Multi Sprite Flickering at Vertical Boundries
Gemintronic
All I can pass along is what I have seen in the DPC+ Kernel, which is similar to the multisprite in a lot of ways.
In DPC+, sprites have to have at least seven lines between them or they intelligently flicker.
In DK Arcade 2600, you can see when the barrels appear new at the top, ALL the virtual sprites flicker a frame, (the barrel, the 2 hammers, any other on-screen barrels.) This was the first time I noticed that behaviour.
One other thing that can cause them to start intelligently flickering is if they are close to off-screen sprites. Now DPC+ offscreen is not Y=0, I have been using Y=200 to move them offscreen. I don't know if the kernel you use works that way or not.
Setting playerheights larger than displayed pixels can cause flicker, I think, if they become close. Maybe set playerheights to 0 when offscreen? Again, I'm only guessing here.
That's a big clue iesposta. Thanks!
I set the playerxheight to 0 to effectively blank out the sprite without resorting to a line like this:
player1:
end
As long as they share the same virtual y the engine may be flickering them even when no need exists. I'll run some experiments to see if that's the case!
It isn't the normal flicker and it doesn't only do it for a height of 0
I'm guessing the sorting routine is getting confused some way
if you set things up so you can step players1..5 you can see that
they completely disappear. does it with the height set to 1 or 2
also. I haven't played with it enough to figure out what's going
on, I don't know if it's position or overlap or what.
also it doesn't seem to do it if at least one of the parked
sprites has a height >2
I don't see anything in your code.
you have a hole in your heart(s)
Edited by bogax
I think I have it solved.. enough :) Still flickers at the bottom.
msflicker2.bas
msflicker2.bin
When a sprite needs to clear off the screen it wasn't enough just to change the height to 0. I set each sprites off-screen position 10 pixels away vertically from any other sprite.
player1y = 110 : player2y = 120 : player3y = 130 : player4y = 140 : player5y = 150
Normally I'd be afraid the sprites would warp and go funky with off screen positions like this but it didn't happen. Just try going off-screen vertically with the first sprite to see what I mean.
The hole in the heart is supposed to represent the shine coming off the heart from a light source. Unfortunately, since you get one color, I had to use a transparent pixel which doesn't look right on a black background.
Two off topic suggestions
rand is a call to a different bank, you might want to consider
using inlinerand
I'd try dealing with the sprites using indexing
Good idea about the rand. I'm not quite savvy enough to pick up on the sprite indexing. Could you explain that in more detail?
Right now I "launch" the sprites every 10 clicks of the counter variable. Assuming the sprites are moving down one pixel each iteration of the main loop this guarantees a 10 pixel vertical spacing between sprites (thus avoiding flicker).
I'm afraid there's some junk in this code
but it should give you the idea.
msflicker_wloops.bas
for one thing, I modified the counter so it (partialy)
runs a little faster.
