e5frog Posted May 22, 2013 Share Posted May 22, 2013 (edited) I'm looking for an NTSC Atari 2600, preferably the black one (called Darth Vader, right?). I only need the actual console, got everything else. It doesn't need to be an exhibit object, I'm going to use it for gaming. Dust, dirt, poor RF cable or other minor faults is not a problem (even if a perfect one is nice). If you have one to spare, let me know. Edited June 8, 2013 by e5frog Quote Link to comment Share on other sites More sharing options...
Hellboy_Bass Posted May 22, 2013 Share Posted May 22, 2013 I have one but the Reset switch is broken off, but it still works, you just need to stick a metal bit in to push down the reset switch. would you be interested? If not I understand. Quote Link to comment Share on other sites More sharing options...
Rick Weis Posted May 22, 2013 Share Posted May 22, 2013 I have one also.. atari 2600 vader system console only http://www.gamegavel.com/item.cgi?show_item=0000766259 Starting At $15.00 Ends: May 23, 2013 8:00:00 PM EDT Rick Quote Link to comment Share on other sites More sharing options...
e5frog Posted May 24, 2013 Author Share Posted May 24, 2013 (edited) Hellboy_Bass: Could be an option of nothing else pops up. Rick Weis: Seems that one has ended, I'd be willing to pay $15 for a working unit, could you check a cheap shipping alternative to Sweden? If it's difficult I have a friend in New York that helps out with these kinds of things. I mean I'll take it if you still got it. Edited May 24, 2013 by e5frog Quote Link to comment Share on other sites More sharing options...
Rick Weis Posted May 24, 2013 Share Posted May 24, 2013 I'll check on it once I get back from a camping trip this long weekend (I still have the system!) I would guess your friend would be the cheapest.. I'll contact you on Tuesday if you still need it by then. Thanks, Rick Quote Link to comment Share on other sites More sharing options...
e5frog Posted May 27, 2013 Author Share Posted May 27, 2013 Only 3.5 hour until Tuesday... here in Sweden at least. Still "need" it. Quote Link to comment Share on other sites More sharing options...
Rick Weis Posted May 28, 2013 Share Posted May 28, 2013 PM sent Rick Quote Link to comment Share on other sites More sharing options...
e5frog Posted June 7, 2013 Author Share Posted June 7, 2013 Got the one from Rick, seems to be some problems with it, it needed more than just a clean-up. On one TV I got no color and static instead of sound, on another I managed to get color but still no sound so I'm looking into it. I have one more TV that does NTSC but that's the one that's least forgiving so I don't have much hope about that. I'm leaning towards a composite mod if sound checks out OK. Hellboy_Bass, yours might be interesting if I can't fix this one. Quote Link to comment Share on other sites More sharing options...
Hellboy_Bass Posted June 7, 2013 Share Posted June 7, 2013 Got the one from Rick, seems to be some problems with it, it needed more than just a clean-up. On one TV I got no color and static instead of sound, on another I managed to get color but still no sound so I'm looking into it. I have one more TV that does NTSC but that's the one that's least forgiving so I don't have much hope about that. I'm leaning towards a composite mod if sound checks out OK. Hellboy_Bass, yours might be interesting if I can't fix this one. If you open it up, there's a potentiometer inside that controls sound, it should be sticking through the metal inner case and surrounded in red plastic. If you can stick a small screwdriver or something in there, you can turn it and possibly fix the sound. If not that, it might just be a broken connection somewhere on the board. If all that fails, mine is still available and I think I can fix the reset switch as well. So let me know, thanks! Quote Link to comment Share on other sites More sharing options...
e5frog Posted June 7, 2013 Author Share Posted June 7, 2013 I tried adjusting that one, it's a coil around red plastic with a threaded ferrite core inside that has a hex cutout in the middle, I have proper tools (bought them for my arcade game) which is basically hex driver in plastic. I got no change in the sound at all. I wonder how many turns is within the acceptable range or if it's 1/100:th of a turn that needs to be hit for sound to come out. Usually you're able to turn such things 1-2 turns and still have the same result - and then you set it in the middle position. I'll measure the sound directly from the IC and we'll see, a composite mod isn't a bad thing for this machine anyway if there's sound out but the RF fails. Quote Link to comment Share on other sites More sharing options...
Hellboy_Bass Posted June 7, 2013 Share Posted June 7, 2013 I tried adjusting that one, it's a coil around red plastic with a threaded ferrite core inside that has a hex cutout in the middle, I have proper tools (bought them for my arcade game) which is basically hex driver in plastic. I got no change in the sound at all. I wonder how many turns is within the acceptable range or if it's 1/100:th of a turn that needs to be hit for sound to come out. Usually you're able to turn such things 1-2 turns and still have the same result - and then you set it in the middle position. I'll measure the sound directly from the IC and we'll see, a composite mod isn't a bad thing for this machine anyway if there's sound out but the RF fails. Sounds like you know more than I about 2600 repair, lol. Hopefully you can work it out, but if not, drop me a line. Quote Link to comment Share on other sites More sharing options...
e5frog Posted June 7, 2013 Author Share Posted June 7, 2013 I had sound from the TIA so there's something wrong in the RF department. I measured the sound carrier with the scope and set it exactly right but it still just threw static on me. So, I'll just mod it and it will be fine. Quote Link to comment Share on other sites More sharing options...
e5frog Posted June 8, 2013 Author Share Posted June 8, 2013 Vader found, thread closed. Quote Link to comment Share on other sites More sharing options...
e5frog Posted June 9, 2013 Author Share Posted June 9, 2013 Got the three resistor composite mod running and audio is sweet so I'm good until I get the parts for the Longhorn mod. Quote Link to comment Share on other sites More sharing options...
