retrogamer73 Posted May 19, 2012 Share Posted May 19, 2012 (edited) I've always been a fan of Sega Saturn, and would love to try some different game for it. But the current prices for most Saturn games are pretty expensive. I heard you can burn copies of Saturn games using programs like IMG Burn and Alchol 120%. I tried a game and didn't have any luck. Can someone please if it isn't to much to ask tell me step by step how to burn Saturn games, and what all programs I need. Edited May 19, 2012 by retrogamer73 Quote Link to comment Share on other sites More sharing options...
skosh Posted May 19, 2012 Share Posted May 19, 2012 Perhaps a silly question.... is your Saturn also modded to play cd copies? Quote Link to comment Share on other sites More sharing options...
retrogamer73 Posted May 19, 2012 Author Share Posted May 19, 2012 Perhaps a silly question.... is your Saturn also modded to play cd copies? I haven't installed a mod chip. But did open it up and tape down the part that can tell if the disc tray is opened, so I could do the swap trick easily. Quote Link to comment Share on other sites More sharing options...
Austin Posted May 19, 2012 Share Posted May 19, 2012 I am wondering the same thing. I have a modded system. I have only tried grabbing one game, but it was in a different format than what you usually find with burning 3DO, Sega CD, Neo CD, or CD-i games. Quote Link to comment Share on other sites More sharing options...
goldenegg Posted May 20, 2012 Share Posted May 20, 2012 There is absolutely nothing special needed to burn Saturn games. They are posted in standard ISO format and can be burned with any software supporting that format. 1 Quote Link to comment Share on other sites More sharing options...
Austin Posted May 20, 2012 Share Posted May 20, 2012 There is absolutely nothing special needed to burn Saturn games. They are posted in standard ISO format and can be burned with any software supporting that format. Hm.. that's like 3DO images. I'll have to try it again--I'm pretty sure the game I tried was a different format. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted May 20, 2012 Share Posted May 20, 2012 Might have been, but it was likely still a common/standard format. Imgburn should have no trouble with whatever you found. Quote Link to comment Share on other sites More sharing options...
goldenegg Posted May 20, 2012 Share Posted May 20, 2012 There is absolutely nothing special needed to burn Saturn games. They are posted in standard ISO format and can be burned with any software supporting that format. Hm.. that's like 3DO images. I'll have to try it again--I'm pretty sure the game I tried was a different format. It's possible the image you got was posted by someone that like to use proprietary image formats, like Nero's NRG. Keep looking and you're bound to find the game you want in ISO format. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted May 20, 2012 Share Posted May 20, 2012 How do you burn Sega Saturn games? That's easy! This post was brought to you by the ghost of Frank Drebin. 8 Quote Link to comment Share on other sites More sharing options...
Austin Posted May 20, 2012 Share Posted May 20, 2012 There is absolutely nothing special needed to burn Saturn games. They are posted in standard ISO format and can be burned with any software supporting that format. Hm.. that's like 3DO images. I'll have to try it again--I'm pretty sure the game I tried was a different format. It's possible the image you got was posted by someone that like to use proprietary image formats, like Nero's NRG. Keep looking and you're bound to find the game you want in ISO format. Yeah, I have a feeling that's probably what it was. Funny enough, Nero is what I use, so it might have been for one of the other programs available. I'll make it a point to track one down in the next couple of days since I'll be off work. I've yet to test if my mod even works with backups. Quote Link to comment Share on other sites More sharing options...
Seob Posted May 20, 2012 Share Posted May 20, 2012 can you play burned games using a action replay 4 in 1? I would ike to test a game that uses the 4 mb expansion. I know I can play import games with the 4 in 1. Quote Link to comment Share on other sites More sharing options...
mimo Posted May 20, 2012 Share Posted May 20, 2012 can you play burned games using a action replay 4 in 1? I would ike to test a game that uses the 4 mb expansion. I know I can play import games with the 4 in 1. no, that only works for genuine import games, you need a mod chip to enable cd-r use. A mod chip+Action Replay and you are good to go with copy imports! As for burning the images, some are in odd formats, such as bin+cue etc etc, I use Img Burn which copes with most stuff. Quote Link to comment Share on other sites More sharing options...
CGQuarterly Posted May 21, 2012 Share Posted May 21, 2012 I use Fireburner, and burn at a slow speed. If you want to burn imports, remember that you don't need a 4-in-1 or anything. Just use the Saturn Region Patcher software to change the region of the image before you burn it. Chris 1 Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted May 21, 2012 Share Posted May 21, 2012 If you want to burn imports, remember that you don't need a 4-in-1 or anything. Just use the Saturn Region Patcher software to change the region of the image before you burn it. Yeah, that's another option. Also, you could region-mod your Saturn. Mine turns Japanese if I hold down the reset button. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted May 25, 2012 Share Posted May 25, 2012 1. Mod your Saturn. (Why anyone would do the swap trick when it's not necessary and probably harmful to your system is beyond me.) 2. Get the 4-in-1 Pro Action Replay so you circumvent the region lock and play the full library of Saturn games (minus KOF '95 and Ultraman). 3. When you burn games, burn them at the slowest possible speed. If you try to whip through the burning process, the Saturn won't be able to read the discs. 4. Some games come in BIN/CUE format, and may include a lot of MP3s. You can't burn MP3s as redbook audio; these must be converted to WAV first, and all references to MP3 must be changed to WAV in the CUE file. The CUE file is a simple text file and can be opened and edited in Notepad. Hope that helps. 1 Quote Link to comment Share on other sites More sharing options...
cimerians Posted May 25, 2012 Share Posted May 25, 2012 Too lazy to mod my system....anyone willing? I see here: http://www.segastyle.com Not sure if they are trustworthing and 60 bucks ain't too bad. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted May 25, 2012 Share Posted May 25, 2012 3. When you burn games, burn them at the slowest possible speed. If you try to whip through the burning process, the Saturn won't be able to read the discs. 4. Some games come in BIN/CUE format, and may include a lot of MP3s. You can't burn MP3s as redbook audio; these must be converted to WAV first, and all references to MP3 must be changed to WAV in the CUE file. The CUE file is a simple text file and can be opened and edited in Notepad. Hope that helps. A good burning app (like ImgBurn) will handle that MP3 business for you automatically. Just load up the CUE file & burn. And you don't need to use the absolute slowest speed, as that may not be the best for your burner or media. Quote Link to comment Share on other sites More sharing options...
Megaman Legends Posted May 25, 2012 Share Posted May 25, 2012 You rub 2 sticks together and when you get a spark throw the games in! Quote Link to comment Share on other sites More sharing options...
PikaX_AtariAge Posted May 12, 2014 Share Posted May 12, 2014 I tried using IMG Burn, but it did not work at all. Quote Link to comment Share on other sites More sharing options...
PikaX_AtariAge Posted May 12, 2014 Share Posted May 12, 2014 You rub 2 sticks together and when you get a spark throw the games in! That's easy! burning.jpg The joke is funny, but we are talking about the burning where you put data on a CD or any other disc, not the literal type. Quote Link to comment Share on other sites More sharing options...
bennybingo Posted May 12, 2014 Share Posted May 12, 2014 The joke is funny, but we are talking about the burning where you put data on a CD or any other disc, not the literal type. A two year old necro-bump, and no sense of humor??? Quote Link to comment Share on other sites More sharing options...
CatPix Posted May 12, 2014 Share Posted May 12, 2014 If you want another joke, in French, Cd are "engraved" not burned. Also, funny developers pun : The Nero icon is the burning Coliseum. Why? Because Nero, the Roman emperor, set most of Rome on fire. So that's the pun : "Nero burning ROM" Quote Link to comment Share on other sites More sharing options...
Rhomaios Posted May 12, 2014 Share Posted May 12, 2014 1. Mod your Saturn. (Why anyone would do the swap trick when it's not necessary and probably harmful to your system is beyond me.)2. Get the 4-in-1 Pro Action Replay so you circumvent the region lock and play the full library of Saturn games (minus KOF '95 and Ultraman).3. When you burn games, burn them at the slowest possible speed. If you try to whip through the burning process, the Saturn won't be able to read the discs.4. Some games come in BIN/CUE format, and may include a lot of MP3s. You can't burn MP3s as redbook audio; these must be converted to WAV first, and all references to MP3 must be changed to WAV in the CUE file. The CUE file is a simple text file and can be opened and edited in Notepad.Hope that helps. This, all of this. If you want another joke, in French, Cd are "engraved" not burned. Also, funny developers pun : The Nero icon is the burning Coliseum. Why? Because Nero, the Roman emperor, set most of Rome on fire. So that's the pun : "Nero burning ROM" That's always been a headache for us Classicists, though, since the Colosseum (yes, there are two spellings, believe it or not!) wouldn't be start to be built until after Nero was deposed. Quote Link to comment Share on other sites More sharing options...
TheGameCollector Posted May 15, 2014 Share Posted May 15, 2014 If you made backups of your own games, UltraISO seems like a great program. I always choose to create bin/cue because that stores all the audio track information in the image instead of separate .wav files. When you burn them back onto the disc using IMGburn, the audio files play back on the disc when they are supposed to. If you use the ISO format instead, you can get problems like audio tracks not playing and such. Just some advice to keep in mind. This also goes for Sega CD, 3DO, TurboGrafx-16 CD, Neo Geo CD and Playstation. Dreamcast is the oddball that needs a program like DiscJuggler to do the job because you are bypassing GD-Rom and converting it to CD-Rom so it needs that special track at the beginning. I had someone modchip my Saturn to play burned discs but also install a Unibios so it could boot legit or burned copies of any region game on top of that without the need for Action Replay. Of course if I wanted to do a PAL game I would need a monitor that accepts those kinds of signals. The mod job cost me some good money but it's worth it not to waste money on bad games. There's a lot of treasure to be found on Saturn but it is good to be able to see for yourself what you like instead of blindly spending money on every game in existence as if they would all fit in your home. (Of course some people have large enough homes to do that, or a storage unit or two.) Quote Link to comment Share on other sites More sharing options...
Spanner Posted December 19, 2014 Share Posted December 19, 2014 (edited) I tried coping a Saturn game,A pal game from the ISO Zone with ImgBurn,just like how I did it with mega cd games and when it comes to verifying the CD it can't read the first track and comes up with errors but I do the same thing with a Mega CD image (Cue/bin) and they work fine...? Edited December 19, 2014 by Spanner Quote Link to comment Share on other sites More sharing options...
