I have a batch for it, if you want
Posted Tue Jul 28, 2015 5:16 PM
Posted Tue Jul 28, 2015 5:20 PM
Posted Tue Jul 28, 2015 5:30 PM
My SAMS is fully functional. AMSTEST4 verifies that it is there and everything is working correctly. All of the programs load and run fine and TurboForth finds it quite nicely. It has been my experience that Classic99 does NOT always mirror real TI gear. MESS seems to be more accurate as far as emulation is concerned.
Thanks. I am sure the problem is with the routine or some interpretation of how the SAMS card functions. I ran AMSTEST4 and noticed you had a hand in modifying the program. Does the original source exist? Maybe Brad's code only works with the smaller capacity AMS card.
Posted Tue Jul 28, 2015 5:32 PM
ah, I nearly forgot the FOUNDATION 128K: was undefinable, so I checked the the DSRs again:
036-Foundation-128K-832C.jpg 92.67KB
2 downloads
037-Foundation-128K-832C.jpg 239.5KB
2 downloads
038-Foundation-128K-832C.jpg 248.76KB
2 downloads
Posted Tue Jul 28, 2015 5:37 PM
If the IDE is recognized as the SAMS, just because the CRU-address >1E00, the DSRs maybe are not read out from the cards ?
Maybe only the CRUs ?
But if Atrax´ card is running, and using >1E00, it should be shown in the ROSCFG832C.....
Maybe you can check the presence of the card (and the DSRs) once with Fred´s DU2K ?
...just to see whats happens.
Posted Tue Jul 28, 2015 5:39 PM
SAMS detect from Willsy
: SAMS? CR ." SAMS Memory card" $3000 @ 994a $3000 ! 255 $3000 >MAP $3000 @ 994A = IF ." not " THEN ." found " 0 $3000 >MAP $3000 ! ; SAMS? CR
That definition is flawed:
The following should work for whatever radix is current:
: SAMS? CR ." SAMS Memory card " $3000 @ $994A $3000 ! $FF $3000 >MAP $3000 @ $994A = IF ." not " THEN ." found " 0 $3000 >MAP $3000 ! ;
[EDIT: Note the change from ‘255’ to ‘$FF’ to ensure radix insensitivity.]
...lee
Edited by Lee Stewart, Tue Jul 28, 2015 5:46 PM.
Posted Tue Jul 28, 2015 5:41 PM
THIERY´s IDE:
I felt boring, so I digged it out, and set it from CRU >1F00 to >1E00
so it was recognized as AMS/SAMS-Card (?) I think just by the address? hmmmm
So the DSRs seem not to be detected, or to misinterpreted...
IDE cards should not be placed at a high CRU
The SAMS detection over-rides any other card identification for CRU 0x1E00. I did this for testing purposes. The only time it will happen is if RAM is found in the DSR space. I am fairly certain Fred's DSR is supposed to lock the DSR as read-only for normal operation. Maybe the SAMS detection enables writes to the DSR. Interesting! The Brad Snyder method will not detect the IDE; however, since it writes to the mapper addresses, Fred's DSR might suffer.
Please reset your IDE to another CRU address
Edit: Foundation also will not work because of the AMS test code I redid. Consequences, consequences... Time for a break.
Edited by InsaneMultitasker, Tue Jul 28, 2015 5:43 PM.
Posted Tue Jul 28, 2015 5:42 PM
Old farts and packrats NEVER throw anything away. I have the source, I'll just have to find it.
I'm an old fart AND a packrat, but I can never find anything in the mess. You must be more organized than me.
Posted Tue Jul 28, 2015 5:44 PM
Posted Tue Jul 28, 2015 5:52 PM
Lee,
That's how it is on my boot blocks. I just wrote it all out in a single line instead of trying to put it into a proper block format.
You said it did not work. What I posted works in Classic99 with SAMS enabled/disabled.
...lee
Posted Tue Jul 28, 2015 6:02 PM
Posted Tue Jul 28, 2015 6:03 PM
Posted Tue Jul 28, 2015 7:42 PM
Tim,
Check you inbox for the AMSTEST4 source.
I implemented Bruce's check, although I don't see how it can be considered a test. It isn't doing anything different to the 16 registers than what I did originally with one.
Anyway, here it is. CRU 0x1E00 may display two devices as I wanted to allow both detection routines to operate. Let's see what happens.
CFG832d is on the disk.
Posted Tue Jul 28, 2015 8:26 PM
Edited by atrax27407, Tue Jul 28, 2015 8:39 PM.
Posted Tue Jul 28, 2015 8:29 PM
Edited by atrax27407, Tue Jul 28, 2015 8:40 PM.
Posted Tue Jul 28, 2015 9:39 PM
However, another bug has crept in. Instead of a reasonable return when pressing FCTN-= and allowing MENU to re-boot. I get a colorful screwed up screen. Almost there! All that needs to be done is make sure we use a BLWP @0000 for a re-set.
I will have to inspect the TEST routine. There may be some trick that need to be performed after the testing. If the FCTN-= worked in the previous "C" version, then it may be simple to track down. I have no idea why this routine works... I may need to find my SAMS card this weekend or it will bug me! Thanks Atrax.
Posted Tue Jul 28, 2015 9:52 PM
I am so confident that you will succeed quickly that I have moved some small programs from DSK4 to DSK5 to make space for the slightly larger CFG832x when it is finished. I also altered my RAMdisk backups accrodingly.
Posted Wed Jul 29, 2015 2:23 PM
I tried the CFG832D on the disk and it successfully detected my Super AMS card!
HRD_detect1.JPG 94.41KB
2 downloads
Edited by Cschneider, Wed Jul 29, 2015 2:24 PM.
Posted Wed Jul 29, 2015 2:31 PM
Whew. Now... like Atrax, did you get a colorful screwed up screen when you hit FCTN-= ? If not, what cartridge are you using?
Posted Wed Jul 29, 2015 3:02 PM
No colorful screen when I hit quit. I tested it with both Editor Assembler Cart and XB 2.7 Suite cart.
Posted Wed Jul 29, 2015 4:31 PM
OK - I tried running CFG832D from "Rum Program File" in MENU. the F'WEB loaders, REA 2015, and got exactly the same results upon quitting. A colorful wierd screen. All of a sudden, for unfathomable reasons, it has finally decided to "play well" with my system. I have no idea why or what the initial problem was with its exit but it is working fine now. Gremlins?
Posted Wed Jul 29, 2015 7:43 PM
Sounds like SPIKE was at it again.
Posted Wed Jul 29, 2015 8:09 PM
It's a vdp register problem, or maybe not clearing the status byte before quitting.
Should be an easy fix.
Gazoo
Atari Systems →
Atari 8-Bit Computers →
![]() Ramdisk driver for MyDos4.53/4 and Sys-Check 2 512K RAMStarted by E474, 4 Feb 2019 ![]() |
Atari Systems →
Ramdisk driver for DOS 2.5 and Sys-Check 2 512K RAMStarted by E474, 29 Jan 2019 ![]() |
Gaming General →
Classic Gaming General →
Intellivision / Aquarius →
![]() jzIntv Keyboard Hackfile for Win10 Vision-Daptor?Started by First Spear, 20 Feb 2017 ![]() |
Gaming General →
Classic Computing →
TI-99/4A Computers →
Horizon 4000 mysteryStarted by InsaneMultitasker, 21 Mar 2016 ![]() |
Gaming General →
Classic Computing →
![]() Rave 99 Ramdisk documentationStarted by RickyDean, 13 Jun 2015 ![]() |
