do find one, or does someone who has lost interest in it have one that they would be willing to sell for less than my soul and first born child. In the interim, assistance in getting Dark Star working on a REAL TI please!!! (yes I have both a decked-out PEB and a nanoPEB (and she wonders why we're broke this month! shhhh!) but no f18a) Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 28, 2014 Author Share Posted December 28, 2014 Also look here. 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted December 28, 2014 Share Posted December 28, 2014 If you are in the US, I can supply a TurboForth Vn 1.2.1 EPROM. You will need one of the Jon Guidry cartridge boards (I think the ArcadeShopper website still has them) and an empty cartridge case. Contact me directly at: Rmcarmany@aol.com Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 28, 2014 Share Posted December 28, 2014 Cartridge boards are generally available from me directly as assembled objects, ready to insert the ROM of your choice as acquired from Atrax, for $16 each, shipped to a US address. They fit perfectly into a TI case. I'm expecting a shipment of the bare 128K boards needed for TurboForth (they are also used for fbForth 2.0, Never-Lander, Arcturus, Rasmus cartridges, and many more) late next week, as I have used up my current batch for a soon-to-be-completed project. There are still a few of the bare boards up on the Arcadeshopper site--and I'll restock him as soon as my new boards arrive. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 29, 2014 Share Posted December 29, 2014 I've been meaning to attempt to port Dark Star to fbForth 2.0. Maybe I'll work on it soon. ...lee Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 29, 2014 Share Posted December 29, 2014 Yes it does run on the real hardware but you need the TurboForth cartridge for TurboForth just as you need the extended basic cartridge for extended basic programs. I recently managed complete level 3 on Darkstar. It's SOLID hard! You've been warned! Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted December 29, 2014 Share Posted December 29, 2014 I've not mastered Level 3. I think I just go there to die! Quote Link to comment Share on other sites More sharing options...
