Super Game Module technical forum
37 replies to this topic
#26 Pixelboy OFFLINE
Pixelboy
  • 8,243 posts
Posted Fri Oct 12, 2012 6:28 PM
if someone has an Adam with SGM and they plug in DKA cart and DKA detects the Adam's memory, and therefore does not enable the SGM's memory, does the SGM's sound chip still work?
Yes. the extra RAM and the sound chip in the SGM are two completely distinct components. Even if the RAM is disabled in the SGM (because the ADAM's RAM is used), the sounds chip is still fully accessible and usable.
#27 Geoff Oltmans OFFLINE
Geoff Oltmans
    Chopper Commander
  • 105 posts
Posted Wed Oct 17, 2012 2:18 PM
Where in the IO map (presumably IO-mapped) does the PSG live?
#28 jblenkle OFFLINE
jblenkle
  • 4,935 posts
Posted Wed Oct 17, 2012 4:51 PM
I have both...but ADAM-only owners wouldn't appreciate that...
Hi youki.
That would be a serious problem.
Maybe the module should be: "Only for use with ColecoVision".
I can see what you mean.
#29 tomjscott OFFLINE
tomjscott
    Chopper Commander
  • 124 posts
Posted Mon Oct 22, 2012 12:24 PM
This issue of the extra RAM not working with the Adam has me confused. If the extra RAM cannot be enabled on the Adam then are there going to be SGM games that won't run on the Adam because they require the extra RAM? Since the SGM is designed to work with both the Colecovision AND the Adam, is that extra RAM just always going to be unused to insure compatibility between both systems?
#30 opcode OFFLINE
opcode
  • 4,585 posts
  • Bringing new life to your ColecoVision!
Posted Mon Oct 22, 2012 12:26 PM
Ok, second and final part of the technical discussion about the SGM.
For sound the SGM offers an extra PSG, the AY-3-8910. It has similar sound capabilities as the CV PSG (SN76489), however it has a few advantages. Frequency range is much improved (both extremes of the human audible spectrum), and it offers volume envelopes. The AY-3-8910 was used by a large number of arcade games around 80-83, and was also featured on such computers as Atari ST and MSX.
The 3 sound channels of the SGM are then mixed with the CV PSG and output together. With that we now have 6 sound channels to play with, plus noise.
Differently of the SGM extra RAM, the AY-3-8910 is always active, so no need to activate it. I am not going to discuss the AY-3-8910 as tons of information can be easily found searching the web. The only information we need here is how to access the chip.
The SGM AY-3-8910 has been mapped to I/O ports 50h to 52h. 50h is the control port, used to set the register #. Port 51h is used to write data, while port 52h is used to read.
Another interesting fact about the AY-3-8910 is that all the registers can also be read. That is another way to check for the SGM, you can for example write data to any of the frequency register and read it back to see if the PSG is present.
Edited by opcode, Mon Oct 22, 2012 12:29 PM.
#31 opcode OFFLINE
opcode
  • 4,585 posts
Posted Mon Oct 22, 2012 12:40 PM
The ADAM already includes the extra 32KB of RAM, so that is why you cannot activate the SGM RAM if used with an ADAM.
Edited by opcode, Mon Oct 22, 2012 12:40 PM.
#32 Pixelboy OFFLINE
Pixelboy
  • 8,243 posts
Posted Mon Oct 22, 2012 12:41 PM
The extra RAM in the SGM is supposed to stay disabled when the module is plugged into an ADAM, because the ADAM's RAM is used instead. Eduardo has developed routines that he uses to detect the ADAM, and enables the extra RAM in the SGM only if a ColecoVision console is detected.
I do have a particular question though: The SGM offers two RAM modes, 24K and 32K (32K = BIOS disabled and replaced with RAM). Does the ADAM natively offer 32K of RAM to work with, or only 24K?
EDIT: Oops, already answered. Never mind. :)
#33 opcode OFFLINE
opcode
  • 4,585 posts
Posted Mon Oct 22, 2012 1:06 PM
The SGM mimics the ADAM memory mapping, and that is the beauty of the thing. Isn't that cool? :)
Edited by opcode, Mon Oct 22, 2012 1:07 PM.
#34 tomjscott OFFLINE
tomjscott
    Chopper Commander
  • 124 posts
Posted Mon Oct 22, 2012 2:32 PM
Understood. Thanks for clarifying.
#35 msmeenk OFFLINE
msmeenk
    Combat Commando
  • 7 posts
Posted Sun Oct 27, 2013 4:15 PM
I've probably missed this somewhere, but after numerous searches I can't find it, so I figured I'd ask here.
Does the SGM use the CV system clock ( 3.579545MHz ) divided by 2 for the AY-3-8910, or is there a separate crystal (4MHz/2 = 2MHz ?) ?
Still working on an MSX-CV conversion, and (I think?) it makes a difference in the note frequency.
#36 5-11under OFFLINE
5-11under
  • 3,406 posts
Posted Sun Oct 27, 2013 4:33 PM
I'm not sure. If nobody else responds with an answer, reply back here in a few days, and then I'll crack it open and scope it out.
Is it divided on the MSX? Eduardo probably made the set-up the same for the SGM.
#37 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,896 posts
  • Coding something good
Posted Sun Oct 27, 2013 7:48 PM
You use exactly the same frequencies as in MSX for SGM sound.
If you're doing a port from MSX to Colecovision, the SN76489 can use same values as AY-3-8910, just make sure you don't exceed 10 bits (AY-3-8910 has 12 bits of frequency)
Edited by nanochess, Sun Oct 27, 2013 7:48 PM.
#38 msmeenk OFFLINE
msmeenk
    Combat Commando
  • 7 posts
Posted Sun Oct 27, 2013 9:55 PM
Thanks!
AY-3-8910 datasheet states it needs 1-2MHz for a clock, so dividing the cpu clock is the easiest way.
The MSX runs the PSG at 1.7897725 MHz, which is half the cpu clock ( 3.579545MHz, same as the CV ), so of course he'd do it that way. :skull:
Also, adding an extra crystal just increases board size and cost, when the expansion port has a clock line already... Sometimes I think too hard about things and miss the obvious. :facepalm:
I ran into that a few months back and posted a question in another thread here. However, when the MSX uses all 12 bits, that's when the fun starts... ;-)
