Posted Thu Jun 21, 2012 2:21 PM
Posted Thu Jun 21, 2012 2:38 PM
Anyway, did anyone else here NOT know that the Atari 2600 was actually in stereo? There's apparently a whole host of games that support it too... like Combat (for example) which will have the shooting sound effect come from whatever side of the screen it's shot from...
Edited by FujiSkunk, Thu Jun 21, 2012 2:41 PM.
Posted Thu Jun 21, 2012 2:57 PM
some later games tooSo only those earliest games were programmed with stereo effects in mind.
Posted Thu Jun 21, 2012 3:56 PM
The 2600 has two sound channels, and it is possible to tap into each sound channel discretely on the motherboard. That by itself wouldn't necessarily mean the 2600 was meant to be in stereo, except that ability is in fact by design.
Lots of dedicated game systems released in the '70s didn't bother sending audio to the TV and instead had beepers or other such bits in the console itself. The 2600 was going to take that a step further, with two built-in speakers, one for each sound channel. You can see a leftover artifact of this design in the earliest 2600 cases, which have speaker "vents" built into the case in front of the cartridge port.
Early games like Combat were programmed to take advantage of this by dedicating a sound channel to each player. So it's not that the sound is programmed to come from the "correct" side of the screen, but that the sound on a given side would always represent the same player's movements, shots and explosions. Atari eventually scrapped the speaker idea, I believe to keep the costs down, and went with mixing the audio into the TV signal instead. So only those earliest games were programmed with stereo effects in mind.
Posted Thu Jun 21, 2012 4:05 PM
Oh ok... so like 2 voice polyphony?
Ok, I guess the guy mis-interpreted it... but I can see how he would have assumed it was stereo.
Posted Thu Jun 21, 2012 4:59 PM
Posted Thu Jun 21, 2012 5:15 PM
Posted Fri Jun 22, 2012 8:17 AM
Posted Sat Jun 23, 2012 8:55 PM
Posted Tue Apr 21, 2015 5:06 PM
Forgive me for digging up such and old thread but google brought this up during some research.
I was viewing that PDF posted above and the Atari stereo mod.
I do not understand why they used resistors and soldered them back to the motherboard?
Why not simply solder to the pins 12 /13 (without pulling them) and go straight to the RCA jacks with a 1uf cap.
Perhaps this has to do with keeping RF intact.
I would composite mod if going through the trouble of stereo.
Am I missing something here?
Thanks,
Edited by retrofixes, Tue Apr 21, 2015 5:28 PM.
Posted Tue Apr 21, 2015 5:55 PM
I think the resistors are required because the output from the TIA is too "bright" and maybe would be distorted and loud without them?
You should try what you suggest, though, maybe by just using alligator clips instead of soldering, and then report back on how it does or does not work.
That definitely would be a great addition to the conversation! I'd be interested to hear if it works.
-a2a
Posted Tue Apr 21, 2015 6:43 PM
I've used that connection before without issue. The output is what you would expect from a 5v chip. The audio is actually quiter when tapping the chip directly. This bypasses the audio amp but also gives a clean near perfect audio signal.
This stereo mod is very similar to what is performed on NES consoles.
I have a few prototyped Atari PCB kits with the composite + stereo option or mono option.
Though I never realized some games were designed for stereo, that is exciting and justifies the mod in my opinion
Looking at the old PDF made me question the install.
Edited by retrofixes, Tue Apr 21, 2015 6:48 PM.
Posted Wed Apr 22, 2015 7:44 AM
I never knew this until a read a description of Medieval Mayhem the other day. I always suspected the round cut-outs on my old six switcher were for speakers. Back in usenet days, many seemed to think it was for venting.
I know this is a revived thread from years ago, but can someone explain this to me? Isn't that like saying the 2600 wasn't necessarily meant to be in color but it was designed to be in color?
Oh ok... so like 2 voice polyphony? Sort of like how the Tandy has a 3-voice speaker (vs the PC's 1 "voice" if you will... heh).
What does how many sounds something can play simultaneously have to do with stereo? If you have separate sounds coming from a left channel and right channel, it's stereo.
Posted Wed Apr 22, 2015 7:53 AM
For stereo sound, the sound comes out the appropriate side of the screen for the action that occurred.
Based on the earlier games, any sound effect for the left player came out the left speaker even if the event happened on the right side of the screen.
In other words, as originally used, each player had a mono speaker that was dedicated for just their sound effects.
It's likely that if it had shipped with two speakers then some games would have utilized them as stereo speakers, just like some homebrews have.
Edited by SpiceWare, Wed Apr 22, 2015 7:55 AM.
Posted Wed Apr 22, 2015 8:03 AM
Wouldn't that would be a game feature and not the definition of stereo?
Posted Wed Apr 22, 2015 9:23 AM
Stereophonic sound or, more commonly, stereo, is a method of sound reproduction that creates an illusion of directionality and audible perspective.
Posted Wed Apr 22, 2015 10:04 AM
So you're implying that Combat is stereo as long as each player stays on their side of the playfield...once they cross that center point and it's no longer accurate to the image on a TV screen, it becomes two channels of mono?
Seriously, what does "onscreen" or video have to do with the true definition of stereo? If I listen to a Beatles album, it's still stereo with no video reference attached to it. Stereo was around long before it became a feature on TVs in the early 80s.
Posted Wed Apr 22, 2015 10:34 AM
Not implying that at all - Combat was not designed for audio directionality, therefore it's not a stereo game. Games like Medieval Mayhem and Skeleton+ were designed with directionality, therefor they are stereo games.
Anyway you're now coming across as being intentionally obtuse, so I don't plan to make any more responses.
Posted Fri Apr 24, 2015 2:42 AM
... Combat was not designed for audio directionality, therefore it's not a stereo game...
Edited by macdlsa, Fri Apr 24, 2015 2:45 AM.
Posted Fri Apr 24, 2015 3:33 AM
Thus, a modded VCS with proper separate audio outputs IS stereophonic
...Try to listen to Thrust+ score !!! It's really, really amazing !
Thrust may sound stereophonic, but that's mainly because of the music player code design and how it is used. In this tune, channel 0 and 1 both have their own pattern set. So e.g. the "drum" pattern are always played on the same channel. However, both channels could share the pattern set, and the "drums" could move back and forth between the channels. If you are e.g. playing three different instruments with just two channels, you have prioritize*. And then the instruments change channels permanently.
Effectively this may (I have no modded 2600) result into a nice stereo effect in Thrust, but IIRC it was not designed that way.
* The same is true for sound effects, usually you have priorities there too.
Posted Fri Apr 24, 2015 8:05 AM
That priority matter is very interesting ! Although I'm not a programmer, I could understand how it works, and I mean it : Thrust+ score is NOT designed to have such a (nice !) stereo effect.
But that's not my "point", Tom : it actually HAS a stereo sound, if you use an audio-out modded console ! You used both sound generators in Thrust+ code, then, what I want to say is :
-Almost all VCS' games, with some exception (for example, Defender and Jungle Hunt audio runs on left channel only...), use both sound generators
-On modded VCS every single generator is directly connected (yep, with the appropriate components such as the capacitor to avoid any undesidered ***and pernicious*** continue voltage) to its "proper" output thru RCA PinJack connector.
-Finally, we have two separate audio outputs, and that's enough to identify this device as stereo, even if almost all its software collection is NOT intended to be "stereoscopic sounding" !
Believe me : use a stereo-mod VCS, "treat" Thrust+ music score with a tube-preamplifer, as I did in that retrocomputing/gaming "expo" shown in my previous picture, and you won't go back to a monaural output VCS .
Posted Fri Apr 24, 2015 8:46 AM
... forgot...
@ 82-T/A : http://atariage.com/...vy#entry3071622
@Tom : http://atariage.com/...vy#entry3100836
Posted Fri Apr 24, 2015 8:59 AM
Posted Fri Apr 24, 2015 9:25 AM
Yep, and also Boulder Dash sounds pretty cool !
... seems you have had a kind of "regard" in doing the score of your games, Tom
Posted Fri Apr 24, 2015 9:47 AM
