macintosh man Posted April 5, 2013 Share Posted April 5, 2013 I finally found my Nintendo 64! so I plugged it in and got everything together. I turned on the system then the tv. I turned it to the av channel and.......nothing. all there was was a black screen! so I tried turning it off and back on. the screen flashed for a second then nothing. I did everything correct I put the cartridge in before starting the system. could it be the av cable? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted April 5, 2013 Share Posted April 5, 2013 Or try running it through a vcr and see. Could be the tv. My 64 is fine. Quote Link to comment Share on other sites More sharing options...
macintosh man Posted April 5, 2013 Author Share Posted April 5, 2013 Or try running it through a vcr and see. Could be the tv. My 64 is fine. I justtried it and it didn't even flash across the screen :/ Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted April 5, 2013 Share Posted April 5, 2013 You got anything in that little trap door on top of the N64? Even without the expansion pak the "filler" do hikey is required for operation............... The system requires the Jumper Pak when the Expansion Pak is not present or else there will be no picture on the TV screen. http://en.wikipedia.org/wiki/Nintendo_64_accessories#Jumper_Pak Quote Link to comment Share on other sites More sharing options...
macintosh man Posted April 5, 2013 Author Share Posted April 5, 2013 You got anything in that little trap door on top of the N64? Even without the expansion pak the "filler" do hikey is required for operation............... The system requires the Jumper Pak when the Expansion Pak is not present or else there will be no picture on the TV screen. http://en.wikipedia....ries#Jumper_Pak the jumper pak is in there and the connections are clean. I wish I could open it! there are the worlds weirdest security bolts on it Quote Link to comment Share on other sites More sharing options...
mbd30 Posted April 5, 2013 Share Posted April 5, 2013 I take it you tried a different cartridge, repeatedly blowing in the cartridge, cleaning the cartridge slot, etc. Usually black screen on an old cartridge-based system is the result of dust buildup. Quote Link to comment Share on other sites More sharing options...
TLD1985 Posted April 5, 2013 Share Posted April 5, 2013 you can buy the correct screwdrivers on ebay... they will open all the nintendo consoles/carts that use them. Quote Link to comment Share on other sites More sharing options...
macintosh man Posted April 5, 2013 Author Share Posted April 5, 2013 I take it you tried a different cartridge, repeatedly blowing in the cartridge, cleaning the cartridge slot, etc. Usually black screen on an old cartridge-based system is the result of dust buildup. I have tried cleaning the connections and still nothing Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted April 6, 2013 Share Posted April 6, 2013 I've found N64 consoles to be very reliable, at least so far. I suggest cleaning one game (with rubbing alcohol) really good, then wrap a thin cloth around a credit card and soaking it with alcohol and cleaning the slot of the console. Make sure your power supply is working, with a meter if you can. Maybe you can try swapping the power cable or the video cable or the cartridge with a friend that has a N64 already working. 2 Quote Link to comment Share on other sites More sharing options...
