Kylearan Posted January 27, 2014 Share Posted January 27, 2014 How sensitive are TVs to infrequent, small variations in number of scanlines? I see Thomas notifying other people when their kernels have variable scanline counts, and found a few discussions on rolling screens on TVs so I guess it's fairly important to have a constant scanline count. So far my PAL kernels manage to generate a constant 312 scanlines according to Stella. The only problem is when I switch from one Kernel to another, which only happens every 30 seconds or so. Then there is one single frame with a different number of scanlines, before it will be 312 again next frame. Is this single frame already enough to cause screen rolling? Related question: Debugging (or even detecting) scanline variations is hard if the number of scanlines only varies in one single frame every 20-30 seconds. Is there some way to tell Stella to break if the number of scanlines in a frame deviates from a specific number? Or to generate a trace/log of scanline counts, so I can see the number of scanlines per frame and find out in which frame the number varies? How do you debug this kind of problem? Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 27, 2014 Share Posted January 27, 2014 If it's a big variance in the single frame, then yes, you could get a full roll, partial roll, or jitter, depending on the TV. A small variance in a single frame will usually visibly shake the screen, but not on always, depending on the TV. You should work on getting the same line counts for both kernels, even during a hand-off. If you have the same number of visible lines in both kernels, it probably means your overscan or vblank time/counts are different, or you're setting one of those timers earlier or later for one of the kernels. (assuming you're using timers) RT wrote up a very good summary of keeping track of scanline counts in stella. It includes instructions on how to set up a stella breakpoint if the count exceeds a certain number. 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 27, 2014 Share Posted January 27, 2014 1. Yes, some TVs are very sensitive. And PAL will loose all color when an odd number of scanlines is displayed. 2. Debugging: Stella supports breakif. Check the debugger documentation, the possibilities are huge! The problem is, that when you use a break you cannot step backwards a frame or so. So it it usually better to step by using frame+1. As soon this becomes too long, step back one frame and then you can debug the frame causing the problem. Quote Link to comment Share on other sites More sharing options...
Kylearan Posted January 28, 2014 Author Share Posted January 28, 2014 OK, I'll take extra care then not to have a single frame with different scanlines. Thanks for the link! I knew about breakif, but somehow missed the scanline var. Nice! Stella is one awesome piece of Software. :-) Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 31, 2014 Share Posted January 31, 2014 My roommates TV was sensitive to rolling. I found that out in the morning after I crashed into his room drunk and slept on the floor by mistake. Quote Link to comment Share on other sites More sharing options...
