SIO2PC for the ST
The ST could use something like SIO2PC as far as I know their isn't any thing like for the ST. I wish, I had the had the know how to make something like the SIO2PC, I could see using the ST port for Drive B and some how connect it to the PC. Is even possible?
http://www.atarimax..../documentation/
Edited by walter_J64bit
WOW, Say that could be installed in Drive B.
The purpose of that is to replace the main floppy drive entirely, just unplug the ST's internal floppy and then plug the USB Emulator into the same cables as the disk drive. The nice thing about it is that it works with a variety of other systems too.
Wouldn't Ghostlink be considered somewhat comparable to sio2pc? Close but maybe not quite as versatile:
Ghostlink v1.02 Beta is a link between an Atari GEM Computer (Master)
and a MS-DOS computer (Slave). It requires a NULL modem cable from your
ST to the PC. It fully supports the extra ports on the TT/Mega STE and
comes with both ST and PC programs. The ST is the master. You can't
access ST drives from the PC, but you can read and write to the PC
drives from the ST. It is possible to connect up to 3 PC slaves
(on different ports!) So, you can, for instance, import a picture stored
on a CD-Rom (connected to a MS-DOS PC) into Calamus!
Edited by eeun
I think it can, but a lot of games require being drive A I believe. I just removed my floppy and brought out the cables to plug into it. It's a really nice device, even has a menu program for loading disks.
I also use the device on my Amiga 500 and Tandy Coco 3.
~telengard
Edited by telengard
