Images generated by RastaConverter
Images Gallery RastaConverter Colors
1859 replies to this topic
#1626 kiwilove OFFLINE
kiwilove
    Dragonstomper
  • 885 posts
Posted Tue Apr 17, 2018 8:58 PM
I'm no expert nor regular user of Rasterconverter - and would like to comment the following...
Because of the limited colours and resolution of the Atari graphics mode - if you start with pictures which are close to this already - you should have greater success - so to speak?  And it is when you are using normal pictures/photographs as such - it is so much harder for any decent result to happen - without any of usual faults Rasterconverter ends up showing - those visible horizontal bands.  People are only posting their successful conversions here - so you don't see the various failures that typically happen.
It is an amazing program - when you see what it can do - as in the various examples posted.
It is very much a lottery as to what picture ends up looking great - and usually you do see it pretty quickly - that you only have it running over a long period of time - just so as for it to clean up on some important detail here and there.
The good thing of course - is that you can have it doing this in the background - while you are doing other things on your laptop?  And you can even have up to 3? windows of Rasterconverter running at the same time - if you wish to, if your laptop can handle it?
Harvey
#1627 Rybags OFFLINE
Rybags
  • 15,891 posts
Posted Tue Apr 17, 2018 11:30 PM
Certain pic types work better than others.
If the detail and colour changes are more oriented towards vertically, e.g. graduated mountain ranges in a sunset then it deals with it better than something like a rainforest on the left with waterfall in the middle and beach on the right.
High dynamic range should be better than low, ie - if the luminances are spread about rather than close shades.
When running the program, the destination shows a "better than best case scenario" - so you know what you'll end up with will resemble it in some way but not be as good.  So if the destination looks crap it's a quick and easy way to know to just quit and either do some preprocessing of the image or try different dithering settings.
The program allows selecting how many threads to run.  You'd probably get better throughput by single-streaming images rather than doing multiples at once though that said the nature of the thing is that you quit when a pic looks good and optionally resume processing after testing it out.  To that end, then you may as well parallel process.
I think you'd need to make extra copies of the RC program directory as it saves work files.  Alternatively you might be able to just use shortcuts with different startup directories - unsure, the program's sufficiently small to just have multiple copies of it.
# of threads - if you have e.g. a quad-core i7 with hyperthreading enabled then in theory you'd get best throughput on a single job by running 8 threads, though it'd bog down anything else trying to run on the machine.  I've found in such cases (like MediaCoder video encoding), run with all but one or two virtual cores active or enable the affinity to all but one or 2 depending on the program.
#1628 Irgendwer OFFLINE
Irgendwer
  • 1,410 posts
Posted Tue Apr 17, 2018 11:47 PM
Round 2
FIGHT!
#1629 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Mon Apr 30, 2018 9:31 PM
Breaking Beyond. 49 colors.
Relativity Of Gravity. 70 colors.
Spring Loaded! 49 colors.
64 Galaxie 500. 54 colors.
#1630 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Tue May 1, 2018 5:25 PM
Blue Brook Falls. 72 colors.
Rifle Creek Docks. 46 colors.
#1631 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Wed May 2, 2018 4:31 PM
I've been doing some "spring cleaning" of late with my Rastaconverter file folders, dusting off some pictures I never got around to converting, a final judgement of some images I was never satisfied enough with to release before, then keeping or disposing  of them and lots  of old source images. The recent images I've posted are new conversions, from old sources, and here are a couple of old conversions I sat on, not satisfied enough to release before, but what the hell. :P  At least I don't think I posted these before...sorry if I have.
Battle For Sansara (Andromeda). 32 colors.
Ancient Spires. 46 colors.
#1632 SpikedRN OFFLINE
SpikedRN
    Space Invader
  • 13 posts
Posted Wed May 9, 2018 12:58 AM
Ciri from The Witcher III -- 175 million evaluations. The output looks fairly good on my PC, but the colors are very washed out on my NTSC 800xl. Maybe I'm not using the correct palette?
Attached File  SpikedRN_Witcher3_Ciri.xex   22.21KB   34 downloads
#1633 Gury OFFLINE
Gury
  • 1,276 posts
Posted Thu May 10, 2018 2:39 AM
At age of 93 Miki Muster, one of the greatest cartoon and comics artists from Slovenia, died. He is well known of adventures of Zvitorepec, Trdonja and Lakotnik. Many of us enjoyed and still do enjoy reading these comics and remember them well from our childhood.
Link to the sad news.
Here is original and converted pic of our heroes:
Edited by Gury, Thu May 10, 2018 2:40 AM.
#1634 a8isa1 OFFLINE
a8isa1
  • 1,530 posts
Posted Thu May 10, 2018 10:04 AM
Revisiting strong dithering (knoll, dither_val=8.0).  I'm shooting for lighting versus detail.
Would someone with real NTSC hardware try this and post comments?   Thank you.
If you wish to view with an Emulator try Atari800 using one of my palettes (see my sig)
In Altirra I don't know if importing a palette is possible (I can't find the option).  Select NTSC mode and in 'adjust colors' default XL, hue start -44, 24.1 degrees, and Saturation 30.
Edited by a8isa1, Thu May 10, 2018 10:52 AM.
#1635 a8isa1 OFFLINE
a8isa1
  • 1,530 posts
Posted Thu May 10, 2018 12:14 PM
This one worked very well.
Slight Chess dither, dither_val=0.5, dither_rand=1.2.
NTSC palette (see my sig).
#1636 SpikedRN OFFLINE
SpikedRN
    Space Invader
  • 13 posts
Posted Thu May 10, 2018 7:15 PM
I'll give them a try later when I get a chance. I did a few images using your NTSC 30 saturation palette @a8isa1
Seeing how many colors I could get in one image. 135 million evals with NTSC palette.
Attached File  SpikedRN_color_gradient_135m.xex   22.08KB   18 downloads
Another try at Ciri but using an NTSC palette this time. Skin tones look much better on my 800xl than the other one I did.
Attached File  SpikedRN_Witcher3_Ciri_NTSC.xex   22.06KB   18 downloads
Here's one of Jupiter. 100M evals with laoo palette and knoll dither.
Attached File  Jupiter.100M.laoo.cie94.knoll.xex   18.61KB   25 downloads
#1637 SpikedRN OFFLINE
SpikedRN
    Space Invader
  • 13 posts
Posted Thu May 10, 2018 9:16 PM
Here are some examples showing the output of different palettes using a common image as input. Using these should allow you to find a palette that most closely matches the actual output on real hardware. Common settings: ciede with no dithering.
Source image
Attached File  Colors_ciede_altirra.xex   18.85KB   15 downloads
Attached File  Colors_ciede_atari800winplus.xex   18.85KB   13 downloads
Attached File  Colors_ciede_Default.xex   18.7KB   14 downloads
Attached File  Colors_ciede_g2f.xex   18.88KB   13 downloads
Attached File  Colors_ciede_jakub.xex   18.71KB   13 downloads
Attached File  Colors_ciede_laoo.xex   18.65KB   13 downloads
Attached File  Colors_ciede_NTSC.xex   18.73KB   11 downloads
Attached File  Colors_ciede_NTSC30.xex   18.87KB   12 downloads a8isa1 NTSC saturation 30
Attached File  Colors_ciede_NTSC40.xex   18.7KB   12 downloads a8isa1 NTSC saturation 40
Attached File  Colors_ciede_NTSC50.xex   18.85KB   13 downloads a8isa1 NTSC saturation 50
Attached File  Colors_ciede_OlivierP.xex   18.81KB   13 downloads
Attached File  Colors_ciede_Real.xex   18.29KB   12 downloads
Attached File  Colors_ciede_Xformer.xex   18.63KB   16 downloads
Edited by SpikedRN, Thu May 10, 2018 9:19 PM.
#1638 Gury OFFLINE
Gury
  • 1,276 posts
Posted Sat May 12, 2018 2:44 AM
Some more of Zvitorepec, Trdonja and Lakotnik:
#1639 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Mon May 14, 2018 4:23 PM
Amber Afternoon. 43 colors.
Covered Bridge. 60 colors.
Rural Home. 69 colors.
#1640 RAM OFFLINE
RAM
    Star Raider
  • 58 posts
Posted Tue May 15, 2018 1:33 PM
It's always a good day when I visit AA and see Gunstar has posted some more pictures!
#1641 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Thu May 17, 2018 7:57 PM
Find your beach.
Ocean Cave. 65 colors.
#1642 a8isa1 OFFLINE
a8isa1
  • 1,530 posts
Posted Thu May 17, 2018 8:35 PM
Find your beach.
Another favorite!  Thanks!
#1643 pirx OFFLINE
pirx
    Moonsweeper
  • 443 posts
Posted Fri May 18, 2018 2:56 AM
Find your beach.
this pic is almost gfx compo quality. kudos!!! the previous set with rural homes kixx ass as well. basically perfect use of the technique.
Edited by pirx, Fri May 18, 2018 2:58 AM.
#1644 Rybags OFFLINE
Rybags
  • 15,891 posts
Posted Fri May 18, 2018 5:11 AM
In terms of source material definitely not the best picture but in terms of technical compatibility with what RC is capable of and producing a very good result, near unmatched.
#1645 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Fri May 18, 2018 7:55 AM
Source material makes a huge difference depending on what it is. Ocean Cave is from a photograph, the houses and bridge were from paintings.The source image medium has a huge effect on the final outcome.Photos are much easier to get good results than artistic renderings.
#1646 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Fri May 18, 2018 8:42 AM
Either way, a compliment to be sure, but when you say "compo" I'm not sure if you are referring to a "competition" or a "composition."
#1647 a8isa1 OFFLINE
a8isa1
  • 1,530 posts
Posted Sun May 20, 2018 10:00 AM
PAL version
For intended saturation in Altirra bump it to 45 or in Atari800 use the palette in my sig.
#1648 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,038 posts
Posted Sun May 20, 2018 1:13 PM
Ocean cave... first I thought its the source gif like
Pic. Awesome.
#1649 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,689 posts
Posted Sun May 20, 2018 8:48 PM
This one I forgot about and let it run too long, so it has a small line-segment-error (when viewed on a real Atari), but it's small and off to the side, so I didn't feel like re-doing it. Also the first attempt, so it's not as good as it might be, but I think it's good enough.
Atari Fuji. 88 colors.
Edited by Gunstar, Sun May 20, 2018 8:55 PM.
#1650 Rybags OFFLINE
Rybags
  • 15,891 posts
Posted Mon May 21, 2018 1:15 AM
Nice but too easy for RC - the real challenge would be to do the colour graduations as diagonals and see how it handles that.
Also tagged with one or more of these keywords: Images, Gallery, RastaConverter, Colors
