Images generated by RastaConverter
Images Gallery RastaConverter Colors
1792 replies to this topic
#1776 Rybags OFFLINE
Rybags
  • 15,789 posts
Posted Fri Aug 10, 2018 7:05 AM
Home system palette - ie one that's going to give you a result that looks closest to what your Atari computer will generate on a TV.   So, a NTSC based palette if your system is NTSC.
#1777 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,443 posts
Posted Fri Aug 10, 2018 7:32 AM
Okay well thanks for clearing that bit up (which is no issue of mine, never was)but your original post still seems discombobulated. One person mentioned that the car looked gold to them in the Corvette picture(an isolated incident) and another person lamented that they wished they had a PAL system still to look at the pictures I made in PAL, so I offered to do a version in NTSC for them and that's it.
Edited by Gunstar, Fri Aug 10, 2018 7:50 AM.
#1778 Rybags OFFLINE
Rybags
  • 15,789 posts
Posted Fri Aug 10, 2018 8:07 AM
The lament for PAL is that colour 3 is red and the adjacent colours aren't very close to red, unlike blue which is well covered and green which is almost as good.
Just how or why any system would display red as gold/brown is a mystery to me.  I'm not sure you could even get that with a badly adjusted colour pot.
#1779 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,443 posts
Posted Fri Aug 10, 2018 9:05 AM
My understanding of the lament for PAL was that ALL my image's colors look wrong on NTSC, because I use a PAL palette, and since I don't normally do NTSC, he misses out on seeing them as they should be with PAL versions, and had nothing to do with the color red in particular nor anything to do with the other comment by a totally different person regarding red looking gold. I understood them to be two totally unrelated comments.
As to the gold color issue, I agree.
Edited by Gunstar, Fri Aug 10, 2018 9:16 AM.
#1780 _The Doctor__ OFFLINE
_The Doctor__
  • 5,177 posts
Posted Fri Aug 10, 2018 9:36 AM
3 different 130XE's
and 2 800XL's
same gold 'vette  reminds me of when they were mucking about with jungle hunt adjustment pal-ntsc.... tree trunk being red/brown versus tree trunk being yellow green etc....
composite/lca/rf all the same..
Samsung shows the same as Olevia
Edited by _The Doctor__, Fri Aug 10, 2018 9:37 AM.
#1781 Rybags OFFLINE
Rybags
  • 15,789 posts
Posted Fri Aug 10, 2018 10:02 AM
OK, I've worked it out.
It's actually using colour 2 for the red.  You can see this in Altirra - enable the debugger.
Then use command GS 170 which will break at that scanline which is mostly the body coloured pixels.
Then enter .gtia which will dump the registers.
Note the colours - particularly the first 2 players and the first 3 playfield colours listed - all variants of colour 2.
I've not got a machine setup but pretty sure that on a real PAL you'd get a reddish gold as well.
So the problem isn't with anyone's machine but with the palette used by RC - the conversion uses nearest match based on whatever palette you give it, which in this case seems to not be quite right.
#1782 _The Doctor__ OFFLINE
_The Doctor__
  • 5,177 posts
Posted Fri Aug 10, 2018 10:24 AM
as I have now started a rasta converted image download frenzy,  I do believe notating if it uses pal/ntsc palette on am image might be a good idea, of course posting it both ways would be very cool..
Many look stunning and match just fine comparing online image to actual hardware.. others may not or don't, and you may find needing to switch palette in Altira is needed to make them match as well...
It looks solvable.. :)         Since I almost always use real hardware with only what I feel are the crucial fixes I run into stuff fairly often these days
Edited by _The Doctor__, Fri Aug 10, 2018 10:47 AM.
#1783 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,443 posts
Posted Fri Aug 10, 2018 11:04 AM
Unfortunately to have both PAL and NTSC versions, a complete conversion needs to be done for each, with no guarantee that you'll get the same results with any given image, and oft times completely different Rasta settings are needed to get the desired result. For every image I post, there are an average of a half-dozen to a dozen attempts, each taking hours, letting it run it's course and it got real old real quick back when I was posting both PAL and NTSC versions. Plus, right now I only have a PAL computer, so I can never see actual results for NTSC images on a real NTSC machine either, which is a vital part of the process as to the final image I accept and post, So I never know if my NTSC versions look as good on the real hardware as my PAL images. But all my PAL images are done shooting for the best result on my real Atari and I never even bother to see what they look like on Altirra. My key audience is people that use real Atari's like myself, even then, all Atari's video's are not equal including stock and upgraded. All I ever see for comparison, are the destination image, then the output.png I post here, and what I see on my real PAL Atari as described below (in sig).
My current working system is a unique anomaly though, being PAL on a system that never was, and in the middle of the U.S. I also have a couple NTSC machines, but they are not currently working. When they are, I will eventually do more NTSC images. But, most of the time I will still do my Rasta conversions on my PAL hardware, for the full 240 over scan resolution.  As to notation of PAL vs. NTSC, I do that if I post both versions or if I make exceptions and do a few NTSC images. Otherwise, if NOT noted, my stuff is always PAL.
'57 Chevy. 69 colors.
Signal Gasoline station. 72 colors.
Edited by Gunstar, Fri Aug 10, 2018 11:24 AM.
#1784 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,443 posts
Posted Sat Aug 11, 2018 8:40 AM
Corvette NTSC. 98 colors.
#1785 a8isa1 OFFLINE
a8isa1
  • 1,513 posts
Posted Sat Aug 11, 2018 4:08 PM
Thanks but my 800XL is out of adjustment.  I could never get it (along with my scan converter) to line up with any palettes available for Rastaconverter. I had to come up with my own palette.
After I last posted I remembered that my scan converter does reasonably well with PAL images if I shift the hue 3 steps to the left.
Edited by a8isa1, Sat Aug 11, 2018 4:23 PM.
#1786 _The Doctor__ OFFLINE
_The Doctor__
  • 5,177 posts
Posted Sat Aug 11, 2018 6:20 PM
a8 is a1... your images always look nice on my Ataris
the corvette is now peach and red... so you might not be out  of whack or maybe if you touched because you thought you were it became a self fulfilled situ...
#1787 Stephen OFFLINE
Stephen
  • 7,173 posts
  • A8 Gear Head
Posted Sat Aug 11, 2018 6:43 PM
Amazing results as usual.  I love that style of automotive art.  I could never get any images of my own vehicles to come out nicely, but given that one car is white and the other is black with some metal flake, there's not much with which to work.
#1788 Geister OFFLINE
Geister
    Star Raider
  • 96 posts
Posted Sat Aug 11, 2018 7:04 PM
Just a comment on the previous discussion about using these pictures in games.  Even if they are too big to use in a graphic adventure, they'd still make an amazing splash screen for a game!  Load the title screen to show something amazing while the actual program loads.  I'd like to see any contemporary computer do a better title screen than one of these pictures. It was literally impossible on any other PC until the IBM with VGA graphics.
#1789 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,443 posts
Posted Sun Aug 12, 2018 5:08 PM
Signal Gas Station NTSC. 78 colors.
#1790 adam242 OFFLINE
adam242
    Dragonstomper
  • 945 posts
Posted Sun Aug 12, 2018 9:32 PM
Really like that one. Very crisp and linear.
#1791 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,443 posts
Posted Mon Aug 13, 2018 10:03 AM
I do my best, but I can't see them on real hardware myself, so I just hope what I see in the .png output also looks good on real NTSC hardware, I know from experience it isn't always the case with PAL images. There have been some I thought looked great until I loaded them up on my Atari, with the real colors. NTSC averages about a half dozen more colors than PAL, sometimes even more, but images are cropped because it can't display the full 240p resolution like PAL. I could squeeze the entire picture in on NTSC, but the entire image would be less detailed and we need all the detail we can get at this resolution.
Edited by Gunstar, Mon Aug 13, 2018 10:09 AM.
#1792 Rybags OFFLINE
Rybags
  • 15,789 posts
Posted Mon Aug 13, 2018 6:21 PM
Turned out well though I'd change the source to make the light and other reflections from the road a bit darker.
#1793 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,443 posts
Posted Tue Aug 14, 2018 9:58 AM
Here is the latest, this one I forgot about and it went through a half-billion evaluations, and probably has line errors when viewed on real hardware, I couldn't test for even that, atm, because my Atari is currently in surgery for an upgrade. So let me know if it has errors on a real machine, and I'll redo it. Maybe I got lucky...
American Muscle NTSC. 90 colors.
Edited by Gunstar, Tue Aug 14, 2018 10:00 AM.
Also tagged with one or more of these keywords: Images, Gallery, RastaConverter, Colors
