Charlie_ Posted March 29, 2014 Share Posted March 29, 2014 I don't really remember much about how to use my TI-99. I have a PEB with the memory expansion and a DSDD (360K) drive installed in it. I use a windows98 PC and ti99-pc to write images to floppy disks. I have an old Adaptec scsi card in the pc that has a floppy controller on it. It can do SD disks, no troubles. So, I use ti99-pc to make disks for Munch Man II and Bandit. The process goes OK, and I can catalog them with TI99-PC and I see the files on the floppies. TI99-pc says they are both 180K DSSD disks. When I put the disks in the PEB with Extended basic cart, I boo the system and the disk light goes on but I'm only greeted with the Basic prompt. I tried to catalog the disks using my Disk Manager cart, but it is version 1.0 and I don't think it works with double sided disks...(?) I have an editor assembler cart, but I don't know how to use it really... I'll attach the DSK files here in a zip. Maybe someone can be so kind as to look at them and tell me how I might get them running on my TI? Thanks. MM2 and Bandit DSK.zip Quote Link to comment Share on other sites More sharing options...
Gazoo Posted March 29, 2014 Share Posted March 29, 2014 I don't really remember much about how to use my TI-99. I have a PEB with the memory expansion and a DSDD (360K) drive installed in it. I use a windows98 PC and ti99-pc to write images to floppy disks. I have an old Adaptec scsi card in the pc that has a floppy controller on it. It can do SD disks, no troubles. So, I use ti99-pc to make disks for Munch Man II and Bandit. The process goes OK, and I can catalog them with TI99-PC and I see the files on the floppies. TI99-pc says they are both 180K DSSD disks. When I put the disks in the PEB with Extended basic cart, I boo the system and the disk light goes on but I'm only greeted with the Basic prompt. I tried to catalog the disks using my Disk Manager cart, but it is version 1.0 and I don't think it works with double sided disks...(?) I have an editor assembler cart, but I don't know how to use it really... I'll attach the DSK files here in a zip. Maybe someone can be so kind as to look at them and tell me how I might get them running on my TI? Thanks. For the Bandit disk, use the Extended Basic Cartridge. At the Extended Basic prompt, type RUN "DSK1.LOADBAND" and press enter to run the program. For the Munchman ll disk, use the E/A cart. Press 5, and press enter at the prompt. This will load DSK1.UTIL1 and run the program. Let us know if you're successful. Gazoo Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 29, 2014 Share Posted March 29, 2014 I don't really remember much about how to use my TI-99. I have a PEB with the memory expansion and a DSDD (360K) drive installed in it. I use a windows98 PC and ti99-pc to write images to floppy disks. I have an old Adaptec scsi card in the pc that has a floppy controller on it. It can do SD disks, no troubles. So, I use ti99-pc to make disks for Munch Man II and Bandit. The process goes OK, and I can catalog them with TI99-PC and I see the files on the floppies. TI99-pc says they are both 180K DSSD disks. When I put the disks in the PEB with Extended basic cart, I boo the system and the disk light goes on but I'm only greeted with the Basic prompt. I tried to catalog the disks using my Disk Manager cart, but it is version 1.0 and I don't think it works with double sided disks...(?) I have an editor assembler cart, but I don't know how to use it really... I'll attach the DSK files here in a zip. Maybe someone can be so kind as to look at them and tell me how I might get them running on my TI? Thanks. Is your disk controller TI? or Myarc/Corcomp? Try formatting the disks on the TI and then copying the files on the PC to them. The PC drive may format them in a way the TI can't read. The TI controller is capable of max Double Sided/Single Density Any disk manager will catalog any disk as long as the controller can read it. The catalog program in the disk controller manual will work in extended basic. http://ftp.whtech.com/datasheets%20and%20manuals/Hardware/Texas%20Instruments/PHP1800%20Disk%20Drive%20Controller/Disk_Memory_System.pdf (page 25) Best disk manager is DM2K, also on whtech in the fkaal directory or off his webpage.. Greg Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 29, 2014 Share Posted March 29, 2014 For the Bandit disk, use the Extended Basic Cartridge. At the Extended Basic prompt, type RUN "DSK1.LOADBAND" and press enter to run the program. For the Munchman ll disk, use the E/A cart. Press 5, and press enter at the prompt. This will load DSK1.UTIL1 and run the program. Let us know if you're successful. Gazoo If you don't have an EA cart you can use a EA loader for Extended Basic to load it.. There are a few out there.. Funnlweb is a good easy choice. Greg Quote Link to comment Share on other sites More sharing options...
Ed in SoDak Posted March 29, 2014 Share Posted March 29, 2014 (edited) When you choose Extended BASIC, it looks for a file called LOAD on Drive 1. If not found it goes to the cursor, where you can then type OLD and the program name and then type RUN after it reads in from disk. You can rename any EXB program as LOAD and it will autoboot or you can add a small loader program which you name as LOAD and it will bring up a disk directory for you to choose from. There's many variations of EXB LOAD programs, my favorite is called BOOT, which is an assembly EA5 program that includes an EXB loader. -Ed Edited March 29, 2014 by Ed in SoDak Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted March 29, 2014 Author Share Posted March 29, 2014 For the Bandit disk, use the Extended Basic Cartridge. At the Extended Basic prompt, type RUN "DSK1.LOADBAND" and press enter to run the program. For the Munchman ll disk, use the E/A cart. Press 5, and press enter at the prompt. This will load DSK1.UTIL1 and run the program. Let us know if you're successful. Gazoo Thanks! Also to everyone else who replied. Got them working nice. So, now I have this thing out and running, is there any other more recent games I could create disks to play? Quote Link to comment Share on other sites More sharing options...
Asmusr Posted March 29, 2014 Share Posted March 29, 2014 So, now I have this thing out and running, is there any other more recent games I could create disks to play? Check out this site: http://tigameshelf.net/ Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted March 30, 2014 Author Share Posted March 30, 2014 Check out this site: http://tigameshelf.net/ Thanks. Made a whole bunch of disks and have been enjoying this TI99. I have a question about one game though... I can't get it started. Astro Fighter, here: http://tigameshelf.net/Files/Emu/Astroft.dsk It says ASTROFGT (E/A option 3) Enter START when asked for program name Maybe I am doing something wrong, but I couldn't get it working. Could someone tell me how to get the game running? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 30, 2014 Share Posted March 30, 2014 It is START, but you should be more specific about "not get it working". BTW, tigameshelf delivers this file wrongly by text/html MIME type, not application/octet-string as would be appropriate. This can be defined in the webserver's conf file. I wondered why I get the file as a dump in my browser. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 30, 2014 Share Posted March 30, 2014 Thanks! Also to everyone else who replied. Got them working nice. So, now I have this thing out and running, is there any other more recent games I could create disks to play? What ended up being the issue? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted March 30, 2014 Author Share Posted March 30, 2014 It is START, but you should be more specific about "not get it working". BTW, tigameshelf delivers this file wrongly by text/html MIME type, not application/octet-string as would be appropriate. This can be defined in the webserver's conf file. I wondered why I get the file as a dump in my browser. I start E/A cart press 3, type START and get IO error code 0 Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted March 30, 2014 Author Share Posted March 30, 2014 What ended up being the issue? The issue was me not remembering how to use the TI. I did not remember to put DSK1. in front of the file name. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted March 30, 2014 Author Share Posted March 30, 2014 OK, I got Astro Fighter working. I start the E/A cart and press 3, then type DSK1.ASTRFGT It loads for a few seconds and then I choose BACK press 4 and enter START and the game runs. Quote Link to comment Share on other sites More sharing options...
Tursi Posted March 31, 2014 Share Posted March 31, 2014 OK, I got Astro Fighter working. I start the E/A cart and press 3, then type DSK1.ASTRFGT It loads for a few seconds and then I choose BACK press 4 and enter START and the game runs. Yep! You can also just press enter with a blank entry at the "FILE NAME" prompt (after loading the first file) to get to the "PROGRAM NAME?" prompt! Saves one step. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 31, 2014 Share Posted March 31, 2014 BTW, tigameshelf delivers this file wrongly by text/html MIME type, not application/octet-string as would be appropriate. This can be defined in the webserver's conf file. I wondered why I get the file as a dump in my browser. It's actually application/octet-stream. This has been fixed. Thanks for the tip Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 31, 2014 Share Posted March 31, 2014 ehm ...yes, octet-stream, sure. Many of these web server issues (concerning the download of files like disk images etc.) can be cleared up with a little server config work ... glad that it helped. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 31, 2014 Share Posted March 31, 2014 ehm ...yes, octet-stream, sure. Many of these web server issues (concerning the download of files like disk images etc.) can be cleared up with a little server config work ... glad that it helped. I doesn't look like I have direct access to the server config file. I have to go through the Earthlink Control Center to set some of the parameters. Not sure if this is a security issue. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted April 4, 2014 Author Share Posted April 4, 2014 Again, thanks for the help to get me going. I've been playing with the system a lot, really having fun with it. 4 Quote Link to comment Share on other sites More sharing options...
RXB Posted April 5, 2014 Share Posted April 5, 2014 If you do not know the name of a EA 3 Program to type in the name and START does not work, then use RXB as it shows all the PROGRAM names for you. It also shows all the routines installed in the EA. Quote Link to comment Share on other sites More sharing options...
