mtshark7 Posted May 18, 2013 Share Posted May 18, 2013 I got a broken SNES off my friend. The round plastic piece that is inside the AC Adapter socket is broken off...which I hear is a common issue with SNES...so it works but if you move the power supply wire it will turn on and off since it's loose. I thought there was a tutorial on here about removing the power socket completely and replacing it with a laptop power cable? Or is there anyway to buy a new SNES power supply socket to solder onto the board to replace the broken one? Thanks for your help! Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted May 18, 2013 Author Share Posted May 18, 2013 (edited) Here is a pic of a bad/good power socket on the snes. Edited May 18, 2013 by Mark T Quote Link to comment Share on other sites More sharing options...
Uzumaki Posted May 18, 2013 Share Posted May 18, 2013 That power plug is molded into the entire back piece, you'd have to replace it. You could take an easier way out by drilling out the broken hole, find a replacement jack that uses the same barrel size as original SNES, screw or glue it in place, and solder the tabs onto the board. I don't know where to get the replacement port though. Quote Link to comment Share on other sites More sharing options...
sqoon Posted May 18, 2013 Share Posted May 18, 2013 Broken SNES power port is a common problem. Short of getting a donor system that does not work but has that plastic piece in tact, I recommend directly soldering the SNES power adapter right into the back of the console. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 19, 2013 Share Posted May 19, 2013 Hyperkin makes repros of it: http://hyperkin.com/parts/repair-parts-retro/snes-super-nintendo-power-input-jack-replacement-html.html Not cheap though. Mitch Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted May 20, 2013 Author Share Posted May 20, 2013 Thanks everyone for your help...wow $12 for the entire back piece! I wonder if anyone knows where to get a replacement type jack that would work? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 20, 2013 Share Posted May 20, 2013 Wow I feel so lucky. My unit still works. Port is fine. Unit is heavilly yellow and few chips on the sides but power port is ok. Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted May 20, 2013 Author Share Posted May 20, 2013 So if I end up buying the entire back piece how would I go about replacing it? Does that piece just slide right off? My one friend said it's molded onto the power socket...sorta like the NES top loaders. I can't confirm cos I haven't opened it up yet. Quote Link to comment Share on other sites More sharing options...
sqoon Posted May 21, 2013 Share Posted May 21, 2013 You take the six case screws out of the bottom of the console and it all comes apart. The $12 plastic cover for the A/C port is not molded in and just takes a little wiggling to get it out. 1 Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted May 21, 2013 Author Share Posted May 21, 2013 Oh ok thanks Sqoon! Quote Link to comment Share on other sites More sharing options...
Uzumaki Posted May 21, 2013 Share Posted May 21, 2013 I thought the power plug itself is soldered on that you need to desolder it before the back piece comes off? Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted May 21, 2013 Share Posted May 21, 2013 I got one just like that too! Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted June 5, 2013 Author Share Posted June 5, 2013 I got the piece in the mail and yea you do have to de-solder the old piece but how the hell do you desolder it with the rf jack sticking out of it? I tried heating the solder and wiggling it out and its not going well. Also with the rf jack sticking out how do I install the new one? I saw this video which explains 0%: Is there any detailed instructions on how to replace these things? Would I have to desolder the RF jack? Thanks! Quote Link to comment Share on other sites More sharing options...
0078265317 Posted June 5, 2013 Share Posted June 5, 2013 you could desolder the rf jack cuz then you still have the av port. Quote Link to comment Share on other sites More sharing options...
NinjaWarrior Posted June 6, 2013 Share Posted June 6, 2013 Why does it say "Wholesale Accounts ONLY!"? Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted June 6, 2013 Author Share Posted June 6, 2013 NinjaWarrior: Wholesale accounts? ALL: An update: I finally fixed it! I got an install guide from here: http://www.nintendorepairhut.com/selfrepairguides/downloadablerepairguide.html I also DIDN'T HAVE TO DESOLDER THE RF SOCKET. You first desolder the two pins on the ac socket then wedge it out. Even tho the part is slightly expensive, it's worth fixing. 1 Quote Link to comment Share on other sites More sharing options...
+Mitch Posted June 6, 2013 Share Posted June 6, 2013 Awesome. I'm glad you got it working. Mitch 1 Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted June 6, 2013 Author Share Posted June 6, 2013 Thanks Mitch! Also here is the best place to buy the replacement part at: eBay Auction -- Item Number: 170920461238 From Ebay ID: starwander. So far it's the cheapest I seen on the internet. Quote Link to comment Share on other sites More sharing options...
sqoon Posted June 6, 2013 Share Posted June 6, 2013 The install guide from your link was missing all the embedded images when I downloaded it. Words are OK, but pictures are better. Quote Link to comment Share on other sites More sharing options...
copper20 Posted October 18, 2013 Share Posted October 18, 2013 Sorry to bump this but I have the same problem and I was wondering if someone could do this repair service for me. And additionally, can you add a barrel to it (Or whatever that thing is) to the power jack so that it doesn't fall off? I'm not sure if you can do that once the power jack's fixed. I'll pay 15 or 20 dollars. Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted October 21, 2013 Author Share Posted October 21, 2013 Copper20: PM Sent Quote Link to comment Share on other sites More sharing options...
Ataridroid Posted November 5, 2014 Share Posted November 5, 2014 (edited) Copper20: PM Sent I have the same problem, who wants to do this for me? Edited November 5, 2014 by Ataridroid 1 Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted November 5, 2014 Author Share Posted November 5, 2014 Ataridroid: I can do it for you...shoot me a pm. Just ship me over the console and the replacement socket. Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted November 5, 2014 Share Posted November 5, 2014 I had to replace this piece on one of my SNES's a year or so ago. A guy in a local gamestore replaced it for me for the price of a few doubles that I traded in. Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted November 5, 2014 Share Posted November 5, 2014 I replaced one of these a few years ago. The soldering was easy-enough that even I could do it, and there's not much I will attempt, and I suck at soldering. Quote Link to comment Share on other sites More sharing options...
